Like your paint stand ,Randy. BTW Those tips look nice, glad I was of help.
Wasn't happy with the way the overlay on the kit prop blades was looking and just can't resist the five blade scimitar idea. Here's the latest WIP pics.
First cut out ten blanks from sheet plastic then marked them for direction and right or left. Something I'll need to keep close watch on with this process. Don't want to end up with 3 right and 6 left blades. Also to make sure they end up mounted on the correct sides.
Blanks are same length of kit blades and 5mm wide.
![](http://i460.photobucket.com/albums/qq327/H-Markel/Air%20Racer%20F-82/IMG_8549.jpg)
![](http://i460.photobucket.com/albums/qq327/H-Markel/Air%20Racer%20F-82/IMG_8550.jpg)
![](http://i460.photobucket.com/albums/qq327/H-Markel/Air%20Racer%20F-82/IMG_8551.jpg)
Glued stretched sprue mounting pins to center of each blank . Length is half of blank plus 5mm . May need to trim end of pin when it comes time to mount to spinners.
![](http://i460.photobucket.com/albums/qq327/H-Markel/Air%20Racer%20F-82/IMG_8560.jpg)
Made a couple twist jigs from steel strap . Marked blank length, clamped one end at mark in a vice, then with vice grip clamed at other end gave approx 60 degrees twist using a drafting angle as a guide. Repeted for the other side, just with an opposite twist.
Cut ten more blanks smae size as before and laminated top and bottom blanks together clamping them to the jigs as the glue dried for a few hours.
Last pic shows rough prop blades with the twist set in . I'll rough sand an airfoil shape to each blade. Then, using the Tachi drawings of Tsunami's scimitar blades as a pattern , I'll cut them to shape. Finally , I'll finish the airfoil shape, smooth and mount to spinners.
![](http://i460.photobucket.com/albums/qq327/H-Markel/Air%20Racer%20F-82/IMG_8561.jpg)
![](http://i460.photobucket.com/albums/qq327/H-Markel/Air%20Racer%20F-82/IMG_8562.jpg)
![](http://i460.photobucket.com/albums/qq327/H-Markel/Air%20Racer%20F-82/IMG_8580.jpg)
Progress on the oil cooler / radiator package. I want to see something realistic when I look in either end of the cooling system. I also plan on adding spray bars.
![](http://i460.photobucket.com/albums/qq327/H-Markel/Air%20Racer%20F-82/IMG_8586.jpg)
![](http://i460.photobucket.com/albums/qq327/H-Markel/Air%20Racer%20F-82/IMG_8587.jpg)
Starting to get on a roll with this build again. Got the props figured out, and the radiator with associated scoops pretty much figured out. Just got to cut, glue, fill, and paint stuff.
Getting started on Lil' Miss Magic but, I'll make seperate posts for that to better help me keep track of each.
Howard/ Daddy1 Racing
