Monogram Mafia Group Build
    July 2007
Posted by troublemaker66 on Tuesday, August 2, 2011 3:43 PM
Hans von Hammer
Anyone else I missed?
Yeah...my SBD...kit #3. Trying to get the Dragonfly done soon so I can get made twice...Big Smile
Len Pytlewski
    June 2008
Posted by Hans von Hammer on Wednesday, August 3, 2011 12:43 AM
Gotcha both, TM & Mkelley...
Just for the record, lemme know if I missed you back-channel, via PM....  I tend to gloss over some posts after I get home..
    January 2003
Posted by p38jl on Wednesday, August 3, 2011 2:56 PM
ok,, update on my 3rd.. F-15,, crossover from the Wild Win[View:/themes/fsm/utility/Photobucket:550:0]gs GB,,, cockpit done.. Fuselage together,,,[View:/themes/fsm/utility/Photobucket:550:0][View:/themes/fsm/utility/Photobucket:550:0][View:/themes/fsm/utility/Photobucket:550:0]
and a nasty seam underneath...[View:/themes/fsm/utility/Photobucket:550:0]
[Photobucket]
    November 2003
Posted by bobbaily on Wednesday, August 3, 2011 7:16 PM
Hey all.....I have officially started.  The P-51D has received a wash, the raised Revell-Monogram lettering has been filed off of the horizontal stabilizer.  Still never understood why they put it on the exposed surface rather than on interior of the fuselage....also, I filed off the molded on seat belts.  Thinking about experimenting with some foil from my contact lenses pack....backup plans include standard PE belts and I could always glue & paint the pilot as a last resort.  Hopefully I can have the interior bits painted and the fuselage assembled before the end of the weekend....at least that's the plan now.
I've been lurking while completing a build for another GB...you guys...and gal.... are doing great work.  Hope I can live up to the standards that are being set here.
EDIT-oops...Hans...I went back and read the fine print in your first post....I should have started on or before 31 March....err....yeah....I meant to say that I started on 31 March, but I forgot to post...yeah...that's the ticket....does that count?  I will (better) have both finished builds before the 30 September date....I promise....are those really violins in those cases?
Bob
    September 2006
Posted by the Baron on Thursday, August 4, 2011 12:15 PM
Hi, all!
Just to prove that I've actually done something, here are photos, up to the current state, for my Zero.
If you remember, my last update showed the pilot installed in his office, and I was ready to close up the fuselage.  That I did, and I attached the wings.  Then I applied an aluminum undercoat, in preparation for using the salt weathering technique:
Next, shots of the salt applied:
We've already had a vigorous discussion on the merits of the salt technique, and on technical details.  I can take or leave using salt to do the chipping, but if I use it again, I will mix the salt and water first, then apply it in small drops/blobs on the surface.  If you apply the water by itself, the surface tension of such small amounts causes it to form droplets that are too large, at least in 1/48, and probably in 1/72.  But if you mix a sludge of salt, you can control the application better.
Once I applied the salt, I masked the canopy, which is a task I don't relish too much.  But actually, it's getting easier.  Or rather, with this old kit, and the way the canopy is molded, it was relatively easy.  Here it is:
Then I attached the canopy.  I shot the model with some IJN dark green first, because I needed to get it on the turtledeck under the canopy:
I did have some seams to fill; the canopy doesn't fit too well on this kit (where's Gaston? He can write a tome about it):
You can also see where I removed some of the salt along the wing root.  It looked OK, but it was later covered over in the next phase, which was to apply IJN dark green and gray:
Here's an shot of the starboard wing, with more of the chipping:
Some of the salt came up pretty easily; in other spots, it adhered so well that it's hard to remove it.  I have some ideas of what I will do, once the final colors are on and touch-up is finished (yes, you can see, there are some areas where I have to fix some overspray, etc).
Here's a shot of the underside:
The kit has no cockpit floor, and I chose not to add one--trying to keep AMS at a minimum with this build.  So, you can see, I stuffed wet tissue paper into the wheel wells, to kit from spraying the cockpit.
You can also see the mistake I made.  Next step is to apply the yellow recognition markings to the wings.  Duh.  I should have applied the yellow first, then masked over and applied the other colors.  Now, I have to go back and mask far more area, to apply the yellow.  I could bag the markings, but I think I want to add them.
If this is a Mafia, I feel like Danny DeVito and Joe Piscopo in "Wise Guys"....
Posted by hutchdh on Thursday, August 4, 2011 6:08 PM
Hans von Hammer
Hans, I do believe you forgot to add my F-100D.  it is coming along nicely.  I am building it the same time as the Trumpeter F-100C.  The Mono holds its own and I got it for $5.00!!!
Hutch
 On the Bench: 1:48 HobbyBoss Ta152-C; 1:48 & 1:72 Hasegawa F-104G NATO Bavaria
In queue: 1:48 Academy F-4B & a TBD Eric Hartmann bird
Recently completed: 1:32 Trumpeter P-51B
    January 2010
Posted by CallSignOWL on Thursday, August 4, 2011 6:11 PM
Hans von Hammer
just a nit-picky thing, but you have my B-25 listed as 25%, but I finished it a while ago...
Now that I'm here, where am I??
Posted by hutchdh on Thursday, August 4, 2011 6:25 PM
hutchdh
 Hans von Hammer:
Thought I'd add a few pics.  I am experimenting with Krylon Metallizer Aluminum from the big rattle can.  While I got a nice smooth finish on the underbelly, the topside had a few flecks.  I like the initial shine I was looking for to be followed with some Alclad, but I don't think I will use the Krylon again in this capacity....
Hutch
    September 2006
Posted by the Baron on Friday, August 5, 2011 11:45 AM
Thanks for the proof-of-concept on the Krylon aluminum, Hutch!  I was thinking of trying it, too, though I'm thinking of it to replace the kit chroming on  the Red Baron hot rod.  I stripped the kit chrome off most of the parts, because there was no way to deal with seams and sprue gate marks on some of them, without losing the chrome, anyway.  Your work shows that it could be used with good effect.
    June 2008
Posted by Hans von Hammer on Friday, August 5, 2011 3:11 PM
Better late than never, Roberto...
However..
What's the Maximum Effective Range of an Excuse?Wink
    June 2008
Posted by Hans von Hammer on Friday, August 5, 2011 3:34 PM
AMS would have been drawing a floor to scale from plans found in a 1978 issue of "Aviation Week" then going throguh every AM P/E rack trying to find a matching part, then giving up because you used the wrong plans, which was pointed out in the Fall 1979  issue of "IPMS Quarterly" and using 125.00-worth of a different Jap bird's 'pit, then hunting down a resin seat, consols, stick, peddles etc.. and deciding to go "Old School Gizmologist" anyway, and just use styrene rod (stretched sprue), strip and sheet cut from an old garage sale sign...
As a Gizmologist, you do this:
 for 25 cents..
Yupper, my Zeke's on the way too.. Don't let those big ol' wheel cover pins scare ya... I cut 'em off a bit later, added some that were more to scale, and painted to look like bamboo (which is what they were made of, as well as the "Gear-down" indicator pins in the wings. Mitsubishi engineers cut weight EVERYWHERE)
I'm currently n the process of removing the molded-in engine facade and inserting the AT-6/SNJ mill in its place...  The Sakae engine was almost an exact copy of the T-6's Pratt & Whitney R-1340 -AN-1 Wasp radial powerplant, in the "Looks" department..
AHem..
Ain't gonna say "I told ya so", but I AM gonna give you th' look...Indifferent
    November 2003
Posted by bobbaily on Friday, August 5, 2011 3:39 PM
Hans von Hammer
However..
Hopefully further than the range of whatever is in that violin case.....
Bob
    June 2008
Posted by Hans von Hammer on Friday, August 5, 2011 3:40 PM
OK.. Front page updated.. Hopefully...
I'll add the models to the other hooch's Monogram Mafia post too, over the weekend.. Need to bring those babies back to page one...
And email the link to Gaston...
Posted by hutchdh on Friday, August 5, 2011 3:57 PM
the Baron
No problem...I've also tried the Krylong Metalized Silver...the Aluminum has a better, smoother, and richer tone with a lot of reflectivity.....The silver almost looks like it was colored with a crayon...good luck.
Hutch
    June 2008
Posted by Hans von Hammer on Friday, August 5, 2011 11:49 PM
I use Krylon too... Big can, little price...  Those five-and-a-half-buck, 3 oz cans are ridiculous, but they still trap me...  Krylon makes the about the best (brightest) silver, plus it sheds the paint for chipping beautifully...
Posted by hutchdh on Saturday, August 6, 2011 7:04 AM
Hans von Hammer
After using a 3200 grit pad and rubbing out some of the flecks, I re-applied another coat of the Krylon and it smoothed things out.  I will likely use this stuff again.  Like you say, it is a real bargain.
Hutch
Posted by hutchdh on Sunday, August 7, 2011 7:55 PM
Thought I would post a few pics of the Mono F-100D.  The Trum F-100D is on hold pending the release of some new decals from Caracal decals of the New Mexico ANG...I wanted these decals, so I could paint it in the rare light grey.
Back to the Mono build....the shiny areas are with the Krylon I referred to earlier..the other areas are Alclad, including the burnt metal areas...lots more work to do, but this ole bird is coming along nicely.
First pic is all taped off:
Masking removed:
Burnt metal area...two shots; one with and one without flash:
Hutch
    July 2008
Posted by vetteman42 on Monday, August 8, 2011 12:15 AM
Hutchdh nice work on the NMF man ! I like the way the mixed paintsd worked out for you, meaning the Krylon and Alclad. The burnt metal looks very convincing too.
My P-51D is back on the bench and finally has the silver base coat on it,, Tomorrow the NG and OD are going on her and pictures will follow then.
Randy So many to build.......So little time
    January 2003
Posted by p38jl on Monday, August 8, 2011 8:23 AM
Hutch,,, looking good man ! Yes
[Photobucket]
    July 2008
Posted by vetteman42 on Tuesday, August 9, 2011 1:10 PM
Gotta get moving on this build as I am only a half made man Surprise I have some WIP pictures to share with ya all. First off I applied a silver base coat and added some rubber cement for paint chipping. Then I preshaded with Tamiya OD, which as some my know is quite dark. I also shaded leading edges and low on the fuse where the paint wouldn't fade much.
http://i712.photobucket.com/albums/ww122/randysmodels/Arval%20Roberson%20P-51B/Arval%20Roberson%20P-51D/12RevellP-51D.jpg
Then I mixed flat white with the OD for a medium dark and painted the panel centers, well mostly the centers anyways.
http://i712.photobucket.com/albums/ww122/randysmodels/Arval%20Roberson%20P-51B/Arval%20Roberson%20P-51D/13RevellP-51D.jpg
Then I added more white for a very faded OD and and thinned it 80% distilled water 20% paint then fogged it on to bring things together. Here's where it is at now.
http://i712.photobucket.com/albums/ww122/randysmodels/Arval%20Roberson%20P-51B/Arval%20Roberson%20P-51D/14RevellP-51D.jpg
http://i712.photobucket.com/albums/ww122/randysmodels/Arval%20Roberson%20P-51B/Arval%20Roberson%20P-51D/15RevellP-51D.jpg
I will rub the rubber cement off today and play with it bit before clear coating it for decals and further weathering.
    June 2008
Posted by Hans von Hammer on Tuesday, August 9, 2011 6:42 PM
That burnt-metal look is outstanding...
Pony's looking sweet do far...
    November 2003
Posted by bobbaily on Saturday, August 13, 2011 6:17 AM
Nice work Randy & Hutch.  Love the 'heat effect' on your plane Hutch.  And I'm looking forward to seeing more progress on your P-51 Randy-I still haven't decided on an O.D. or Silver finish for my P-51....speaking of which, here are some progress pics-got the interior together last night....hope to have the fuselage together, wings on and primed by the end of the day....depending on household 'to-dos)....
A little bit of wire run thru the cockpit and on the radio/battery would add, but I didn't want to take the time....
Cheers
Bob
Posted by hutchdh on Saturday, August 13, 2011 7:36 AM
Thanks for the nice comments.  I applied the Zinc Chromate Green to the wheel wells.  As you can see, the paint lifted in some spots on the belly when I removed the masking.  My fault in that I painted the Alclad straight over the Krylon and I don't think it liked it.
I applied some Tamiya Smoke to accentuate the panel lines, last night.  A few minutes ago, I slapped on some Future in preps for the decals.
Also,  my Trump F-100C is coming along nicely as well.
Hutch
    July 2008
Posted by vetteman42 on Tuesday, August 16, 2011 4:24 PM
Bobbaily nice start on the 51 man ! I really like your IP YesYes
Hutchdh I am gonna have to remember the smoke trick, it did bring out the panel lines very well
Ok so we are on page 2 now ??? That aint no good at all, and just wont do, so a WIP picture to get us back where this group should be Stick out tongue
I have the decals on and have done the first round of weathering, faded those bright decals. Looks much better now I think, anyway I will clear it again this evening and start the final weathering maybe tomorrow morning.
I can only hope Don Hammer will approve of my humble contribution to the family.
    January 2011
Posted by Tal Afar Dave on Tuesday, August 16, 2011 6:22 PM
Hey Vetteman, "Passion Wagon" looks great!!  Can't wait to see it all finished up.
 The F100 is also looking the part of a century fighter; love the variation on the different panels using the different paints. The heated exhaust area is also very convincing.....
Everyone's work is truly inspirational; I always look forward to checking the group's board; always something cool happening.
2022 New Year's Resolution:  Enter 1 group build and COMPLETE a build this year!!  Why Photobucket did you rob me of my one Group Build Badge???  Must be part of the strong anti-Monogram cartel!!!
    November 2003
Posted by bobbaily on Thursday, August 18, 2011 6:50 PM
Thanks Vetteman.
Fuselage is together, wings attached, primed & painted.  Fit was very good....however, I didn't do a very good job on the minimal filing & sanding that I had to do....and the silver makes it look worse.  The O.D cowl panel is a bit off but the 357th 'checkerboard' at the front of the engine cowling should hide my mistake. With a little time, patience & skill (I'm short on all of these) this kit can be a winner.
Anyway, here's the current status:
Future should go on tomorrow, decals on Saturday, more Future on Sunday and then the weathering begins.
Bob
    July 2008
Posted by vetteman42 on Friday, August 19, 2011 12:29 AM
Thanks Tal Afar Dave
Bobbaily oh I didnt know your 51 was gonna spot a NMF. Looking very good man YesYes Keep the pics coming Eats.
Passion Wagon II is finished ! Bout time huh Stick out tongue
Passion Wagon I was a P-51B flown by Lt Arval Roberson, after 3 kills he apparently had a landing accident and was assigned a P-51D also called Passion Wagon in which he became an ace with a total of 6 kills to his credit. After Lt. Roberson completed his tour, Passion Wagon was assigned to Capt. Charles Weaver. Capt Weaver became an ace in Passion Wagon, he changed the nose art but kept the name of Passion Wagon, although the name on the nose was dropped. After his tour was finished Passion Wagon went to the 357th from the 362nd and the name was changed to Gypsy. I am still looking for pictures of Gypsy.
Anyway I hope my build will be acceptable and allow me to be taken into the family so I can proudly wear the badge of " The Monogram Mafia "
Now for a little fun
Here's a B/W picture of the P-51B and P-51D Passion Wagon. The B is Revell's newly tooled version, sorry guys but thought they look kinda cool together.
Ok I know, I know, I hope this next one will make it up to ya. Two Monogram kits.
Angel's Playmate and Passion Wagon.
    November 2003
Posted by bobbaily on Friday, August 19, 2011 5:39 AM
Very nice build Vetteman-I love the weathering.  I need to build an OD Mustang one of these days.
Very well done. Yes
Bob
    September 2006
Posted by the Baron on Friday, August 19, 2011 11:51 AM
Awesome ponies, Vetteman, well done!
    February 2011
Posted by Reasoned on Friday, August 19, 2011 12:16 PM
I REALLY like those Stangs VettBeer.  Great work guys, you talented builders can turn the oft-scoffed at Monogram kits into beauties.
Science is the pursiut of knowledge, faith is the pursuit of wisdom.  Peace be with you.
On the Tarmac: 1/48 Revell P-38
In the Hanger: A bunch of kits
