Hey Guys---well, it's been a long road to this point. Thanks for the comments, and I'm sorry for not acknowledging them sooner; I've really been just lax from being stressed out and under pressure with all that's been happening here.
Brian, I just used regular 5-minute epoxy from a hardware store; nothing fancy! ![Smile [:)]](/emoticons/icon_smile.gif)
Well, here's an update. I'm about ready for paint.
First, for those really considering this kit--there are a couple stupid mistakes that I made which you shouldn't--first, DO NOT install the spaced armor on the front hull--the box will not fit properly with it on.
2. DO NOT install the armored guards (?) over the engine screens--the crane will not fit with them installed.
I had a hell of a time figuring out the parts placement--more how to space and align the crane parts--the darned side brackets are so tight that they really almost make the placement of the crane jib impossible--anyway, I finally got it figured out. Here's a progress report so far....
Most of these vehicles are seen either with regular tracks, or "Ostketten"--which are shorter than "Winteretten". However, since theonly kit of Ostketten tracks I could find were in the $40.00 range, and resin (you know how I hate resin tracks!) I decided to use the last set of winterketten tracks that I had. There is photographic evidence--TA DA!!!
What's more, is that this photo also shows that some vehicle were modified beyond "normal"--there looks to be some sort of shield or special armor--even perhaps a top and a hatch?--fitted to this vehicle?
This "customization freedom" will play into my build-philosophy for this kit! ![Tongue [:P]](/emoticons/icon_smile_tongue.gif)
First of all--the winterketten tracks, I was disappointed to find that this set--I believe that I 'lifted" this set from the StuG IIIF kit--are completely unusable in their present state! I mean--look at the height of the dual knockout marks on this link!
I do have to say that the separate, actual "kit" of later-released Winterketten tracks, which I used on my late Brummbar and which come in a darker gray plastic color--were not as egregiously scarred.
After painstakingly using a flat Exacto blade to shear off each little stub, and then filing smooth the remainder, (two night's work!) I started out by assembling the tracks, as per my "doog method"--leaving off the outer return rollers, and assembling the tracks on masking tape. The winterketten are "handed" so I did two rows. Here's the link to my tracks tutorial, for anyone curious: http://www.armorama.com/modules.php?op=modload&name=Sections&file=index&req=viewarticle&artid=1737
![](http://i170.photobucket.com/albums/u244/heydoog/Bergepz%20III/pz3.jpg)
I also added some reinforcing strips to the bottom of the box--the box should not sit flush on the hull, and this is one omission of the NeoGrade kit.
![](http://i170.photobucket.com/albums/u244/heydoog/Bergepz%20III/pz34.jpg)
I also built a storage rack for the crane jigs, and built an extra crane jig. You also have to eliminate the radio antennae mount and channel--that little square of plastic is to replace where the mount would have been.
![](http://i170.photobucket.com/albums/u244/heydoog/Bergepz%20III/pz313.jpg)
And as part of my "customization", I decided that a late-war Bergepanzer might need a bit of extra firepower (at least I would have wanted some in mine!?) so I built up this pedestal-mounted MG to put in the bed. The parts came from spare parts from the "Shwebelafette" halftrack that I finished recently.
![](http://i170.photobucket.com/albums/u244/heydoog/Bergepz%20III/pz311.jpg)
So here's what it looks like so far. The box, MG, and all the rest of the chains and tackles are not fitted yet. I'm going to paint them all separately, and put them together...
![](http://i170.photobucket.com/albums/u244/heydoog/Bergepz%20III/pz33.jpg)
I also made a ladder for the entry hatch, and also had to lengthen the longer crane brace because it didn't reach the other mount.
![](http://i170.photobucket.com/albums/u244/heydoog/Bergepz%20III/pz36.jpg)
![](http://i170.photobucket.com/albums/u244/heydoog/Bergepz%20III/pz32.jpg)
![](http://i170.photobucket.com/albums/u244/heydoog/Bergepz%20III/pz35.jpg)
I went kinda easy on the sag--I figured that the engineers would keep it pretty tight?
![](http://i170.photobucket.com/albums/u244/heydoog/Bergepz%20III/pz310.jpg)
![](http://i170.photobucket.com/albums/u244/heydoog/Bergepz%20III/pz38.jpg)
I added a pair of spare track racks and you can see the other dark-plastic winterketten links there.
![](http://i170.photobucket.com/albums/u244/heydoog/Bergepz%20III/pz39.jpg)
So that's where I am so far. I'm going to be trying a new painting approach on this one. I'm not sure how it will work out, but it will be interesting at least. That resin "wood" will also demand a bit of innovation. I just hope that, given the crazy schedule I'm under here with teh band, that I'l be able to get it going soon?
Comments, suggestions, critiques and anything else much appreciated and welcomed!
