Modern Group Build - COMPLETED - THANKS ALL !!
Posted by Bish on Wednesday, December 20, 2017 9:12 AM
Interesting conversion there LA.
    April 2014
Posted by lostagain on Tuesday, December 26, 2017 12:53 AM
Thanks Guys!
Trust everyone had a good christmas, sitting down watching the Boxing Day Test Match on the telly, so far advantage Australia, but not in a big way. Heading down to the MCG for day 2 tomorrow, should be good.
But back to the Cobra
Filled out the other side of the nose with epoxy putty, ready to put the cockpit in and glue it up.
Then with it all glued up, coated the nose in tamiya grey putty and sanded it back
Gave it a spray with can primer, found so many flaws it wasn't funny, a bit more putty and sanding it again
Another go with filler and that's as much as it is getting for now.
SO next is to build the firespotting IR ball that hangs under the nose, then final assembly before painting
Posted by Gamera on Tuesday, December 26, 2017 7:20 AM
Wow, that's a lot of work but looking good there in the last two photos.
    June 2014
Posted by BrandonK on Wednesday, December 27, 2017 9:48 PM
Lostagain, the hard work is really paying off. The bird is really starting to take shape and I can totally see it now doing its job. Very cool work and thanks for letting us follow along.
BK
On the bench:
A lot !! And I mean A LOT!!
                         14 / 5 / 2
                              Tongue Tied
Posted by Bish on Thursday, December 28, 2017 2:25 AM
That is some very nice work there LA, really interesting what your doing with this.
I hear the English finally decided it was time to turn up down under. Bit bloody late now ain't it.
    April 2014
Posted by lostagain on Thursday, December 28, 2017 6:14 AM
Hi Bish,
I chose the worst two days of the whole Test series to go and support Australia, but you're right, too little too late for the poms
    April 2014
Posted by lostagain on Sunday, December 31, 2017 9:24 PM
Masked off the glass and then stuffed up the installation - the port side is sitting wide, stuck on now and not going to move it. Used PPP to fill in the gaps around the glass, it works well in these gaps. Also been scratchbuilding some of the special accessories for the USFS bird.
Posted by Gamera on Monday, January 1, 2018 8:23 AM
LA: She's really coming together. Looks like that canopy was a pain to mask, at least you were able to use multiple layers of tape.
    June 2014
Posted by BrandonK on Monday, January 1, 2018 11:04 AM
Lostagain, looks like a chopper to me. Looks like you will be laying down some primer soon. You don't have far to go now, and its looking very impressive.
BK
On the bench:
                         14 / 5 / 2
                              Tongue Tied
    April 2005
Posted by taxtp on Monday, January 1, 2018 5:39 PM
I was at day 2 and day 3 too LA. They were long, slow, hot days ,but that was a magnificent innings by Cook. I'm glad I saw it, you don't see every ball of a test match deuce too often. BTW, your helo is looking great. I use PPP for around the canopiues too, in fact I just did that on Dragon 1/72 HE 162 that I've finally gotten around to this morning before work.
I seem to have lost some of the photos I took earlier in the build. I'll try to find them and post them later if i can, because there is a lot of work that goes on inside the fuselage of this kit. This kit is unique in my experience, there is no positive fit for ANY of the parts, at all. Makes it hard work, but there aren't too many He 162s out there in 1/72. As far as I know, there is this kit, also released by Revell, an earlier Revell release that looks like it's early, and the Hobby Boss easy build, which has less detail.
Anyway, on with the show, I'm going to aint this thing like grey and use some decals from Berna Decals to depict a French one in post war service. As I understand it, the Allies captured 27 of these at one airfield, and the French were allocated five. Interesting.
It will also complete my atempt to use decals for every aircraft on a decal sheet, I've never done that before. Two  FW190s, a Do 335, a Bf108 and this He 162, all in French markings.
Before closing the fuselage, I packed as much lead as I could into the nose. However once I added the tailplane assembly, it sat down on it's tail.
Luckily for me, I still have this opening behind the cockpit, my plan is to jam so more lead through it, with a gob of CA gel to fix it in place. It should work, as it's still in front of the main undercarriage. Also, that triangular piece between the wheel bays is a nightmare. They give you the undercarriage doors and this bit all molded in one piece. You have to cut it into three then locate this piece with no positive attachment points. I got it done, but it's hopelessly fragile, and I've already broken it twice whilst just holdng the model lightly. Yippee...
There is some nice detail inside the wheel bay, but the insert is 3 or 4 mm too narrow for the fuselage, so you have to work with that. I've managed to make it look acceptable...just.
Here it is sitting on it's undercarriage correctly, the additional weights worked :) I also added the canopy, and took this photo before using PPP around the canopy frame. The kit has those slots behind the canopy that allow for a movable canopy, but they didn't exist on the real plane, so they've gotta go. It seems like I've used more CA gel and putty on this thing than I have in a very long time, but its hard to see the CA gel in these photos. I'm not complaining though, we take on these  challenges as modellers :)
Cheers
Tony
I'm just taking it one GB at a time.
    April 2014
Posted by lostagain on Tuesday, January 2, 2018 2:56 AM
Yes it was a great innings to see, but the action was all on the wrong side...
I thought the Dragon kits were supposed to be better than that, sounds like you have had your work cut out to slap it into shape.
So now we are at primer stage. Well it was primer, fill sand, primer, fill, sand, primer before this point. In the background is a colour test card - the photos of the USFS bird shift between a dark red and orange, and the draw decal instructions call for International Orange, but that's too Orange I think. So my preferred colour is the one on the left, 25% Orange and 75% Red mix. But first I need to get the gloss white down.
Posted by Bish on Tuesday, January 2, 2018 3:50 AM
LA, helo is looking good, going to be an interesting scheme you have planned.
The old Dragon 72nd aircraft kits seem to have a bad rap for fit from a lot i have read. But i have built a few including 2 of those 162's, and i rather like them. They just take a bit of TLC.
Posted by Bish on Tuesday, January 2, 2018 3:58 AM
Coming together nicely Tony.
Your probably right about the Allies capturing 27. I am sure you have seen this photo and a couple of similar ones. These aircraft belong to JG 1 and are awaiting the arrival of Allied forces to formerly surrender.
    June 2014
Posted by BrandonK on Tuesday, January 2, 2018 9:38 AM
Tony, it never fails to amaze me how you 1/72 guys can pull of such amazing work on such small kits. Incredible. Looks like you are winning the battle.
LA, I knew that helo would look the part when primed. Your work has made it look like it came that way, and that was your desire. Well done, Sir. I'm looking forward to seeing it in it's fire colors.
BK
On the bench:
                         14 / 5 / 2
                              Tongue Tied
Posted by Gamera on Tuesday, January 2, 2018 12:19 PM
Tony: Looks perfect to me, great job esp with all the issues you had to overcome. The French scheme is going to look cool.
LA: Your primer coat looks perfect too, looking forward to seeing her with paint.
    January 2015
Posted by TheMongoose on Tuesday, January 2, 2018 10:39 PM
LA I pulled the close up of that primer job and it looks like you are going to have some nice lines on that bird when you put the color on her!
In the pattern: Scale Shipyard's 1/48 Balao Class Sub! leaning out the list...NOT! Ha, added to it again - Viper MkVii, 1/32 THUD & F-15J plus a weekend madness build!
    June 2014
Posted by BrandonK on Wednesday, January 3, 2018 9:05 AM
For those that may have missed it I am extending this build out until mid year 2018 due to the fact that I won't likely have time to start a new one this year and to give those who have not had a chance to complete their builds more time to do so. Keep them coming folks.
BK
On the bench:
                         14 / 5 / 2
                              Tongue Tied
    April 2005
Posted by taxtp on Wednesday, January 3, 2018 7:09 PM
Thanks Brandon. I was only thinking this morning that I should have entered more in this GB. So many jets that don't fit into other GBs. I've done the priming and preshading on my He 162, hopefully I will finish the paintwork today. It's quite a simple scheme, overall light bluish grey with green trim on the nose and front and rear of the engine pod. Hopefully I'll be able to shoehorn in some more before this GB ends. Cheers Tony
    October 2009
Posted by greentracker98 on Thursday, January 4, 2018 12:00 AM
Hi every one. I was just looking through the forums here and was really surprised to see the modern aircraft build still open. I had packed my Blackbird along with othe kits I have away because of health reasons. But last week, I thought, I'm going to get it out and finish the SR 71. I only have a few more decals to put on it and it will be done. I need to get the little flash drive for my camera then I'll be able to transfer the pictures to my computer.
Hopefully I'll be able to come in more often now. I do miss reading everyones comments and seeing thier great looking builds.
Ken
A.K.A. Ken                Making Modeling Great Again
Posted by Gamera on Thursday, January 4, 2018 8:39 AM
Thanks BK, you'd think I'd be able to build a F-16 in a year and half. I'll see about trying to finish up if can take care of what I'm working on now.
    June 2014
Posted by BrandonK on Thursday, January 4, 2018 9:01 AM
Hi Ken, glad to see you around these parts. I would totally love to see your SR-71. You are always welcome my friend.
BK
On the bench:
                         14 / 5 / 2
                              Tongue Tied
    August 2014
Posted by goldhammer on Thursday, January 4, 2018 10:54 AM
Thanks, BK.  Now that the timeline is extended, I've got to dig out 67-463 of the dust and try to finish her.Bow Down
Got as far as fuselage together and wheel bays white.  Now that I've got some incentive, the rest should go fairly quick in a couple of months.
    October 2009
Posted by greentracker98 on Thursday, January 4, 2018 5:22 PM
BrandonK
BK
Thanks Brandon
I'll get the decals finished tonight, but I'm not sure when I'll get the memory for the camera. The high for the tempeture for the next 2 days in suppose to 2 degrees F
Thanks every one
    June 2008
Posted by lewbud on Friday, January 5, 2018 1:52 AM
Since this one has had new life breathed into it, I'll get back to my EA-6B.
Buddy- Those who say there are no stupid questions have never worked in customer service.
    April 2005
Posted by taxtp on Friday, January 5, 2018 8:42 PM
Since we're talking about weather, it's 41 degrees C, or 105 degrees F here in Melbourne today. Phew.
I've finished my He 162, it was surprisingly quick in the end, must be that I'm in form after the Weekend GB.
Hope you like it. I've used Berna Decals to depict one of 5 that were allocated to France after the war. They were painted grey, internet research cam up with a couple of shades, 'Beige grey', which to me seems like RLM 02. I even saw someone interpret that as Beige and paint up a Beige He 162 :)
Someone else quoted an eye witness that they knew who recalled them as 'Bluish grey'. That's good enough for me, I used Tamiya's mix for French Light Grey which is two parts of XF-25 Light Sea Grey to one part XF-2 matt white. It came out about right to my eyes. I struggled with the colour for the green trim too, and ended up using Lifecolor's 'Vert Khaki' as I couldn't find many other French greens for the WW2 era. I figured any paint used in 1946 would be war surplus, they had more to do than come up with new shades of paint.
Here it is on it's journey.
and completed.
Cheers
Tony
    April 2014
Posted by lostagain on Saturday, January 6, 2018 1:14 PM
Hi Tony
The 162 looks great, a very neat, simple finish. The roundels really stick out against the background.
Can't see any of the struggles with the kit that's for sure.
With the temperature back down today I will try painting the orange on the cobra.
Posted by Bish on Saturday, January 6, 2018 4:04 PM
Tony, great job on the 162, looks really nice in that scheme, bit different from the usual 162's.
    June 2014
Posted by BrandonK on Saturday, January 6, 2018 10:41 PM
Well Tony, that came out super nice. I agree with your ideas on the paint colors, they did indeed have far too much to do than come up with new paints. I think you nailed it with your mix. It looks the part and is very convincing. Well done, Sir. I will update the front page and thanks for taking us along.
BK
On the bench:
                         14 / 5 / 2
                              Tongue Tied
Posted by Gamera on Sunday, January 7, 2018 3:45 PM
Hey Tony, love how she came out!!!
    April 2014
Posted by lostagain on Sunday, January 7, 2018 9:12 PM
Setting out the masking to paint the orange, realised the white was not opaque enough, so back to the shed to respray... Another four days to dry properly, then try masking again...
