Adversary & Aggressor GB (3/15/09-12/31/09)
    June 2008
Posted by lewbud on Saturday, October 24, 2009 3:18 AM
Chris,
Nice work.  Haven't forgotten about this build, just haven't gotten around to it yet.
Buddy- Those who say there are no stupid questions have never worked in customer service.
    November 2008
Posted by Hot-Pb on Saturday, October 24, 2009 6:24 AM
Truly spectacular Chris. Thumbs Up [tup]Thumbs Up [tup] And equally impressive, if I recall right, the splinter camo was hand painted? She really came out nicely and I'm sure it will spur the masses! In fact we have a new participant, Konigwolf13. You made them salivate Chris, LOL. Thanks for posting!
Tony
    November 2008
Posted by Hot-Pb on Saturday, October 24, 2009 6:42 AM
 lewbud wrote:
Chris,
Hi lewbud, I know you wouldn't forget us! These builds always get livelier as the deadline approaches and I'm certainly looking forward to your funky green Skyhawk!
Just for everyone's info, I had mentioned a while ago that AFV Club has been working on a new tooling for a 1/48 F-5E Tiger II, a real mainstay of aggressor squadrons, particlulary for the US Navy and Marines. They've posted some test shots over at Aeroscale and it looks sweet, I think one of the really anticipated releases of the year and if we're lucky it will be out before the holidays...which would unfortunately force me (and my dwindling wallet) to do a second bird for this GB! Anyhow, I thought folks here would be interested in seeing some of these test shots Dinner [dinner].
    May 2009
Posted by Konigwolf13 on Saturday, October 24, 2009 7:42 AM
Tony
Yes certainly made me sit up and take notice.
Anyways was picking up an expensive amount of paints yesturday and had enough money to pick up this bird from shops cheapo bin, being a scale I've never working in before I figured, hell why not. Got her home, looked at the instructions and as expected rather short on information (well it is an acedemy kit, looks not bad in general lines though). The only info paint wise given was "light grey with medium grey patches" . I figured if I had to google more accurate paint info I might as well make it exciting, after a while I found some images of birds from the 65 Aggressor squadron, figured looks like a good idea, see this thread today, and was sold.
heres what it should be
 This is what I plan to do with her
I have more accurate details than above, but not looking fwd to doing the 1/100th marking by hand LOL
    November 2008
Posted by Hot-Pb on Saturday, October 24, 2009 9:23 AM
Konigwolf13,
I have got to admit, the extra digit in 1/100 sounds small but hey, if it was easy everybody would be doing it! Do you have decals for the bird at that scale?
Tony
Posted by Bossman on Monday, October 26, 2009 11:55 AM
Thanks for the kind comments guys, and good to see that this GB hasn't faded away yet.  Looking forward to seeing more.   That F-5 looks like a nicely detailed kit.
Chris
    May 2009
Posted by Konigwolf13 on Sunday, November 29, 2009 11:16 PM
OK Painting stage. She comes with a stand so I went with the wheels up configeration, and discovered she was not ment for that look, the gear doors needed alot of sanding to sit flush. Also needed some putty and sanding around the air intakes as well.
Did the base layer of Gunze sangyo light blue, then dusted with tamiya xf-23 light blue to get the right colour. Then I 've done GS 322 for the camo. I got part way through this coat and realized I still had the large flow nozzle in the airbrush which accounted over spray, So I need to redo the light blue again, hope it looks fine, cause I dontreally want to strip the paint and start again, lol.
 Andrew
    November 2008
Posted by Hot-Pb on Tuesday, December 1, 2009 1:10 PM
 Andrew
Thumbs Up [tup] Looking great to me Andrew, paint looks nice and smooth, if there's any overspray I can't tell. Looking forward to seeing it all decaled up.
Tony
    May 2009
Posted by Konigwolf13 on Tuesday, December 8, 2009 11:13 PM
Thanks Tony, might not of been able to see it in the photos, bit it was there.
FINISHED
As it turns out without using an enamel based paint as a primer, just using crud quality tape, and handytak at masks  it was taking paint off down to the model. In fact just pouring metho over to make a bath to strip the paint took 99% of the paint off.
 I gave a grey enamel primer, then coated in light blue. I then made some masks by printing out the paint guide at the approx size, taped it on, and handytaked the in between bits.I then pained remaining areas.
Decals are mostle printed normal paper glued to aircraft with hand painting over white areas to small to cut out. I used the decals that came with the model, though not full black I think on this scheme they actually look better, I also used the kit formation strips. Only problem was the 'decals' printed at wrong size so the are slighty to large.
Andrew
