U.S. NAVY Chevy Step Side Task Force PU
    January 2006
Posted by SprueOne on Friday, February 3, 2012 9:51 PM
My current kitmash project in 1/25.
This is a pre-CUCV and pre-MILCOT, U.S. NAVY '55 Chevy Step Side Task Force Second Series.
The prototype picture is from my dad's film footage of this pick up truck in the Philippines around 1955 - 1958.
These are the two kits where most of the primary parts will come from.
I start with the Chassis and suspension
The holes are tooled onto the wrong side (top side) of this part. I have to drill new holes using the holes on top to register the correct positions.
The iSheets indicate location for these exhaust parts, but there are no holes for the pins.
I had to drill hole at 1/16" through the top side of the chassis frame part.
building continues... thanks for looking Paradise
Anyone with a good car don't need to be justified - Hazel Motes
Iron Rails 2015 by Wayne Cassell Weekend Madness sprueone
    July 2004
Posted by wbill76 on Saturday, February 4, 2012 4:11 PM
Ought to make for an interesting project, look forward to seeing what you do with it. Beer
    May 2005
Posted by terry35 on Saturday, February 4, 2012 5:59 PM
I love it, it's a great idea, I know nothing about the subject but I sense from your work so.far that this will be a build close to the heart. I look forward to seeing progress.
Regards,
Terry.
    July 2006
Posted by redleg12 on Saturday, February 4, 2012 8:57 PM
Outstanding and different. Nice to see something unique
Rounds Complete!!
"The Moral High Ground....A Great Place to Emplace Artillery."
    January 2006
Posted by SprueOne on Saturday, February 4, 2012 10:45 PM
Thanks for all the replies and looking in on the build.
The interior door handle deatil tooling wasn't satisfactory so new ones were scratch built from parts from a cassette recorder and a disposable lighter.
Then some work on the seat back detail with filler putty
Tags: Chevrolet
    January 2006
Posted by SprueOne on Friday, February 10, 2012 10:39 PM
progress continues . . .
Painted the chassis flat black for now and cleaned up the flash on all the AMT/ERTL kit parts for assembly of the bed and step side fender parts
next is more on the cab interior . . .
    January 2006
WIP - U.S. NAVY Chevy Step Side Task Force PU
Posted by SprueOne on Sunday, February 12, 2012 5:19 PM
I'm jumping around on this build
Careful and extensive online research revealed pictures of what the shifter base plate and auto-tranny cover plate looks like. Then I realized that I'm going to install a floor mat so the hole and any scribed in plate parts will not be seen anyway . . .
Cab floor transmission cover photos:
manual tranny shifter base plate
base plate cover w/o shifter
I'll probably use this piece of styrene or textured paper.
I also realized this 'unseen' fact regarding the gas tank part as well. . .
Tags: Chevrolet , 1/25
    July 2006
Posted by redleg12 on Sunday, February 12, 2012 6:43 PM
You may be jumping but it is understandable and coming together nicely. I love the door handle work
Rounds Complete!!
    July 2004
Posted by wbill76 on Sunday, February 12, 2012 7:59 PM
Ditto to Mike's comments...the detail work you're putting into this one shows. Beer
    March 2007
Posted by JEFFB on Monday, February 13, 2012 9:07 PM
Great work on your step side!!  ditto the door handles, cool idea!!
Heliman
    January 2006
Posted by SprueOne on Monday, February 13, 2012 10:10 PM
Thanks for the comments. Tonight I'm working on the tail lights, all four of them
Tags: kitmash , Chevrolet , 1/25
    January 2006
Posted by SprueOne on Saturday, February 18, 2012 8:42 PM
The rear turn signals needed to be built and installed. These were made with the parts from the this AMT Dodge pickup kit parts 65.
They are the correct diameter so I used them.
Digging them out of the kit box I notice that they are bad bad, terribly tooled parts.
back
front
I reshaped the back with tube putty
Clear lens parts from the spares box were sanded down to an appropriate thickness
The bracket was an electronics component. The lens looks weird in this picture because they are tacked in place with tac-putty temporarily
Bolt details were made by slicing hex rod then gluing them in place next to the tailgate hinge on both sides
This pickup is a small rear window cab version. Work will continue on this . . .
Thanks for looking in
    January 2006
Posted by SprueOne on Monday, February 20, 2012 10:38 PM
I found a picture online that was directly behind the cab. After resizing the image it was printed to scale. From this I can cut out the shape and use this for a template, as pictured in the above post.
I didn't take measurements from a 1/1 pickup truck to scale from. I'm working this one visually which is the way I usually build models. If it looks right then it is
the window part has a weatherstrip detail along the edge around this part that has a thickness beyond the glass
I needed to uniformly fill the 'glass window' area inside the weatherstrip bead with material cut to the correct shape. I don't know the thickness of this material, I just placed them against each other and ran my thumb over it. It felt smooth and flush so I used it.
To get the exact shape right, I burnished a piece of paper over the detail shape of the window part
Then this was penciled in for better clarity. This was then cut out with scissors and transferred to the styrene (for sale sign) sheet. Then the styrene material was cut out to the proper shape
This was then shaped over a steel block for better conformity
Crazy clampidge while the glue set
After glue set, automotive product Body Filler was used to fill the gaps around the 'glass window' part that this kit is famous for
.... progress continues ...
    January 2006
Posted by SprueOne on Saturday, February 25, 2012 8:43 PM
The rear window body work is finished with only the window weather stripping to install.
What type and shape of material would you recommend for this?
I found the tiny chain for the tailgate limiter from a craft store in the jewelry beading department.
thanks for looking . . .
    April 2005
Posted by JohanT on Sunday, February 26, 2012 9:06 AM
SprueOne
http://i91.photobucket.com/albums/k290/SprueOne/1955TaskForce/55TaskForce_intDoorParts.jpg
I have started to look in a different way at "disposals" :)
Very interesting build, thank you for sharing!
Very Best Regards
Johan
    April 2009
Posted by deafpanzer on Sunday, February 26, 2012 10:49 AM
I have been lurking but no more... I am really enjoying this build.  My dad would have loved to see this as he is fan of old times trucks.
Andy
    January 2006
Posted by SprueOne on Sunday, February 26, 2012 8:43 PM
Thanks for checkin in fellas.
The weather stripping fro the rear window is next. Any ideas?
    January 2006
Posted by SprueOne on Monday, March 12, 2012 3:42 PM
I've received several ideas from different sources for making the rear window weather strip.
I'm going to try this with styrene rod.
I'm forming the rod by bending it by hand. Then Crazy Glue (CA) in place as I go along.
    July 2006
Posted by redleg12 on Monday, March 12, 2012 6:22 PM
Interesting idea...looks like a good solution
Rounds Complete!!
    July 2003
  • From: On my kitchen counter top somewhere in central North Carolina.
Posted by disastermaster on Tuesday, March 13, 2012 1:22 PM
SprueOne
http://www.nefsak.com/images/T/64-013.jpg
Radioshack .022 Silver - Bearing Solder.
Easily holds its shape and can be super-glued into place.
 https://i.imgur.com/LjRRaV1.png
    January 2006
Posted by SprueOne on Tuesday, March 13, 2012 10:22 PM
hey redleg12, yup it worked.
disastermaster, if it didn't, that would've been the alternative material, thanks for tip
A sharpened pencil tip was used to shape and hold each radius because of the variable corners and the porous wood material broke free easily from the CA where it touched
The lower piece at the bottom of the cab cracked free during this over handing but that's cool, it's fixable
Tags: Chevrolet
    May 2009
Posted by Pawel on Friday, March 16, 2012 5:09 PM
Hello!
A very nice truck and an original idea, too! Too bad they don't make'em in 1:35, isn't it? Good luck with your project, have a nice day
Paweł
www.vietnam.net.pl
    January 2006
Posted by SprueOne on Sunday, March 18, 2012 12:12 AM
Hi Pawel, yeah true that.
Thanks for looking in my build thread
    January 2006
W I P : U.S. NAVY Chevy Step Side Task Force PU
Posted by SprueOne on Monday, March 19, 2012 10:44 PM
While I'm trying to figure out the front windshield and it's bogus fitting glass part. ...
I finished the seat back detail to match the seat bottom seam part.
Sprue was stretched to the same diameter and then glued, trimmed and sanded in place
match is made
    March 2006
Posted by Shellback on Monday, March 19, 2012 11:42 PM
Nice w.i.p. you have going here Yes
    January 2006
Posted by SprueOne on Tuesday, March 20, 2012 9:21 PM
Thanks lookin in Carl Cool
    March 2006
Posted by Shellback on Tuesday, March 20, 2012 11:29 PM
...........Yes
