Hi all.
I have started working on this resin interior for an armor vehicle. The kit has two wall insets, where some instruments ets are casted on a thin wall 'baseplate'.
The problem is that this base plate is unevenly poured: Excluding instrumentets etc, the wall baseplate is intended to be about 1mm thick (maybe a bit less, I haven't measured it). In one corner it is this thin, but in one other corner the wall is at least twice, maybe three times, as thick as intended.
The problem is how to thin this wall.
So far I have used a coarse sandpaper, laid it flat on the table, and sanded the back of the wall on it.
There are several problems with this: The wall is large (8cm x 3 cm) or so, so it requires a lot of force to sand it. The resin is brittle, so I don't want to use too much force. The second problem is that i try to and the thick pars of the wall more than the thin parts. This is only partically successful, as there is a 'hump' on the back of the wall; it is no longer flat.
So I'm wondering if there might be some clever tricks to do these kinds of things?
DoC
