Vetteman,
The wings look spot on my friend! Very well solved!
Doogs,
Oooooh...that barrel just looks gorgeous I must say it's one of the weaker parts of the trumpy... Plus the way overscaled grooves in it. Some say that the grooves shouldnt be there at all but i have seen a wartime pic of one that had, just much less pronounced.
And the tracks are equally as beautiful. I MUST bring myself to buy stuff like that..... Oob is nice and gives great results but the difference with these is just the thing to make it a contest winner. Sag looks very realistic!
Thunderbolt,
Coming along nicely i see! Cant wait to see what you do with the camo.... I take it you got the AB problem under control?
Been working on my panzer off and on last week but encountering problems along the way...
Just when i wanted to start camo spraying i found out that i glued on the bottom plate of the turret in a light angle causing the turret to not sit straight.... So i carefully cut the part off and reglued.....only to find out some glue oozed on the outside turret, wrecking the paint job
So i resprayed dunkelgelb and waited for it to cure. Being enamel i gave it half a week.
Just now i fired up the AB and started freehanding the green stripes according to a profile picture somebody pointed out to me in the armor section...
Now i find out i thinned too much and using too high a pressure setting making the camo look really runny and just plain awful......
Sooo...... back to sanding and re applying the gelb again... Next time i will use putty to mask my work! Anyways.... gonna take a bit longer
Richard
