One Year War GB 2011-2012 !Extended time! 30sept 2012
    November 2006
Posted by dupes on Friday, May 6, 2011 10:26 AM
archangel571
If you can't wait, and the fact that you use netflix means you have high speed internet, go crazy on this youtube channel, http://www.youtube.com/watch?v=6PvGJTPtiZI
Unfortunately, all I have (and can get) at home is tethering to my phone - so no movie downloads for me. Stuck with the actual physical discs. And, like I said earlier, it looks like someone lost/broke/stole the first disc in the 08th MS Team series, so I'm kind of out of luck there unless I can find it locally.
Maybe I'll start in with the Gundam movies? They should summarize the first series fairly well, I take it?
    April 2008
Posted by smeagol the vile on Friday, May 6, 2011 11:31 AM
yea, the three gundam movies do a good job of summarizing it
    March 2004
Posted by knabria on Friday, May 6, 2011 6:17 PM
Ms Igloo isn't a bad entry point into the Gundam UC universe. It briefly shows the start of Operation British and takes you through a few key points in the One Year War from a Zeon viewpoint.
    October 2008
Posted by bsyamato on Friday, May 6, 2011 7:52 PM
mmm the gb take a look as gundam enciclopedia..
a gogg good thing to remind for modding is that in gundam universe radars does not exist, because  particle emitted by minovsky reactors make it unusefull, then the only way to find enemy veichles are ir sensors , sonars and just a good eye Cool
then a gogg good update
actually i don't have computers down on the farm for references consulting , without it i cannot continue my others works , so more time to work on the giant brown anphibious
prepare to heatforming clear visor for the monoeye , a mold usually i use the same piece in the kit that represents it. I use a lighter or a candle to heat the clear piece
Photobucket
first try was a fail
Photobucket
but second not !
Photobucket
without removing from the mold i cut it using the same as guide
Photobucket
and final result with natural smoke effect Cool
Photobucket
Photobucket
changing zone
after glued the hip ,some groove apear in (this was one of first ,11 years old molds, hguc and not perfect like newest)
Photobucket
started to meltdown some piece of plastic  with tamiya glue and forced in
i'll return after on with putty
chest glued (removed original inner pins to make easier paint stage
to do good mods good tools are needed
and so, start to cut somethig
plastic of this hguc are a little too strong, and some thing even go wrong
Ick! ... then the hole for the under head is done, i'll refine it after scratched the well for the under of head .
removing the pins for the retracted arms option (on the mg version the arms can really retracted!) for underwater cruising, i will posing the gogg out of water
on the underlegs some other improvements
digging in dept the existing lines , i'll try to do more perpective to the lines
and added others panel lines on the pieces
that's all for this night!
    January 2010
Posted by Klik on Friday, May 6, 2011 8:54 PM
Managed to pry myself from my homework long enough to snap a couple pics of current progress:
Sorry about the blurriness. As I said, I only had a few minutes to snap some pics. The Color scheme is grey on blue, matched to the original tones of the plastic sprues. Just painting the bloody parts took nearly two weeks.
Notice the distinct lack of leg tubes? I broke one of the springs provided for the leg tubes during assembly. My bad. It's a 'custom' suit anyway, so I guess it doesn't really matter, until I figure out a way to overcome the problem (piece of shoelace, maybe?).
Keep up the outstanding work, all.
oneyearwar1
The hardest part of flying isn't flying...it's landing.
    April 2008
Posted by smeagol the vile on Friday, May 6, 2011 10:03 PM
I, like always, am working on about 12 different projects at one time, none of which I will finish, well, hopefully Ill finish this one, heh.  So I havent gotten that much work done on it, The turret is built, just have to paint it then do the body.
What our good friend Bsyamato was trying to say about the history is that in the gundam universe a professor Minovsky discovered a particle that interferes with sensors such as long range radar.  The battleships would use this to mask their location on a battlefield.  It was sort of like a smoke grenade, honestly, if the particles were around you knew there were enemies around, but you could not see them.  Eventually they were used to also cover the launch of a ship's mobile suits though this made the mobile suit pilots have to rely on their eye sight.  Because of this a lot of suits after the one year war had cockpits that were not like standard cockpits, but round with a virtual screen that covered the entire inside of the cockpit, letting them see everything around them as if their suit was not there.
These particles were not as effective on the ground for the EFGF started using sonar trucks.  They were large trucks that looked much like APCs, with a 50 caliber anti air machine gun on the top and a large spike on the side.  The spike would extend and plant itself into the ground and the sound man would listen to the sonar pattern.  They were trained to distinguish the sound patterns of the different mobile suits, zeon and federation, inorder to rely intel to their HQ and to their squads.  These trucks were often assigned to a mobile suit squad.
    April 2008
Posted by smeagol the vile on Saturday, May 7, 2011 12:49 AM
Hey dupes, just a quick comment.  When watching the series, especially the ones based around this group build's timeline, if you find yourself agreeing with the 'bad guys' it is NOT uncommon.
    October 2008
Posted by bsyamato on Saturday, May 7, 2011 6:25 AM
smeagol the vile
thanx smeagol Bow Down
you mean truck like this?
Sad the project is still freezed on the box
    October 2008
Posted by bsyamato on Saturday, May 7, 2011 6:29 AM
Klik
no breaks on my zaku fz but i replaced original tubes with auto am supplies and juice straw
    November 2006
Posted by dupes on Saturday, May 7, 2011 10:07 AM
Wow, you guys are flying! Unfortunately, Netflix is also missing the first Gundam Movie (but of course they have #2 and #3!). Going to have to try to find some locally (or maybe Amazon?). ALSO spent quite a bit of time checking out the Gundam World Cup link provided by Smeagol - wow, there are some SUPER builds in there. Going to continue to peruse!
    February 2011
Posted by GreySnake on Saturday, May 7, 2011 11:05 AM
Dupes here's the first movie off Amazon http://www.amazon.com/Mobile-Suit-Gundam-Movie-I/dp/B0000648WM/ref=sr_1_2?s=dvd&ie=UTF8&qid=1304784217&sr=1-2 You can get it used for around $2.55 or so not including shipping.
    April 2008
Posted by smeagol the vile on Saturday, May 7, 2011 3:35 PM
http://tv.blinkx.com/show/mobile-suit-gundam/b652OZEksuysxVbY
http://www.animefuel.com/index.php?s=gundam&ss.x=0&ss.y=0
http://animeseed.com/index.php/site-content/anime-pages/mobile-suit-gundam-the-08th-ms-team/?p=979
I havent checked them out myself, but there is the First Gundam, a bunch of Random ones, and then 08th Ms Team, to watch streaming online
    November 2006
Posted by dupes on Saturday, May 7, 2011 4:11 PM
Egads - that used department at Amazon is going to get me into trouble! So far I'm looking at: Mobile Suit Gundam: The 08th MS Team - Anime Legends Complete Set ~$24 Mobile Suit Gundam - The Movie Trilogy ~$25 Should be a good start, no?
    October 2008
Posted by bsyamato on Saturday, May 7, 2011 4:26 PM
Indifferent a massive start
    June 2005
Posted by archangel571 on Saturday, May 7, 2011 4:29 PM
dupes
Definitely a great dive into Gundams.  I sense a lot of watching and a lot less building coming up for you though.  There were a few gundam kits videos in the series of Fuji TV model building tv shows on youtube uploaded by a user sleepyfish or something, all in Japanese but the videos is inspiring enough.
-=Ryan=- Too many kits... so little free time. MadDocWorks
    April 2008
Posted by smeagol the vile on Saturday, May 7, 2011 11:11 PM
That is a great place to start.
    October 2008
Posted by bsyamato on Sunday, May 8, 2011 6:55 AM
Indifferent Finding some resource pics for detailing my gogg with goggle images, ii was surprised that between the first pictures pop up two pics of my finished hy-gogg... but a bigger surprise when discovered that someone used one of my pictures without spak to me
http://www.toyzhunt.com/toy-category/model-kits/robot-kits/1144-hguc-hy-gogg
the strange things of www Cowboy
    April 2008
Posted by smeagol the vile on Sunday, May 8, 2011 1:48 PM
bsyamato
Some people are ***** and will do that, use your stuff as their own, I have had it happen before.  Justput a watermark on the picture or something.
EDIT: sorry bout that, used to posting on another forum (non modeling) that instantly changes curses to little hearts)
    February 2011
Posted by GreySnake on Sunday, May 8, 2011 2:07 PM
smeagol you might want to edit your post a little.
    October 2008
Posted by bsyamato on Sunday, May 8, 2011 2:29 PM
smeagol the vile
Some people are cunts and will do that, use your stuff as their own, I have had it happen before.  Justput a watermark on the picture or something.
is not a problem, the important is to someone not gives my hy-gogg as own work Smile
then.. goggdates!!
to seal two seams with a shot i added some details here
added other lines on hip
gently i digged the hip thrusters with a screwdriver Whistling
and a speed snapping to see overall situation
also i glued with proper pinsall the arms pieces .
that's all for mow
    November 2006
Posted by dupes on Sunday, May 8, 2011 2:53 PM
Bsyamato - trying to get a sense of how the different grades of kits build up - what is yours? High?
    November 2006
Posted by dupes on Sunday, May 8, 2011 4:09 PM
Alrighty...hope to have some Gundam goodness show up at the house by next weekend. Got the following on Ebay, both new:
Mobile Suit Gundam Trilogy: Anime Legends DVD
Mobile Suit Gundam : The 08th MS Team DVD
I was always a big Battletech fan (WISH someone made some decent 'mech kits), so this should be a good time! Can't wait!
    October 2008
Posted by bsyamato on Sunday, May 8, 2011 4:29 PM
i'll try to explain.
this gogg is one of first hguc, (uc = universal century) a step up the old hg, this is one of the more simply between this series , have not inner details as mg or pg (the skeleton inside like the blue MG gouf i show before) . Actually not represent the hguc  standard, it was one of first attempt to improve old hg.
all joints in this series are covered ,resulting more realistic but, as you can see lots of works needed to make it more realistic. On latest exit of this series have some kit that instead have some great more details like the giant zock of my actual avatar, acguy and some other have great enhanced posability.
the hguc zock (one of the largest hguc) with all under parts detailed visible
and the acguy too have under details, only the body is without
Pay attention that i added panel lines on both kits , as original they comes without it.
and here a confrontation with the same subject, rx-79g,  one like your hg and the other the new hguc,
even if the picture is blurry you can see that as example , the feet, the older kit resolve with 3 pieces and the
joint in soft plastic, the newest have 6 pieces and the soft joint and the toe is movable , plus the up ankle armor is movable , and in the older are moulded with the ankle.
the elbow on older have an only rotation point , the new have two point, better hands , better weapons etc
hope this usefull and not mess you Tongue Tied
To add on series to see youcan try even the 0080 pocket war; on there have some crude scenes (are not walt disney cartoons), but look at the war with the eyes of a child that as fan of mechs , see suddenly involved his city in a battle between giants, that causes even civil casualties, there  have (imho) most of beautyfull mechs never seen on a  show Crying
    April 2008
Posted by smeagol the vile on Sunday, May 8, 2011 6:53 PM
The UC part of HGUC is subjective now.  There putting out Gundam Seed, Gundam Wing, Gundam X, kits with tags for the universe they come from, like... HGCE, HGAC, HGAW (cosmic era, after colony, after war)
    October 2008
Posted by bsyamato on Monday, May 9, 2011 5:56 AM
you're a graduate on gundam universe!!!! Yes Beer
    September 2010
Posted by potchip on Monday, May 9, 2011 7:19 AM
Wow, just realized I have Zock in the stash.. Maybe it's time to build it..the box takes up too much space.
    October 2008
Posted by bsyamato on Monday, May 9, 2011 7:30 AM
potchip
great!
i sign you in the  gb
Off Topic
investigation with a friend about the robbery of my hy-gogg picture Lightning tryng to contact grissom!
    May 2011
Posted by Real G on Monday, May 9, 2011 6:35 PM
Hello all!
I have been a lurker at FSM for some time, but the Gundam One Year War group build has enticed me to join in on the fun!  As my avatar implies, I am a Zaku fan.  The old 1/100 Char's Zaku was the first MS kit I built way back in 1983.  Gundam kits sure have come a long way since then!  See here for construction details of my more recently built HGUC Zaku:
http://www.ipmshawaii.freewebsitehosting.com/build_up_neal_izumi_hguc_zaku_1_1-144scale_bandai.html
Anyhow, I would like to enter the GB with the 1/100 MG Zaku Cannon:
http://www.ipmshawaii.freewebsitehosting.com/review_neal_izumi_zaku_cannon_1-100ccale_bandai.html
I have been wanting to builld the thing since I bought it, so hopefully this will provide the impetus (translated: kick in the rear end) that I need.  I will post photos when I figure out how to work my Flickr account.  (I am new to that too.  Sorry, still living in the Dark Ages.)
I am also trying to get some of my buddies to join in, so hopefully the GB will see a few more new faces.
Neal "Real Gundam"
“Ya ya ya, unicorn papoi!”
    September 2010
Posted by potchip on Monday, May 9, 2011 6:47 PM
Does it has to be 'accurate'? I'm planning to build a faberge easter egg themed Zock, for lulz and because it looks like an egg!
    October 2008
Posted by bsyamato on Monday, May 9, 2011 6:52 PM
Great finished zaku Real G ! i like it
And i can't wait to see the great zaku cannon finished, read lots of review on it but actually out of my budget Tongue Tied
I'll sign you in with it as v2.0 version (another zaku v2.0 derivates kit)
Which type of flickr account you have? if are the free account is very limited, you can try also photobucket.
To share here pictures from flickr, just go on the picture you need and on upper left have icons as email faceboock ,twitter, after this have an under arrow, just click on it and copy the code that pop up,HTML/BBCode, and past here with the "insert media" button , on the post message editor Smile
others can be more clear that me Tongue Tied
