PFJN> That's a lot of filing and sanding! But we all love that... Don't we? As for access, I would assume there would be a hatch. Perhaps one overhead that could be jettisoned in case the pilot had to eject. For such a small craft, I assume an ejection seat would be provided... maybe.
Hypertex> Look forward to see what you do! I have a couple of more LMs that could probably use an upgrade.
Gamera> Will appreciate anything you might find, photo wise. The upper stage is ready for paint, but there's no rush as I'm goint to get the descent state cleaned up and ready before attempting.
Progress Report:
I've finished painting up the interior (though it's just a couple of colors). After the paint was dry, I placed a small piece of paper over the window opening and traced it out with a pencil, then cut it out to use as a template.
Tracing the paper template, I then cut the windows out of a clear, plastic sheet with an X-Acto knife. I made sure to cut them a little larger than the template.
Then using Aleene's Clear Gel I glued them in position. After the glue dried, I used the template again and cut some masks for the windows.
A bit more sanding and she'll be ready for paint. Now it's on to the descent stage, and trying to decide on a paint scheme overall.
One thing I think I will do for the descent stage is make some new legs. I have some brass tubing and plastic rod, so making some telescoping legs would look better than the ones in the kit.
Mission Director (GAF)
