Man, I've been trying to post this reply for over an hour. First, the internet connection went down, so I copied it to wordpad so I wouldn't loose it. Then when the i-net came back up, I posted it to the wrong thread! So I went in there and deleted it then finally posted it here. Some days... lol
Moses, sounds great. Where do you get your Vallejo paints? I haven't been able to find a source for them. Interesting choice of colors you've got. I can't wait to see how it turns out. I'm betting on great. (You're not satisfied with your zimmerit??? Oh boy, the rest of us, me in particular, are in REAL trouble!) I'm right there with you on the side skirts. I'm leaving mine off until they HAVE to go on.
Okieboy, after doing the little bit I've done with the Tamiya putty, I'd definately recommend masking off "virgin" areas before putting on the zimm. I didn't on my first try and spent a lot of time afterward cleaning up places where I didn't want it. Some of it got down in the weld line detail on the top of the turret and man, was that a pain. Where are you finding Zimm-it-rite? I understand that stuff is pretty good to use, but understood that it wasn't being made anymore. I don't know how the cost compares to the Tamiya stuff. I've also read that Apoxi-Sculpt is pretty fantastic, and really cheep (something like $22 for 4 POUNDS!) compared to Tamiya.
I went out and looked at the Verlinden detail set (#1177) and I was pretty disappointed with it. Many of the resin parts didn't look too well molded and had quite a bit of flash on them. The instructions are virtually non-existant (guess they figure you'd better have your own references, still it's nice to not have to figure out from scratch what some part is and the general area it goes), and there were some parts that were unidentifiable (a couple of hollow cones that looked almost like jet or rocket exhust nozzles, in specific). On the other hand, some parts (the turret rear stowage containers, for example) are spectacular. Anyway, I decided it was a lot of money for the quality, so have decided to go with some of the Aber sets. I picked up the set for the side skirts and the Eduard barrel last night. I will probably get the Aber fender and detail sets next week. I also looked at the Model Point barrels, and they are nice as far as they go. They do not have any muzzel brakes with them, so I guess you would have to use the kit part. Although, I've seen a picture of a Tiger I or II that didn't have a brake on it. The end of the barrel was ragged like it and the brake had been torn/broken off. Interesting thought...
The Aber side skirt set I bought contains 6 smoke dischargers that mount on the lower hull. 3 each side at the front corner, middle, and rear corner. In my references, it appears these were mounted on the hull of early mid production Tigers. Any thoughts on this from you experts?? Thanks.
Someone tell me what tool you use to do the starburst zimm patteren around the kubelblende and the gun ports on the turret. I'm using the Tamiya zimmerit tool set, and even the small tool is much too big to do them. I'm considering whittling down a piece of resin to use, unless someone has a better idea.
Have a great one.
Bill
Bill
DML M4A2 Red Army
-- There is a fine line between "hobby" and "mental illness". (Author unknown)
