Tristar Pz IV Ausf B DONE 8/12 page 11
    April 2005
Posted by wing_nut on Tuesday, July 6, 2010 7:46 AM
Dave again I say... SCHWING.
The tree is very cool.  All it needs is a rope SCHWING to go SCHWINGING.Stick out tongue
Marc
    August 2009
Posted by M1Carbine on Tuesday, July 6, 2010 2:00 PM
I say...
BADABINSCHWING!!!!!!!!!!!!!!!
Bob
    May 2005
Posted by hughes2682 on Thursday, July 8, 2010 2:52 AM
Oh my there is a whole lotta SCHWINGING going on here.  Surprise
Marc and Bob,
The both of you dang near made me snork my IPA on the monitor (again!).  Thanks for the laughs guys.Big Smile
I accomplished some more on the base.  Mostly modifications.  I felt the embankment was a bit blah so I casted some outcropping rocks using a Woodland Scenics mold and hydrocal plaster.  To place the rocks I cut out a couple of areas using my Dremel and, "cemented" them in using Elmer's Wood Filler.  I filled in around the rocks using the same Elmer's material.
This one is a bit fuzzy.  I tried numerous time but the camera kept focusing on the first tree I ever made.  It 'll give you an idea of how it looks.
The tracks dried overnight.  I used Devil Over the Atlantic "Track Brown".  I like the color and it goes on pretty nicely.  I shot two views of different stages.  In both of the pics the finished track is on the left(treated with a MIG pigment wash "European Dust" and graphite for the contact areas) .  In the first pic the track on the right does not have the wash applied nor does it have the graphite.
In this pic, I have applied the MIG pigment wash to the track on the right but not the graphite.  That will happen tomorrow.  Perhaps the decals as well and then I can get started on the weathering.
Cheers and good night Sleep
Dave
http://img.photobucket.com/albums/v317/Aaronw/Groupbuilds/ClassicAviationGB2010bomb.jpg
With enough thrust, pigs fly just fine.
    April 2008
Posted by *INDY on Thursday, July 8, 2010 3:45 AM
Its all looking brilliant DaveYesYes
Perfect choice of construction materialsWink
This is going to be a real corker when it's doneBeer
"Well...you gunna pull them pistols, or just whistle Dixie?"
    May 2005
Posted by hughes2682 on Friday, July 9, 2010 3:35 AM
Indy,
Thank you so very much for checking in on this build and the compliments.  Ed and Bob sold me on the Elmer's filler.  Very forgiving stuff to work with.  I got some more done on the tree today but it's probably nothing that would show in pics.  Some of the branches got painted with Vallejo Burnt Umber. Oh, and the other track run got its graphite treatment.  So, both track runs are done.  Nest will be decals for the beastie.  But first, I'm trying to find a reference pic that shows a number on the left side of the hull.  Whether it is on the hull itself or on a placard.  I've got the PE placard that came with the kit, it's just not called out.  Hmmmm.
Cheers
Dave
    July 2004
Posted by wbill76 on Friday, July 9, 2010 3:25 PM
Dave,
I'd say run with the placard. The use of the rhomboid placard wasn't discontinued until late in 1940 so the IV-Bs would be most likely to have the placard and vehicle number vs. the turret.
    May 2005
Posted by hughes2682 on Saturday, July 10, 2010 5:11 PM
Bil,
Thank you for the info.  I had planned on heeding your advice anyway when, I took another look at my references and, clear as day, I found several pics that clearly show the placard, including several with the post that it is mounted to.  Putting a "few" hours in at work and not enough sleep.  Oh well. Confused That happened.  As always thank you for following this and your support.
Cheers
Dave
    May 2005
Posted by hughes2682 on Saturday, July 10, 2010 11:19 PM
I'm calling the tree done.
The trunk and larger branches were washed with Vallejo German Black Brown.  Once this dried I dry brushed the same areas with Vallejo light grey.
I did a test shot on a scrap piece of basal and some Woodland Scenics Turf blends and, decided to apply it to the tree as it looked sparse after the test shot.  I first sprayed the tree with 3M Spray Mount.  I then placed a small handful of Woodland Scenics Coarse Turf Burnt Grass T62, held the base upside down in the bag, shook the bag.  Instant foliage.  I sprayed what was already on the tree and then placing Green Blend T49 in the bag and, repeating the process.  This darker green gave the foliage more depth.
Now I can get started on the rest of the base.  Once I finalize those colors then I'll get back to the tank (after the decals are on) so then I can apply the colors to the tank, thus tying the tank and base together.
Cheers
Dave
    May 2005
Posted by hughes2682 on Tuesday, July 20, 2010 3:12 PM
The bench has been idle for a about a week now.  The better three quarters and myself were out of town.  A grown up (ie no kids) biking/kayaking trip to the San Juan Islands.  I'm feeling quite a bit more human now and the creative juices are flowing better.  I got a little bit done since getting back.  I got some color on the base.  Now mind you, these are only initial colors.  They will be built up in layers, so the stark colors are not the final product.  The vertical portion of the base is painted with Liquitex Burnt umber.  The ground portion is a mishmash of Woodland Scenics Yellow ochre, raw umber, burnt umber and slate gray.  I also used a bit of Liquitex Raw Sienna.  The rocks were painted with Vallejo Basalt Grey.  I am still needing to fabricate a static grass applicator.  Finding a 9-12volt Negative Ion generator is proving problematic.  No worries.
This is a detail shot of the tree with the excess foliage brushed off, so that the branches and trunk are now visible.
Cheers
Dave
    July 2008
Posted by Railfan 233 on Tuesday, July 20, 2010 3:28 PM
Well, Dave you may say no worries with the static grass applicator, but I'm still going to do a little worrying for you.
Here's a link to a back issue of an on-line model railroad magazine I subscribe to, with an article on how to make a few different types of static grass applicators (both using a negitive ion generator, and another one not using one) It also has some adresses of negative ion generator dealers, if you want to get one.
I hope this helps.
http://model-railroad-hobbyist.com/magazine/mrh-2010-MarApr
http://i6.photobucket.com/albums/y211/razordws/GB%20Badges/WMIIIGBsmall.jpgRed, White, and YOU! group build of 2010
    May 2005
Posted by hughes2682 on Wednesday, July 21, 2010 2:27 AM
Railfan233,
Thank you for worrying and the link.  That is exactly what I was in search of as it appears that nobody has the 12v ion generator avaliable.  Yes, I have "played" with 120v before with some remodels around the house. Looks like I'll be building the 120V version.  Hey, maybe I can apply the grass from across the garage.  Or maybe couple that with a 1/16 scale R/C Tiger and that'll keep the cats out of my flower beds. Just kidding. Oh I know I'll catch Censored for that one. Big Smile
Cheers
Dave
    July 2008
Posted by Railfan 233 on Wednesday, July 21, 2010 10:30 AM
hughes2682
Cheers
Dave
Well, I don't think it would work across the garage, and it would be bad to the cat, but you are on to something.
You could probably make an RC tank that fires a Police tazer, and use that on the neghborhood hooligans that trespass and vandalize your property (just 1 zap, and they'll be more than willing to leave you alone) Mabe that would cut down on crime: the tazebotBig Smile
    August 2009
Posted by M1Carbine on Wednesday, July 21, 2010 11:23 AM
Brother Dave, this is lookin STUNNING!  I still cannot get over the tree and how well it looks.  You need to give me a toot next time you come over.
Bob
    May 2005
Posted by hughes2682 on Thursday, July 22, 2010 12:01 AM
Railfan233,
I snorked my coffee this am when I read about your "Tazebot".  I snork more java reading replies in these forums.  Thank you again for the grass applicator link.  I'll be ordering the generator and gathering the parts tomorrow.  It looks like it'll be the 120v option.  Woooo Hooooo!Lightning
Bob,
My brother.  Thank you for the compliment and the consistent support in my builds.  That TBM is looking fantastic by the way.  We need to set up another visit.  When we do I can bring all the supplies for tree building and case of Ninkasi.  I think the next time I build a tree I can cut the assembly time in about half.  I would like to try my hand at some evergreen trees. You know, for a nice friggin' cold middle of winter dio/vignette with some white wash armor and troops that look chilled to the core.
Cheers gentlemen and thank you for looking in on this build.
Dave
    July 2004
Posted by wbill76 on Thursday, July 22, 2010 9:33 AM
Nice to see you had a chance to recharge the batteries, sometimes that's just the trick! Nice work on the tree and ground work Dave, now get this one done already! Big Smile
    August 2009
Posted by M1Carbine on Thursday, July 22, 2010 10:51 AM
Dave - thanks and excellent idea my brother.
Bob
    May 2005
Posted by hughes2682 on Thursday, July 22, 2010 11:07 AM
Bill,
Thank you for the compliments and your support. That having been said.... that whip stings! Crying      Big Smile     I repainted the base color yesterday and am much happier with it not.  I'll still be using the Woodland scenics colors for washes.  This base is an experiment in progress as I've not built many.  Four previous ones but, nothing as this involved.  I'm getting better about not biting off more than I can choke down.
Bob,
Good morning brother.  Yeah, I get those ideas from time to time.  You know, just like a busted watch... correct two times a day.Big Smile  I'm looking forward to getting back to the tank as the ground work has been moved to the fore of the line.  The panzer has been ensconced as to keep the base work dust off of it.
Cheers
Dave
    April 2005
Posted by wing_nut on Friday, July 23, 2010 6:01 PM
Still very schwingalicious DaveStick out tongue
Marc
    February 2007
Posted by T-rex on Friday, July 23, 2010 8:05 PM
Looking good, keep up the good work.
Working on: Trumpeter SU-152 (1/35) Trumpeter E-10 (1/35) Heller Somua (1/35)
"The world is your enemy, prince of a thousand enemy. And when they'll find you, they will kill you... but they will have to catch you first ''
    May 2005
Posted by hughes2682 on Saturday, July 24, 2010 1:38 AM
T-rex,
Thank you for the compliments and having a look at this build.
The negative ion generator will be here Tuesday and I gathered most of the parts today to build it.  I only need to go to the hardware store and get the ABS supplies.  The plan is to have the grass on the base by this next weekend.  BIG kudos to Railfan233 for sending me the link to build one of three applicators.  Mine will be the 120volt version.  Yes, I will be careful and, yes, I have played with 120 volts before with remodels on the house.  No riding the lightening for the boy.
I did get a little bit done on the base today.  Some color and some flora.  The rocks I had already painted with Vallejo Basalt Grey.  Today, I gave them a wash with Woodland Scenics Burnt Umber. To give the impression of dirt and dust that had settled into the nooks and crannies.  I then highlighted them with Vallejo Stone Grey, followed with a very delicate highlighting with Pale Sand.  The flora is by NOCH. The sets  used are: Grass Tufts Flowering and Grass Strips Spring.  I applied the Grass Strips to have the random clumps that will stand higher than the static grass when I get it applied.  I am thinking that I will be applying more to the base before the static grass gets applied
The base had a dark wash applied, Woodland Scenics Earth Undercoat and, was highlighted with Vallejo Buff.
Cheers
Dave
    August 2003
Posted by Nachtflieger on Saturday, July 24, 2010 5:49 AM
Wow, your base is looking awesome!!!! I can't wait to see the static grass applied.Big Smile
I've saved a link from a model railroad site for building a static grass applicator myself, and it's on the "to-do" list, so I am VERY curious to see how you make out.
Nate
    May 2005
Posted by hughes2682 on Saturday, July 24, 2010 11:30 AM
Nate,
Thank you so very much for the compliment.  I've been chomping at the bit to get the static grass down.  I've been tracking the package for the ion generator and, it left Salt Lake at 0436 today.  It'll be here on the 27th.  The only down side is that is toward the end of my work stretch.  The up side is that it'll be here when I'm done with my work stretch and I can get it built.  So, stay tuned, as I should have the grass down by the end of the week.
Cheers
Dave
    October 2008
Posted by RickLawler on Saturday, July 24, 2010 11:36 AM
Wow, this has turned into quite the hefty, and informative log.   I just spent the past 1/2 hr. catching up on your progress...well done all around.  The base is coming along very nicely.
I'll be looking forward to seeing it all tied together very soon.
Enjoy the Summer (finally).  BTW..I'll be in Eugene later today.
Rick
    January 2008
Posted by Bodge on Saturday, July 24, 2010 12:13 PM
Dave it is looking great, the tree is awsome and the whole layout is spot on. Depending on how much grass you want on this scene i find hanging basket liner a really effective grass alternative and very realistic. I also blend my vegetation together with the base with a light spray of dust and also use pigments to blend .
Hope some of this might be of use to you mate.Andy.
    May 2005
Posted by hughes2682 on Saturday, July 24, 2010 12:42 PM
Andy,
Thank you for stopping in and the compliment.  I've got a package of the basket liner I picked up at the hardware store.  I've yet to use it but, after seeing these dio pics, I will have to utilize it.  Is the dio yours?  What was used for the ferns? This is of a huge use to me.  Thank you so very much.
Cheers
Dave
    December 2008
Posted by New Hampshire on Saturday, July 24, 2010 1:35 PM
Dave, the base is looking perfect!  Can't wait to see the IV on there! Cool
Brian
    May 2005
Posted by hughes2682 on Saturday, July 24, 2010 5:25 PM
Rick,
High praise indeed sir. Bow Down Thank you.  I added a small detail to the base today. Some roots poking out of the ground.  These came from some yard work I was doing last year and kept some clippings.  I have been enjoying the summer. I got back earlier in the week from a biking/kayaking trip in the San Juans.  The entire time I was there enjoying myself I was also taking in the land scape and making mental notes.  Welcome to Eugene.  Hopefully I will meet you at an upcoming show and pick your brain about some stuff/techniques. If you do not mind that is.
Brian,
Thank you sir for the compliment.  I did get a small but important bit done on the Ausf B today.  The decals.  I had been putting it off as I've been focused on the base.  I opted to do them today as I go back to work tonight and by the time I'm done with my stretch they will be fully cured.  Then, I can finally play with my Abteilung oils that I got for my b-day in June.  Wooooo Hooooo. Also the base should have the grass on it within the week.
The decals are not silvered. It is the way the light is reflecting off of the glossy portion of the decal.  I have turned the lazy susan every whichway and I can not see any silvering.  I double checked after I shot this pick. When I saw in on the camera I thought I had a dreaded case of the silvering.  When I went to place the decals,I wetted the decal and, then I brushed a small amount of Future (undiluted) where the decal was to go. With the decal on, I positioned exactly where I wanted it, then I blotted the decal with a Q-tip moistened with water. Any Future that got out from under the decal and was starting to leave a ring was taken care of with the aforementioned Q-tip.
You can see where there is enough residual Future to darken the paint but, not enough to gloss it up.  I am not worried about this as the weathering will take care of this.
The root structures I mentioned.  Don't throw away all of your lawn debris.
Cheers
Dave
    January 2008
Posted by Bodge on Sunday, July 25, 2010 1:35 PM
Dave yes these are mine, I used moss for the ferns, there are so many varieties of moss in peoples gardens. I do a lot of building and landscaping in my work and i have allways got my eye open for things i can use in modelling. Have a look at a post of mine called How to build a Normandy dio in 1/72 scale or one called Timeout. Hope these help. Cheers mate.Big Smile
    July 2004
Posted by wbill76 on Monday, July 26, 2010 1:11 PM
Very nice progress with the base Dave, the flowers along the road are a very nice touch...definitely provides just that slightly incongruous bit to draw the eye without it seeming out of place in the setting. Late Spring/Early Summer France definitely comes to mind with them there! Wink
    August 2009
Posted by M1Carbine on Monday, July 26, 2010 3:23 PM
Thats it....between you and Ed.......Im throwing everything away.........................LOL
AWESOME! BRO
Bob
