Ok, photos as promised. So far the only filler ive used on this is thick paint. A few seams needed to be filed back. I had to cut the locator pics off because they were useless and ended up making it a bit wonky.
Flash washed this photo out a bit. sorry. Ill have to fill the forward hole in the fuselage because this is for the gun pod slung underneath but because im doing an aerobatic version ill be putting the centerline fuel tank on.
Hard to see. but its all black down there with drybrushed silver to pick out the high points.
In the process of making some seatbelts for it. seat was a little spartan so im just using some making tape to make some belts.
If you make this one bigger you can see the detail on the control panel. Just a bluey green drybrushed black to pick out the instruments.
This was the biggest gap. you can just see it at the front of the vertical fin.
Other big gap, sorry washed out again. was just along the base of the ventral fin. filled with white glue and tidied up.
So shes coming along rather quickly. i look at some of the pics and notice mistakes here and there. but itle be ok. Working on the fiddly bits now. so frustrating. Especially since everything is just not quite fitting flush. Hopefully i can get the main construction finished this weekend. But ive got a flat inspection on tuesday so things might go a bit slow for a few days.
Almost forgot this one. this shows the paint scheme ill be using.
Ill be using the markings for 76. But i was thinking of raiding some of my other kits to create a new Rego for it. Skyhaws were 62 (NZ6201 etc) Machis were 64 i think. so im thinking of using 78 (NZ7876) well see what happens
"I am a leaf on the wind, watch how i soar"
Recite the litanies, fire up the Gellar field, a poo storm is coming
Check out my blog here.
