Tamiya Wespe COMPLETE 08-29-10
    April 2009
Posted by deafpanzer on Sunday, August 15, 2010 7:15 PM
Nice camo work! Yes Lately I have been keen about buying another Tamiya kit unless it is a new release after 2000 and not re-boxed like StuG III Ausf B that came out nicely especially that it came with small PE set and an aluminum barrel.  Yours is coming out great as usual.  If you were in my shoes, I don't have a Wespe kit yet and it is on my wish list, would you have brought a Tamiya or DML kit?
Congrats about the anniversary... my 14th is coming up in October! Toast
Andy
    July 2006
Posted by redleg12 on Sunday, August 15, 2010 7:18 PM
Bill - Ahhhh the wonders of blue painters tape....can't live without it. Nice camo work....always love your camo.
As for the wife and 14th...congrats...and best to the Mrs....
The hobby supportive wives must be taken care of Wink.......my anniversary will be 28 in a month Surprise we take good care of each other!! Wink
Rounds Complete!!
"The Moral High Ground....A Great Place to Emplace Artillery."
    July 2004
Posted by wbill76 on Sunday, August 15, 2010 7:52 PM
Chris, thanks for the kind words! Certain days always have to get their due...the irony is that I have a jury duty summons for Tuesday so we both thought it best to celebrate today rather than wait until the actual date of the 17th. Big Smile
Eric a belated congrats to you as well!
BeerTony, Brian, Mike, thanks as well for the best wisshes and of course interest in the build. Wink
Andy, the more modern Tamiya releases are definitely a pleasure to build if the subjects are things you are interested in. Unfortunately DML doesn't offer a Wespe (only a Marder II) yet, so if you want to build a Wespe, the Tamiya kit is the only game in town at the moment. Thanks for the kind words and congrats! Beer
    May 2009
Posted by hedorah59 on Sunday, August 15, 2010 7:56 PM
That camo looks really cool Yes - And thanks for the pic with the masking tape, Bill, that explains it all!
Congrats on your upcoming anniversary as well! Pizza Beer
Kirk
Posted by tigerman on Sunday, August 15, 2010 10:10 PM
wbill76
Totally agree. The Wespe, Marder III M, and Pz III L are my favorite of their 90's or later releases. I have a Pershing, Marder III, and Hetzer in the stash and they will be undoubtedly fun to assemble when I eventually get around to them. Just can't go wrong with Tamiya.
 Eric
    August 2003
Posted by Nachtflieger on Monday, August 16, 2010 4:23 AM
Camo looks great Bill!Yes
Nate
    July 2004
Posted by wbill76 on Monday, August 16, 2010 8:55 AM
Kirk, thanks for the comments and glad the masking tape example works for you.
BeerEric, I would also add their Char B1 Bis to that list...a very well engineered kit all around, especially the tracks.
Nate, thanks as well!
    July 2004
Posted by wbill76 on Monday, August 23, 2010 9:33 AM
Work progressed this weekend with the focus mainly on the details and preparation for the markings and weathering stages.
First up was the running gear. The lower hull and elements were pre-weathered by stippling MM enamel Burnt Umber with an old brush to simulate scuffs/scrapes from normal driving/handling and all of the road wheels and return rollers glued into position. The Tamiya poly-cap design for the sprockets meant they could rotate freely in position and the idlers were left off to the side until it was time to add the tracks. I also applied some MM non-buffing Metalizer Steel to the sprocket teeth and also the contact surfaces on the idlers. The suspension leaf springs were detailed with MM non-buffing Metalizer Gunmetal and given an overall wash of thinned enamel Rust to complete their look.
Next up were all the pioneer tools and gear for the fenders. The metal portions were finished with the same non-buffing Metalizer Gunmetal and lightly dry-brushed with enamel Steel. The wood portions were painted with a base-coat "wood" color custom-mix I keep on hand and then given a light wash of thinned MM enamel Leather. The tools were installed in their respective clamps and locked in place. The spare track run was also added to the hull nose along with its retainer. For the jack block, I added the Eduard detail items for the reinforcing strips and carry handle after the block had been painted since they are already in a metal finish and didn't need any additional treatment as a result.
The rear of the vehicle also received some attention. I detailed the aiming stakes (or what Tamiya provides to represent them at any rate!) by hand alternating with Flat Red and Light Gray to produce the candy stripes. The rear Notek convoy light was given a base coat of non-buffing Metalizer Steel followed by a coat of Tamiya Clear Blue. The exhaust muffler was base coated with non-buffing Metalizer Gunmetal and given successive washes of thinned enamel Rust and enamel Burnt Umber. I also applied, very lightly, the same washes over the heat shield screen and then dry-brushed the Light Gray/Dunkelgelb base-coat color over it to blend it all back together a bit.
That brought things around to the tracks. Off-and-on over the last couple of weeks I've been slowly assembling the runs. The MK links have one pin already molded in place and you slip the links together and add the opposite side pin to assemble them. Makes for a relatively speedy process but the links are small and have 3 attachment points on the sprue, so the cleanup is what took the most time. I assembled 2 runs and test fit them, the left hand run needed 99 links while the right needed 100 to generate the desired sag.
The tracks were primered by airbrush with MM enamel Flat Black to protect the delicate pins and plastic from the effects of the lacquer-based overcoat of MM Non-buffing Metalizer Gunmetal also applied by airbrush. After the tracks were dry, I heavily dry-brushed enamel Steel and then applied a wash of enamel Raw Umber. The tracks were then installed and the movable idlers used to create the proper tension on both sides to round out the day's session.
    August 2008
Posted by Pvt Mutt on Monday, August 23, 2010 9:56 AM
Sweet little buggy Bill and that camo just makes it pop.YesStarStarStar
Love ItHeart
Tony LeeSmile
Shoot Low Boys They're Ridin Ponys
    July 2004
Posted by wbill76 on Monday, August 23, 2010 1:27 PM
Thanks Tony, always glad to have you stop by and comment...especially with an SPG build! Wink
Posted by IBuild148 on Monday, August 23, 2010 6:14 PM
Now that I have read all your posts and the comments I can say it is another Master Bill build.Yes
My only other question is when you said you had some time "to do some interior paintwork".....what panzer colors where used?
IBuildOne48
Teach modeling to youth!
Scalefinishes.com
http://i712.photobucket.com/albums/ww122/randysmodels/NMF%20Group%20build%20II/Group%20Badge/NMFIIGBbadgesmall.jpg
    July 2006
Posted by redleg12 on Monday, August 23, 2010 7:54 PM
As always, you details stand out.
Some day we are going to pin you down and get the formula to the great Bill wood mix!!
Starnge that there is only one aiming stake....these are normally used in pairs....one near and one far in order to get good alignment. One stake could be inaccurate
Rounds Complete!!
    May 2009
Posted by hedorah59 on Monday, August 23, 2010 9:14 PM
Its really looking great, Bill - I agree with Tony, that camo is fantastic Beer
Kirk
    July 2004
Posted by wbill76 on Monday, August 23, 2010 9:18 PM
IB, thanks for the comments! I'm not sure I quite understand your question about the interior paint work...back on Page 2 /forums/t/130193.aspx?PageIndex=2 of the thread I outlined what colors I used for the general paint work as well as all the different details where appropriate. Is there something additional/specific that you're looking for? I use a custom mix of 50/50 MM enamel Light Gray/Panzer Dunkelgelb for my base color, if that's what you mean by "panzer color"?
Mike, always glad to see you stop by as well! I don't know why they only carried one aiming stake...could be a size/space issue in terms of the rear hull and needing to have enough clearance for the rear door to fold open or similar. The references I've got only show one stake in place as a consistent thing, perhaps the 2nd stake was carried by the ammunition carriers that accompanied the gun batteries? Hard to say...as for the "wood" mix, that recipe is long forgotten. I started out one day mixing various colors until I got the tone I wanted. All I remember is that it includes various proportions of Panzer Dunkelgelb, Light Gray, Leather, Afrika Grunbraun, and Italian Dark Brown. Propeller I get tired of trying to write that out all the time...and I've got a large quantity of it mixed up so it should last a while until it ultimately goes bad (as it inevitably will due to the mixed paints).
    July 2004
Posted by wbill76 on Monday, August 23, 2010 9:20 PM
Thanks Kirk, you sneaked in while I was replying to the others. Glad you like it! Beer
Posted by IBuild148 on Monday, August 23, 2010 9:47 PM
Bill,
I was referencing your first post on this build where you said you did some interior paintwork and bathrooms:
As some of you may know, the past month of July has been quite an adventure in terms of various things happening to me. First I had a major computer meltdown at the end of June which resulted in me having to do the unthinkable (I'm a former certified Microsoft systems engineer, former network engineer and PC support specialist, etc.) and actually take my PC to the Geek Squad at BestBuy to get it back. That took a couple of weeks. Second, at the same time as the aforementioned computer disaster, contractors were here adding the now fully functional model room/spray booth, etc. and that took essentially the entire month of July to get it completed before I could get back to the bench. Third, and lastly, the past weekend my wife and I decided it was as good a time as any to do some interior paintwork before she headed back to work as an elementary teacher since her summer break was coming to an end. That resulted in all of last weekend being taken up with repainting the two bathrooms and my original office space before all of the summer casa revisions could be considered "done" for this year. Long story short, it is now possible for me to resume my "regular" weekend schedule.
In other words did she allow you to use any armor colors on the wall?Big Smile
IBuildOne48
Scalefinishes.com
Posted by tigerman on Monday, August 23, 2010 10:11 PM
Nice Bill. Bow Down
 Eric
    July 2004
Posted by wbill76 on Monday, August 23, 2010 10:41 PM
IB aha! The light bulb goes on! Idea You threw me when you mentioned interior colors...I'd forgotten about the original post reference. FWIW the colors of the two bathrooms are by Valspar and go by the names of Limeish (hers) and Misty Blue (mine). Don't know who comes up with their color names but I guess you have to get creative to distinguish all the shades (not to mention all the different kinds of "white" paint you can buy)! I was tempted to paint mine in three tone ambush scheme but masking all the discs would've been a true nightmare...Wink
Eric thank you kindly sir! Beer
    October 2009
Posted by jetmodeler on Tuesday, August 24, 2010 6:56 AM
Looks good so far. I like the camo scheme.Toast
    August 2003
Posted by Nachtflieger on Tuesday, August 24, 2010 7:10 AM
It's coming along great Bill! I have the same kit, with the MK tracks, and an RB models barrel in the stash. Watching this build is inspiring me to pull it out of the pile. I've never used the MK tracks yet, but I like how they "sag". And they are cheaper than Fruils! Keep up the great work!
Nate
    July 2003
  • From: On my kitchen counter top somewhere in central North Carolina.
Posted by disastermaster on Tuesday, August 24, 2010 8:30 AM
Dang BIll...........100 and ..........how many now???
                                               http://i827.photobucket.com/albums/zz192/denistephenson/smileys/jawsmiley.gif
Looks like 'ya pulled another one out'ta the hat.
Everything is always so neat 'n proper.
I can always spot a "Bill Build"...... http://i63.photobucket.com/albums/h137/angel3210/coffeehouse/sm%20smileys/sm-x-spot.gif
  ............and that's a good thing.
http://i827.photobucket.com/albums/zz192/denistephenson/smileys/shakehands.gif
http://i20.photobucket.com/albums/b232/gluetank/Decorated%20images/th_T1-4-copy.jpg
 https://i.imgur.com/LjRRaV1.png
    July 2004
Posted by wbill76 on Tuesday, August 24, 2010 12:13 PM
Jet, thanks for the comments!
Nate, thanks as well, the kit is a fun one to build and glad to hear it's inspiring you to consider yours. MK tracks have become a staple of mine and they are a definite improvement over the Tamiya-supplied rubber-band tracks for sure.
Steve, this one is build # 106, this year has been a slower than normal production year due to all the summer distractions but this one's close to the finish line now. Appreciate the comments as always, the smiley king is always a welcome poster! Wink
    December 2008
Posted by New Hampshire on Wednesday, August 25, 2010 5:29 PM
Hey Bill,
Been a bit busy as of late so have not been able to keep up with everything, but I just browsed through the last couple pages since stopping in and I see you are coming along real nice.  You are consistent as usual, and this one is no exception!
Brian
    July 2004
Posted by wbill76 on Wednesday, August 25, 2010 8:02 PM
Thanks Brian, glad to have you stop in and sit a spell. Beer
    October 2007
Posted by panzerguy on Saturday, August 28, 2010 3:07 PM
   Bill shes looking good! As always an outstanding jobYes
   It was mentioned that they only have one aiming pole and like another 13bravo mentioned an arty piece would have two. By looking at that pole it looks like it would be about ten to eleven feet tall when put together the tallest I've ever seen was about seven. You said that the kit poles were in rough shape. Could it be possible that they were supposed to be two seperate poles?
"Happiness is a belt fed weapon"
    July 2004
Posted by wbill76 on Saturday, August 28, 2010 3:42 PM
Steve,
That's a good question...when I measure the two halves of the pole, they come to 9.5cm in total length including the tip that would go into the ground. That scales out to 332.5cm on the real deal or right around 10.9 feet in length. I have no idea what the actual height/length of German artillery survey poles might have been but it does seem pretty tall to me! Wink They aren't meant to be two separate poles the way Tamiya has them molded...definitely molded as two halves of the same pole. The references in Achtung Panzer #7 show the same single pole arrangement so it's not an ucommon layout and they definitely aren't gun cleaning rods which is the only other possibility I could think of.
    May 2005
Posted by terry35 on Saturday, August 28, 2010 6:36 PM
Hi, Bill I finally got around to reading through this one. the kit looks just superd and the usual additions really do spruce it up. I'm not very fimilar with the kit as I not really a big fan of the Wespe. While I do realise that for a lot of people consider it one of Tamiyas better offerings I only opened a box to look at the parts and have never looked again since, so I suppose that you haveopened my eyes up to the possibilities of what can be achieved with this kit. I can also remember a time that the only 1/35th kit was by NKC, resin and expensive.
keep up the good work and I hope to around a bit more.
Terry.
    July 2004
Posted by wbill76 on Saturday, August 28, 2010 8:01 PM
Always a pleasure to have you drop by Terry! The Wespe kit is a little gem and builds up very nicely and just needs a few things here and there IMHO to dress it up. It had been sitting in the stash for quite a while waiting its turn and its number finally got called. I've been enjoying it immensely and just about have it across the finish line...depending on how things go tomorrow, it just may get done this weekend. Wink
    July 2004
Posted by wbill76 on Saturday, August 28, 2010 8:20 PM
Today's session was productive enough that it warranted its own update since tomorrow will likely see this one get across the finish line with the final touches.
Earlier in the week I had laid the ground work by sealing in all the previous paint work with a protective layer of acrylic Future floor polish sprayed through the airbrush. This was allowed to air dry for about 1-2 hours before I applied the decals courtesy of the Echelon set. Each decal was applied individually using ordinary water and carefully blotted dry with a paper towel scrap before applying Walther's Solvaset to get them to snug down tight to the surface.
Once the setting solution had thoroughly dried, I applied a second coat of Future via the airbrush to seal in and protect the decals and let that cure for a full 24 hours before starting the weathering process today. That first step was the overall application of an enamel Raw Umber wash using a round 0 sable brush. This inevitably darkens the finish and is a driver in the selection of the initial camo colors and basecoat mixes but also lays the foundation for the next steps of the weathering process.
That next step is the application of dot filters using small dots of MM enamel Flat White, Panzer Dunkelgelb, and Raw Sienna. The dots are placed with a small spotter brush and then blended together using repeated downward strokes with a square tip brush. The square brush is dipped in clean thinner and then blotted 2-3 times on a paper towel to remove the excess thinner before starting the strokes. Rinse and repeat until the dots are blended together and the desired effect achieved. Due to the high thinner fume exposure, I wore a breather mask the full time while working this step in the process.
The process was applied to the whole vehicle exterior working small sections at a time until the coverage was achieved.
Next up will be the application of a pin wash and then on to the pigments!
    April 2008
Posted by *INDY on Saturday, August 28, 2010 9:39 PM
FLAWLESS
"Well...you gunna pull them pistols, or just whistle Dixie?"
