doogs - thanks! I'm glad you liked the BT-5. Hopefully I'll have a couple more builds to add to the GB! The Tu-2 looks great and for only $25.99!! Wow! I wonder who makes that kit?
Tony - thanks for checking it out and your nice comments.
Richard - It took a while but I finally got that old kit done! It turned out almost as I envisioned the completed build from the beginning. I'm very proud myself to have participated in your GB and to have been able to present something worthy here. Thanks for hosting the GB and for having me!
Randy - I'm not an AC guy, but I do love a well built and painted aircraft model! I'm glad you liked my little green tank!
So I've started on the Tamiya 1/35 GAZ67B Russian Field Car:
Lower chassis and suspension consists of only 7 parts! Detail is very basic and, being an old kit, is laden with mold seams and some pin marks, but nothing that can't be ovecome.
The wheels are also very simple, but detailed enough for me! Strange that there are none of the usual Tamiya poly caps for the wheels, just plastic inserts that allow the tires to rotate. Oh well, can't have everything!
When assembled the inner side of the wheels have a gap that I'm sure shouldn't be there. The gap is where the tire sidewall should be as the hubs are easily discernable in the molding. I'll have to fill those gaps with either putty or stretched sprue and sand smooth.
I think I counted a total of 67 parts which is quite a change from most of the kits I've build lately. Also, I will be doing this mostly OOB with only some light scratchbuilding to either correct mistakes or improve some of the basic detailing. I have absolutely no AM parts for this kit...mostly because I couldn't find any!!
Ernest
Last Armor Build - 1/35 Dragon M-26A1, 1/35 Emhar Mk.IV Female
Last Aircraft Builds - Hobby Boss 1/72 F4F Wildcat & FW-190A8
