Thanx guys , Reasoned i need a 1/72 Val!! waiting for your 48 progress
yes so was the mask don't work propertly, opted to seal decals with matt coat and after i placed some gloss clear drop on intruments, here the results. I tried to get better picture to show the difference on the surface but was hard to succeed
then starting to mummify the zero
and orizontal rundders and top with mtg glued too. The top give some difficult to place, wrong enginereed piece; to fix i needed to remove the pins in front the windshield and also needed to force the piece in !!
The fuselage instead glued almost perfect
I forget to talk about guys , but on the airfix kit there's another wrong thing!! searching on the web for the particular camouflage style never seen before, i found on a japanese aircraft blog a build of the same kit. The squadron signed on the box is wrong, the proper squadron is a training one
here the link
http://www.straggleresearch.com/2011/11/new-airfix-zero-partial-build-review.html
and here the conclusion
http://www.straggleresearch.com/2012/01/rex-wadsworths-sweetnyellow-zeros.html
from the blog researchs the avaible subject from decals was full painted in yellow!! the ondulated green was added after now another drastic decision to do!! theres hve 3 ways
1) totally ignore the real aspect of the unit and paint it in green and below grey
2) correct green top and drastic yellow under
3) full yellow cab zero
