Search and Rescue Group Build 2011
    October 2008
Posted by bsyamato on Friday, January 27, 2012 9:10 AM
Don't worry abour Rotorhead Yes Just update the rooster when yuo have the opportunity Cool
Again best wishes for the new come Toast
too few updats about seabat, i planned bad this project and comes really slow even withouth significant mods on
Main colors on
the yellow stripe on and started to paint gears and minor pieces. Also cleared some paint mistake on clear parts with a toothpick
Corrected also the paint on the nose... i extended too much the red area Whistling
    October 2008
Posted by bsyamato on Tuesday, January 31, 2012 7:22 PM
First clear layer on, after a strike of weathering shading
    October 2008
Posted by bsyamato on Friday, February 3, 2012 5:21 PM
more seabat updates
decals on , the sheet was poor but great quality
and panel lines washing, again to fix some other line
gears already painted, now remains rotors
    September 2007
Posted by SuppressionFire on Friday, February 3, 2012 7:22 PM
bsyamato,
Difficult colors to pull off well, your helicopter is looking great!
The bottom photo looks a shade lighter than the rest, is this the lighting or a step you took in the painting process? Regardless the highlights and panel definition looks perfect.
http://i6.photobucket.com/albums/y211/razordws/GB%20Badges/WMIIIGBsmall.jpg
    September 2003
Posted by Helo H-34 on Friday, February 3, 2012 9:17 PM
Excellent progress Bsyamato Yes
The red , yellow and gray colors have come out quite well . Nice job also on getting those nose numbers to contour around the nose engine doors , I struggled with a single number 3 on an early U.S. Navy SeaBat I built a while back , so I know how difficult it can be .
As for me , sadly not much progress on the Crazy Legs builds other than glueing the fuselage halves together ;
Hopfully I can some more done this weekend .
John .
    October 2008
Posted by bsyamato on Saturday, February 4, 2012 9:33 AM
Thanx guys for comments Bow Down
Suppressionfire about colors no change was made between top page and last pictures, i only weatherend the grey (better i darkened the panel lines borders with drybrush) ,differences was made by different camerea manual setting.
Helo the nose number effectively was a nightmare, i did 3 or 4 attempt, used really hot water to dip and on last i attempt I risked spoiling the decals turnred too soft and elastic ,then with hands and the cutter removed totally and re-dip in the water, 2 layer of microsol perfected the adhesion.
The red looks so good because under i used 3 or 4 white layers Indifferent these colors like yellow ,white and red are even a pain to paint.
waiting for more updates here
the two pellican (italian name of the hh-3) looks very domesticated from the raw kits they comes YesYes
    October 2008
Posted by bsyamato on Saturday, February 4, 2012 5:10 PM
final laps
fixed the broken main rotor (newbee mistake i performed Embarrassed )
painting rotors and matt layer on the copter
tomorrow will finally glue the gear and minor parts
    October 2008
Posted by bsyamato on Monday, February 6, 2012 9:14 AM
some update
Then... i lost the finished blades control disc of main rotor Bang Head unexpected scratchbuild needed
tail rotor will also receive metal rods to replace original parts.
painting some missed detail from italeri as external tubes with brass rods and the tail light scratched from clear sprue
Hope not need to replace other parts Tongue Tied
    October 2008
Posted by bsyamato on Tuesday, February 7, 2012 9:58 AM
more updates here
compass cutter work
first fitting test
and the two rotors fixed!
just waiting the CA glue dry and refine after
Metal rods painted and fixed on fuselage
this is the bottom pieces from the kit someone knows where's the correct position to glue it? i found few and not clear picurer of this helicopter for a correct fix
just to show seabat with rotors Big Smile
few pieces left to finish
    January 2003
Posted by p38jl on Tuesday, February 7, 2012 10:03 AM
thats looking better and better all the time ! Yes
[Photobucket]
    September 2007
Posted by SuppressionFire on Tuesday, February 7, 2012 8:30 PM
bsyamato,
compass cutter work`...
Agg! I remember the days before I purchased a punch set. Turning styrene in a drill for round bits and toiling with sanding sticks.
Trust me once you use a punch set you will never manually cut a round disc again!
One of the best modeling tool investments I made for $30.
Anyhow the rotors are looking great! Sometimes its the journey that is half the fun.
*My affliction scratch building puts the journey at 90% of the fun!Bang Head
    October 2008
Posted by bsyamato on Wednesday, February 8, 2012 3:42 AM
thanx Chris Toast
Suppression in this case the compass was better because needed the center of the disc , a punch see is also needed for litter discs but the two tools are complementary.
Punch set and the rivet (counter Whistling) maker are two tools i'm considering to buy soon.
I'm surfing on web about the under details missing (antennas radar sensors and others things on the italian seabat but really few pictures are around Surprise
    October 2008
Posted by bsyamato on Friday, February 10, 2012 6:40 PM
so... more updates and more wall head hitting Bang Head this afternoon painted and added other details included the rescue hook. This night returned on the workbench after billiards session i picked the seabat and the hook was not here where i glued it! the only scientific explain is an alien abduction Alien so tomorrow another scratched piece is needed Angry
then pictures with wheels , rescue hook lifter and other details painted
At the end glued also the bottom tubes. Some italian seabat shows more details added on the fuselage but not found clear pictures to perfect complete these pieces, so i leave the copter withouth for the moment.
I hope this weekend to finish the good copter Cool
I feel like want a third version in future of the 58 kits Stick out tongue
    September 2003
Posted by Helo H-34 on Friday, February 10, 2012 9:02 PM
bsyamato your Seabat is really coming along well now .
Excellent work fixing the rotors and overall she is looking great .
It's no big deal but Italeri have the tail rotors going in the wrong direction ; I've never worried about it in the past when I built my H-34's , however a modeller over in the helicopter forum section back in 2010 built an awesome Vietnam H-34 and he explained that instead of cutting the four tail rotor blades and turning them over to face the other way an easier method is to just cut the pin off one side of the tail rotors and do the same with the small raised piece on the other side and swap them around . This is much better than cutting off the individual tail rotor blades and struggling to get them glued back into position facing the other way . Cutting the pin is definitly easier .
Embarrassingly I started a whole fleet of H-34 and Wessex builds but the whole project has stalled , I finished  7 kits and have another 20 builds glued toghether with  about  24 H-34 and Wessex kits in the stash with a ton of after market decals , resin and PE . Perhaps sometime this year I can finish off the 20 builds I have already started .
Any great on-going work on your Seabat my friend Yes
John .
    October 2008
Posted by bsyamato on Saturday, February 11, 2012 6:03 AM
Thanx for comments Helo Toast
After posted last picture i remember that Paul boyer posted an h-34 and he replied me about the wrong tail rotor on italeri's h-34 Lightning too late.
The solution to reverse the whole rotor is good but not resolving the control shafts points, they are in correct way Sad
Probably for now i leave it so. If will found the necessary references for the others missing details will fix it too.
I see your great collection when searched references for my hu-5 Yes theres lots of great subject between ,really liked all . Will check on helicopter section for updates !
    September 2007
Posted by SuppressionFire on Saturday, February 11, 2012 8:32 AM
bsyamato,
Looking good into the tail stretch.
I am sure the missing part will appear after toiling for hours scratch building a replacement. Its how Murphy's law applys to model building.
I hope to post some progress WIP's this weekend.
    October 2008
Posted by bsyamato on Sunday, February 12, 2012 9:34 AM
Big Smile LOL i think the same ! not first time, waiting for norse updetes !
I can call the Seabat finished for now, will add later some more pictures with the wessex hu5 and... when the buran and blizzard from the east will leave Italy will take some honest outdoor pictures LightningLightning actually two weeks without sun and the only weather avaible are cloud with wind or rain, or both mixed with lightings Super Angry
as i see after take pictures the right whell need some more retouch Whistling
I'm not sure but will try to get some yellow one copter to add here between some month .. probably a sea king Surprise
    September 2007
Posted by SuppressionFire on Sunday, February 12, 2012 8:01 PM
CF-SAM Updates:
Making progress in the interior. The triangle braces will have one more larger tube installed after the interior is sprayed with Krylon Almond. The braces are to be brush painted black.
The dash is coming along as with the cabin floor. Here you see it stained with some aluminum on the floor as per reference photographs.
Made a replica of the interior cargo door to simulate the corrugated aluminum interior door skin. Will use tin foil or lead.
Paint at last! Just the completed engine in Testors enamel spray can. Will detail paint then Future coat before a enamel semi gloss black wash.
    October 2008
Posted by bsyamato on Monday, February 13, 2012 10:23 AM
Great updates Suppression Toast like this mix of media including wood !
The engine is the scratched one?
Good things ,this afternoon some hour of sun allow to snap some good pictures, here the sesabat with some hu5 support
some more here withouth filling the post too much
Finished Seabat
    September 2007
Posted by SuppressionFire on Monday, February 13, 2012 11:20 AM
bsyamato,
Excellent photographs and helicopters, models always look best in natural light.
Photo with the clouds into the sun looks real, just the cement ledge tips off they are models.
Thanks for checking out the progress!
The engine is based on the kit. All detail (or lack there of) was carved / filed off. I don't have a exact count yet its close to 50 multimedia parts added to the engine. A few times more than the entire kit!
    September 2003
Posted by Helo H-34 on Monday, February 13, 2012 3:12 PM
Excellent finish pic's of your Seabat , bsyamato and I really like the HU-5 Wessex as well ...Toast
Suppressionfire , absolutly awesome WIP pic's . The work on the fuselage interior is amazing along with the scratch built engine , outstanding work Sir...Bow Down
John .
    October 2008
Posted by bsyamato on Tuesday, February 14, 2012 5:04 AM
Thanx for comments guys Bow Down on last pictures the wind starter to rotate the seabat rotor (not fixed), a sense of fear pervaded me Tongue Tied
Now i'm counting about nine helicopter (and one building for airfix group ,the ancient scout kit) ,time to get a "family picture ... just to see the impression fro the larger (mh-53E) to the litter (ka-18) LOL
SuppressionFire
bsyamato,
.. just the cement ledge tips off they are models.
this is about my "i will do a moveble piece of diorama to show my finished models" but never do for some reason (mostly because when finish a model i procede to the next/s) aargh!!
Great on the about 50 added pieces to the engine Toast
    October 2008
Posted by bsyamato on Thursday, February 16, 2012 5:21 AM
SuppressionFire
bsyamato,
Hmm rule confirmed!!! the rotor control appeared in the box used box for seabat pieces Bang Head the only place i not search ,now rescued (lol) and placed in the spare box pieces . Murphy wins
    September 2007
Posted by SuppressionFire on Thursday, February 16, 2012 10:52 AM
I can relate to extensive searches for MIA parts only to find then the one place I did not look!
The wooden stick used as a handle for a 1/144 scale Me 262 broke as I was spraying it (outdoors with a rattle can) The plane dropped (flew) about 8 feet into the snow, noticed the tail rudder was gone! Searched the snow for 20 minutes and when back at the bench it was sitting there! Guess it fell off before the paint session?Hmm
    October 2008
Posted by bsyamato on Friday, February 17, 2012 10:51 AM
LOL Big Smile
Then the rule is this
-The piece you lost will appear only when you don't need it more, and in all cases only when all areas where he is not was carefully sifted! -
Yes
    February 2011
Posted by RotorHead10 on Tuesday, February 21, 2012 9:47 AM
+1 true. My tail rotor pitch change beam didnt show up on my Hobbyboss Jayhawk until completion....bsyamato great looking Seabat! Once I am done building my son's 1/72 B-1B...I am going ti start Academys1/35 UH-60 in a medevac role.
http://i301.photobucket.com/albums/nn48/MikeTheModeller/GB_Badges/Phantom2011_1.jpg
    October 2008
Posted by bsyamato on Tuesday, February 21, 2012 10:21 AM
1/35!!! Indifferent
    February 2011
Posted by RotorHead10 on Tuesday, February 21, 2012 11:32 AM
Yep. Just like my old ball coach used to say....go big or go home!
    September 2007
Posted by SuppressionFire on Thursday, February 23, 2012 5:05 PM
Well its been a while and I am happy to say  made a bit of progress!
Painted the radial engine in enamel. The push rods flat black. The center a mix of Russian interior blue, blue and flat black. Never had a copper color so I mixed gold with a dab of red & brown.
The center was repainted after some surface flaws were removed. Wanting a enamel wash to 'pop' some details I coated the engine in Future after painting was complete. Just the wash is left after the Future cures a few days.
The interior is progressing as well! Scratch built the pilots gauges, added detail to the control stick and drilled holes in the roof for a light & vents. Also scratch built a cargo lift bar above the open door. Once a few more details are worked out the interior will be sprayed Krylon flat almond.
    October 2008
Posted by bsyamato on Friday, February 24, 2012 4:33 AM
Cool looking engine!! waiting tor the interiors.
