Variable Geometry: the Swing Wing GB
    October 2008
Posted by eatthis on Sunday, March 6, 2011 2:30 PM
panel gap anybody????????
that hole was drilled from inside so i could glue the top and bottom half of the wing pivots better its rock solid now and iv filled the hole in
snow + 4wd + escessive hp = :)  http://www.youtube.com/watch?v=x7egUIS70YM
    March 2010
Posted by macattack80 on Sunday, March 6, 2011 3:09 PM
eatthis
http://i55.tinypic.com/6quu07.jpg
Just looking at that is giving me a headache!  Bang Head Ick!   Good luck!  Don't hesitate to ask any questions about building that.  We are here to help.
Kevin
    October 2008
Posted by eatthis on Sunday, March 6, 2011 3:59 PM
thanks alot mate tbh the engine nacelles annoyed me far more because i followed the instructions and glued 1 half to the body then the other half to that it left a bloody great gap all round that there was just noway of closing.
in hindsight i shouldve built the nacelles as a complete unit then fitted the whole thing to the plane grrrrrr
    October 2007
Posted by pordoi on Sunday, March 6, 2011 4:33 PM
eatthis
Oh, forgot to tell you that you'll also need alot of sanding sticks and putty.  Stick out tongue  I can't believe that anyone could do anything to prevent that gap.  Just look at how misaligned those panel lines are. Same on my build; I re-scribed some and just left others as they were.
Also, nice job with the wing pivots.  Wish I had  thought of that.  Bang Head  I'd still have swing wings if I did.  Sorry to hear about the nacelles.  Any chance you can cut them off?
Don
    October 2008
Posted by eatthis on Sunday, March 6, 2011 5:03 PM
iv done the same with the panel lines/alignment im just not good enough to make it very good so its tough lol
the pivot occured to me when i came to glue it together how do i glue the actual pivot together without it getting into the wings and siezing the wings? drill a bloody great hole through it so i can get to both sides of the pivot from outside ie after the body went together it worked a treat too 1 wing is easier to swing than tother but the pivot itself is rock solid
i tried to prize the nacelle halves off but theres no chance id snap the body before theyd give i put too much glue on them lol i think iv hidden the gap though
    March 2010
Posted by macattack80 on Sunday, March 6, 2011 5:41 PM
eatthis
No problem at all.
I believe that Don and I assembled the engine nacelles as subassemblies first.  It did make seam removal a bit easier.  I am sure that you can clean it up while they are attached.  It is probably just a bit more difficult.  The nacelles had fit problems all around.  It took a lot of sanding to get the forward piece to sit flush with the main nacelle sections.
The huge seams are not at the fault of the builder.  Don't think it is you.  The kit has many big fit problems.   Like Don said.  You need a lot of putty and sanding sticks.  A bottle of CA glue won't be bad either.
The big problems of this kit are pin marks and seams.  There are seams in every kit to clean up but these are more like trenches.  All the pin marks are on sides with the details.  The reverse side, that won't be seen, are nice and smooth.
Kevin
    March 2010
Posted by macattack80 on Monday, March 7, 2011 4:22 PM
The Eduard PE set for the Revell 1/48 F-14D arrived today.  WOOHOO!  It corrects the RIO's cockpit panel and add much needed detail to the engines and replaces dodads here and there too.
So with the True Details seats, Steel Beach ECM blister, and Eduard PE set I should be all set to get the party started.
Yes, the infection is spreading....aaaahhhhhhhhh!!!!!
Kevin
    October 2007
Posted by pordoi on Monday, March 7, 2011 6:19 PM
macattack80
OK, I've put on my bio-containment suit, grabbed a beer and a bowl of popcorn.  On with the show!!  Yes
Don
    March 2010
Posted by macattack80 on Monday, March 7, 2011 6:33 PM
pordoi
I will try and make it a good one.
Kevin
    March 2010
Posted by macattack80 on Wednesday, March 9, 2011 3:33 PM
The True Details seats arrived today!!!  YAY!  I planned on closing the canopy but the cockpit might look good enough to keep it open.
Kevin
    October 2007
Posted by pordoi on Thursday, March 10, 2011 7:00 AM
macattack80
OK, just had to respond as it is to 1000th post to this GB.  But that said, really looking forward to seeing this build.  I've liked the one or two things from true Details that I've worked with, so no surprise that you'll have fun with yours.
Don
    March 2010
Posted by macattack80 on Sunday, March 13, 2011 3:55 PM
I started work on the Tomcat.
As of now I have the weapons and wings assembled.  A little putty here and there to smooth out yet but not too bad of a fit.
I also started work on the kit parts to prepare them for the PE parts.  That means some sanding and cutting.  It's not a color PE set but it should paint up nice.  I will get some pics posted ASAP.
Kevin
    October 2007
Posted by pordoi on Monday, March 14, 2011 9:35 AM
macattack80
Sounds good, Kevin.  Post some pics; things have been kind of quiet around here lately.  Still have about 5 weeks to go, so there's still time for plenty of action.
Don
    March 2010
Posted by macattack80 on Wednesday, March 16, 2011 3:31 PM
I will attempt to get some interest going in the GB so here are some progress pics of where I am at so far in the F-14 build.  Keep in mind that I still have quite a bit of work left.  I haven't got much done.
Here is the cockpit tub with some of the PE parts attached
[View:/themes/fsm/utility/:550:0]
A different angle
The instrument panel ready for PE parts.  The detail has been removed as needed
The missles.  Good thing I wanted to have 2 AIM-7 Sparrow's on this bird.  They are molded onto the wing glove pylons!
The missles went together without  any trouble.
Kevin
    October 2007
Posted by pordoi on Thursday, March 17, 2011 9:06 AM
Any progress is good!  A couple of photos of your build may spur some others to give us updates.  We have I think three F-14s being built right now, so a side-by-side cpmparison would make for some interesting reading.
 guess that one could cut off the Aim-7 if necessary, but it does seem a bit silly to mold them on the pylons.  I also would have thought that your exterior PE set (did you get that one or just the cockpit?) would have added bits to the pylon, which might force you to remove the Sparrows.
Don
    October 2008
Posted by eatthis on Thursday, March 17, 2011 1:30 PM
4 tomcats im gonna do my revel 1/32 jobbie when im done with the phantom
    March 2010
Posted by macattack80 on Thursday, March 17, 2011 3:27 PM
pordoi
Don
I agree about the 3 Tomcat builds.  It's a good way to learn how others tackle the same issues.
The PE set has parts for the cockpit and exterior.  It has a few parts of the Sidewinder missle rails and the Pheonix missle pallets but nothing for the Sparrow launchers.  I hope I got the terminology right on those.
I will probably cut off the swing wing mechanism on the wings and cut a groove in the wing attachment area.  This way I can paint them seperately and get good coverage.
Kevin
    October 2009
Posted by Medicman71 on Friday, March 18, 2011 12:59 AM
macattack80
 pordoi:
Don
Funny, my Revell F-14A has the same molded on Sparrows as well. And one of the tails to the Sparrows is broken!!! That's gonna be fun. May have to cut it off. Hope to get back to my Tomcat soon. I did order the Fightertown Decals for VF-1. They came in on Wednesday and they look awsome. I'll try to post some pics of the decals tomorrow. Bout done with my recert and my second job is slowing down so i'll be back with it real soon.
Building- (All 1/48) F-14A Tomcat, F-16C Blk 30, He 129
    October 2008
Posted by eatthis on Friday, March 18, 2011 3:07 AM
i might let the cat out of the bag soon about what im doing
    October 2007
Posted by pordoi on Saturday, March 19, 2011 1:29 AM
OK, gentlemen.  The show is all yours.  Lets see what you've got, or can do in the final weeks of this GB.  I always liked a strong finish.
Don
    March 2010
Posted by macattack80 on Sunday, March 20, 2011 8:00 PM
eatthis
You building a model airplane or somethin'?  Big Smile
Kevin
    March 2010
Posted by macattack80 on Sunday, March 20, 2011 8:04 PM
pordoi
Is that the scotch talkin'?  Toast
I have be plugging away at the PE parts.  I hope to get some painting done in the next couple of days.
Kevin
    October 2007
Posted by pordoi on Monday, March 21, 2011 10:54 AM
macattack80
 pordoi:
You betcha!  Wink
And from experience, I know that scotch and PE don't go well together at all.  So beware...
Eatthis has done some unusual things on his builds.  I'm looking forward to seeing what's up.
Don
    October 2008
Posted by eatthis on Monday, March 21, 2011 11:28 AM
balls my secrets out already :(
    March 2010
Posted by macattack80 on Monday, March 21, 2011 3:24 PM
pordoi
You betcha!  Wink
Its even worse if you invite CA glue to the party.  Then you end up glueing you hand to the bottle of whisky.  You may as well drink the rest of it at that point....Whistling
pordoi
Ditto  He has already built some nice models.   If he builds the Bone in time it would have to be some kind of record I would imagine.
Kevin
    October 2008
Posted by eatthis on Monday, March 21, 2011 4:19 PM
the colour would give it away
ps dont assume its a single colour camo ;)
    October 2008
Posted by eatthis on Monday, March 21, 2011 4:21 PM
can i add a whiff f111 that a pulled apart and remade it in 1 night at the weekend?
    October 2007
Posted by pordoi on Monday, March 21, 2011 6:34 PM
macattack80
Been there;...  Done that!  Stick out tongue   I do remember that it was a bit difficult to comb my hair in the morning.  Lost a bit of skin trying to pry the bottle from my hands the next morning; at least I think I did.  I don't really remember....  Embarrassed
You just wait.  Eatthis will put a B-1B in the GB before you know it....   That will make 4 Bones.  Givin' the Tomcat guys a run for the money, eh??
Don
    October 2007
Posted by pordoi on Monday, March 21, 2011 6:43 PM
Nice job on the wing seam, Eatthis.  It is interesting how everyone has dealt with the size of this model.  Although I have to admit that pulleys and slings is unique.  Yes
No comment on the camo.  I'll wait to see what you come up with.  Although I did see a Flanker in the background...,  how about an aggressor Bone in Flanker 3-tone Blue/gray?
Don
    March 2010
Posted by macattack80 on Monday, March 21, 2011 7:23 PM
pordoi
Yes  Par for the course I suppose.
pordoi
It's great.  Four Revell 1/48 B-1B Lancer builds.  Never expected that when I signed up for the GB.  I figured there would be You and Me building the Bones and a bunch of Tomcats.  Nice that there has been so many different subjects so far.
Kevin
