When last we left my Hellcat I was working on the replacement wings from the Weekend Edition I ordered. The painting has gone well and I got the gloss coat on without mishap. Whew... Then it was on to the decals which was what I also needed from the new Weekend Edition kit. Decals went on just fine and then I noticed something quite out of the ordinary. The blue on the insignia for the upper wing was way out of register. WHAT THE #@$&!!!!! How? Common wisdom would have me believe that decals from essentially identical kits would be the same right? Nope. Not in this case. Here is a pic of a comparison. The wing at the top is the original that I am replacing. The one on the bottom is the new one with the out of register decal:
![](http://i848.photobucket.com/albums/ab48/joerix62/Hellcat/33b0a5db-884f-4efc-b002-53a53a38f109_zps8i3kqehy.jpg)
After a bouncing my head off the bench a few times it was time to invest in a solution. I was not about to give up on this now. Not after what I've been through with this build. I was not about about to purchase a second kit just to get one decal. So, I broke out the original decal sheet and began to examine some possible options. Two actually jumped out at me. First, was to use the '43 insignia which has the blue border on the bars and is slightly larger. Although technically incorrect, it would at least be in register and look good. The second option was to take the even older insignia with red border and trim the red border off. This would leave me with the correct insignia in size and configuration. But, htis would require a steady hand and sharp eyesight, both of which I lack. Here is a pic of my options:
![](http://i848.photobucket.com/albums/ab48/joerix62/Hellcat/d2cbc193-cc48-4820-a6d5-583d0f8f9928_zpsrtj8qd8f.jpg)
Yet, I decided to give it a go since I had the '43 insignia in case I hacked the daylights out of it. I broke out my trusty scalpel, small beauty scissors and optivisor and set to it. All the while gripped in doubt and fear. Well, I didn't do a half bad job. It's a bit rough but it might pass. I was unable to lift the old decal off with tape so I had to lay the new cut out over the top of the old one. More fear and doubt ensued! But..
Glory Be and Hallalujah! It Worked!!!
![](http://i848.photobucket.com/albums/ab48/joerix62/Hellcat/bc0621c4-1212-459f-b412-a9a95f076136_zpssjk3ekgc.jpg)
It's a tad rough around the edges but, nothing I can't fix with a little weathering. So, now I'm moving forward. I've cleared the the hurdles. nothing can go wrong now. Right?![Embarrassed](http://cs.finescale.com/emoticons/emotion-10.gif)
