The Race Into Space GB, October 2018 - July 2019 (Ended)
    July 2014
Posted by modelcrazy on Sunday, December 9, 2018 12:12 AM
We have "The Incredable Mr Limpet". She loves that one. I just ordered the "Reluctant Astronaut" from Amazon, we should get it just before Christmas.
I'll get the Shakiest gun and Mr Chicken later.
Steve
    July 2014
Posted by Bakster on Sunday, December 9, 2018 11:05 AM
modelcrazy
That sounds great, Steve. I think you two will have fun with it.
Yes
Posted by Gamera on Sunday, December 9, 2018 3:05 PM
Lol, saw it back when I was a kid, probably thirty years or more ago but haven't seen it since. Now I want to watch it again.
    July 2014
Posted by Bakster on Sunday, December 9, 2018 3:50 PM
Gamera
It's a hoot, Gam.
    July 2014
Posted by Bakster on Sunday, December 9, 2018 5:35 PM
Ok--I guess I can call the base done.
I did have a setback along the way. You may remember my last image showing the sandpaper concrete that I made. Since then I painted, weathered, and clear coated it. I planned on trying some washes over the clear, and the clear is where it went sideways.
I used the Humbrol Clear that I mentioned further down this thread. Well--to save time, I brushed it on. It was a stroke of genius! LOL. They tout this stuff as great for brush painting. And for the record--I think it is. Not so much on my sandpaper slab. What I didn't think of is that this stuff has the consistency of water. It goes on very wet. You might imagine what happened next. The clear leached under the sandpaper causing it to curl up along the joins. Blasted! I pondered on if I could force it down once dried. In the end I figured that no way it will ever look right again. It was a dreaded do-over.
So--this time I did things a little different.  As follows:
1. I went with 600 grit instead of the 400. To my eye, it looks more to scale.
2. I made each section of the slab out of styrene. Whereas before I had one solid piece with only the sandpaper cut into sections. In this case I am cutting both. Why? I figured I could paint and weather the pieces without the use of a wash by painting the shades within the joins before attaching them to the sublayer. (That's a mouthful)
3. I applied the pieces to a sheet of clear styrene. As before I used spru-goo. Why clear? Mostly because it is very thin. I didn't want the piece too thick. With it clear it added the benefit where I could paint color from below the joins, as a way to enhance them. How much this improved the look, I am not sure. I am pretty sure it improved some.
4. I used weathering powder around the joins and where the feet of the rocket stand will sit. I then painted over the weathering using the same color paint as the base coat. In effect--creating a filter to push back the powder some.
5. A final coat of Testers Dullcote mixed with Glosscote is applied.
That's that. I am not blown away by it, but it looks ok. My concrete weathering mo jo needs work. But--it will have to do for this build.
It was tough to image the piece where you can see the subtle shades. The human eye gets it, the camera not so much.
Next up: Masking the rocket.
    July 2014
Posted by modelcrazy on Sunday, December 9, 2018 5:38 PM
The base looks great and is a beautiful idea....or is it beautiful and a great idea.........? Confused
I staling it for my Saturn V Whistling
Steve
    July 2014
Posted by Bakster on Sunday, December 9, 2018 5:41 PM
modelcrazy
Lol.
And steal away!  Thanks, Steve.
    March 2010
Posted by mach71 on Sunday, December 9, 2018 7:29 PM
Beautiful!
    July 2014
Posted by modelcrazy on Sunday, December 9, 2018 9:34 PM
Well thanks guys, now you done it, I'm back on the Saturn. I worked for a while on the seams then sprayed the base coat again. I added some grey to see where I was painting. Juts a tad more clean-up then on to the gloss white. "Small steps Elie" from the movie "Contact"
The darker Grey is caused by shaddows
Steve
    July 2014
Posted by Bakster on Sunday, December 9, 2018 11:12 PM
mach71
Beautiful!
Thanks!
    July 2014
Posted by Bakster on Sunday, December 9, 2018 11:15 PM
modelcrazy
It looks good on that bench, Steve. You are barreling along on it nicely.
Btw, I like that movie.
    March 2010
Posted by mach71 on Monday, December 10, 2018 8:32 PM
Modelcrazy your SV is looking great!
Not much new here, I started masking the instrument panel today,
I was using left over masks from other projects and I ran out.
I orderd a punch set from amazon, that should finish things up.
    July 2014
Posted by Bakster on Monday, December 10, 2018 9:37 PM
Oh man.  You have an instrument panel? It looks cool! I can't wait to see it done. Cool model you are building.
Posted by Gamera on Tuesday, December 11, 2018 11:22 AM
Steve: Looks fantastic to me!
Mach71: Great work, love the IP too!
Bakster: That base looks perfect to me.
Little Timmy: If you're reading this hope you can get back on soon. I was locked out for about half a week there.
    March 2010
Posted by mach71 on Tuesday, December 11, 2018 1:00 PM
Thanks,
It looks like the instrument panel might not be acurate.
I think every Mercury had a slightly different configuration, I can't match this
one with any yet. I have to find photos/diagrams of all the missions to be
sure.
I'm sure it matches one of them.
Posted by Gamera on Wednesday, December 12, 2018 6:20 PM
Mach71: Ouch! I hope it's at least close...
BTW: Got this in our club Christmas party. I'm tempted to switch to this entry- looks like there's not too much to the kit:
    July 2014
Posted by modelcrazy on Wednesday, December 12, 2018 6:58 PM
Awesome Gam, I didn't know Revell had anything like that. How serendipitous of your giftee.
BTW, with the latest FSM SMAFU I can post for those who can't. Just find my public email in my bio and send me what you want to post with pictures and I'll take care of it.
Steve
GAF
    June 2012
Posted by GAF on Wednesday, December 12, 2018 9:47 PM
After a frustrating few days, I'm finally able to get back on and post.  I apparently just had to e-mail Steve about the problem... Wink
I don't have anything to report except that I have nothing to report.  I'm still recovering from the effects of this flu/cold, which means my time at the bench has been rather curtailed.  Also, my brother-in-law passed away last Friday and his memorial service is this Friday, so I'll be away for a couple of days.  When it rains, it pours.  Hopefully I'll be back on full-time next week.  I look forward to getting back to normal.
Take care, everyone!
Gary
    July 2014
Posted by modelcrazy on Thursday, December 13, 2018 2:56 AM
GAF
All someone had to do was ask.
Steve
Posted by Gamera on Thursday, December 13, 2018 7:37 AM
Gary: Hope everything is sorted out now and hope you feel better soon.
I was locked out for about half a week. Got back on this weekend and haven't had any issues since (cross your fingers).
    June 2018
Posted by DRUMS01 on Thursday, December 13, 2018 6:00 PM
I was out for a week, but I'm B-A-C-K! Prior to my untimely departure I indicated I was going to build a second space race kit, the venerable X-15 in 1/72 scale from Monogram.
Here it is... the only other thing I am not showing is where I glued the astronaut by his heels to the display base; now he goes wherever the kit goes.
The challenge was spraying the gloss black, decaling, then another gloss coat and final satin coat without having any grit in the final finish. The kit is really simple but looks good on a desk top. I built it for a friend and that is where it will sit.
Ben
That makes two / 2 for me so far....
Ben
"Everyones the normal until you get to know them" (Unknown)
LAST COMPLETED:
1/35 Churchill Mk IV AVRE with bridge - DONE
NEXT PROJECT:
1/35 CH-54A Tarhe Helicopter
    March 2010
Posted by mach71 on Thursday, December 13, 2018 7:46 PM
GAF, glad your on the mend.
Drums01, great X-15!
It look like the Mercury panel is from the MA-10 mission, Alan Shepards unflown
orbital mission.
    March 2010
Posted by mach71 on Thursday, December 13, 2018 7:49 PM
Gamera,
That Apollo astronaut is great!
    July 2014
Posted by Bakster on Thursday, December 13, 2018 8:03 PM
Very very nice, Drums. Both the pilot and x15 looks cool! You are a prolific builder. I am envious of that.
Yes
    July 2014
Posted by Bakster on Thursday, December 13, 2018 8:06 PM
mach71
orbital mission.
I have nothing to add on that. Maybe someone else here can, though.
Posted by Gamera on Friday, December 14, 2018 7:42 AM
Ben: Wow great job there on the X-15 and the astronaut!
Posted by Gamera on Friday, December 14, 2018 7:43 AM
Bakster
mach71
orbital mission.
Maybe I'd add a set of pink fuzzy dice...
Sorry Mach71- I couldn't help myself.
    July 2014
Posted by Bakster on Friday, December 14, 2018 8:32 AM
Gamera
Thats a hoot! Great idea. Or maybe a pine tree air freshener. It does get stuffy in those capsules.
    July 2012
Posted by littletimmy on Friday, December 14, 2018 10:07 PM
Gamera
I was "locked out" for six day's ..... and on the seventh day, my Wife bought me "Shiny Chrome !
But, I still followed along with everybody's build's.
 Dont worry about the thumbprint, paint it Rust , and call it "Battle Damage"
    July 2014
Posted by modelcrazy on Monday, December 17, 2018 1:26 PM
Here's my SV so far. I'm trying to get this done before I head out for Christmas. I forgot the black ring at the bottom of the second stage. I also have some touchup and silver on the CSM to do as well as a base.
Steve
