Hello!
Real G - Yeah, the BRDM is a similar machine, but the Warsaw Pact used it for everything, and the R in the name is for "Razvedka" (Recon), so that's a role that the M706 wasn't meant for - not that the BRDM has any equipment that couldn't be installed on the M706.
I'm glad you like my work, thanks a lot!
Gamera - thanks a lot, I'm so glad you're still here!
But it's true, it's tiresome how bad the forum works now. When you compare it to a forum that actually works, the difference is shocking.
I'm here mainly out of sentiment for the old times, and here's another update:
I have the rear suspension done:
The resin wheels are from a company called MMK, the axle is my 3D print with a hole through for a reinforcement made out of brass wire to keep the axle from bending under load when it gets hot, and the shock absorbers are scratchbuilt.
And here's how the subassembly fits into the chassis:
Now more fun to come - the front suspension and the steering system!
Thanks for looking and have a nice day!
Paweł
