tanker bar
    June 2008
Posted by Hans von Hammer on Saturday, May 26, 2012 2:05 PM
When I was on M101A1s, we had two Donkey D icks in the section chest.. The afore-mentioned fuel can spout, and this one:
This one was removable.. It was just a round steel rod (wieghed about 10 lbs) that was pointed on one end to fit into the end of the left trail in order to move it... It was never left in place (as many modelers of the M101/M2A1 do) once the gun was laid and emplaced, because you WILL walk into it at night if you leave it there, and it WILL hurt...
 Bad enough that the lunette (the thing on the other trail, that hitched to the truck) is also out to getcha... At night, we stuck an aiming post section in it for safety.  But that sucker WILL put a damn-damn on your shin...
Oh yeah.. It was also a perfect place to set your steel pot of shaving-water on in the morning..
    September 2005
Posted by treadwell on Saturday, May 26, 2012 3:11 PM
Hi guys, this is the finished tanker bar with the afore mentioned dimentions.
I just have to make the 'leather ' straps and buckles.
Shell, to answer your question, this is Tamiya's 1/16 M4 105, not an M4A3E8, although they make conversions and turrets to make one.
The model has undergone lots of changes the only Tamiya parts left is the aluminum tub chassis, running gear and upper hull bare shell
I built it about 4 yrs ago and it is undergoing minor upgrades and new paint. (the paint in these pics is 'in process', so go easy LOL) I thought sure you must have seen it. When I'm done maybe I will post a pic or 2.  I am just trying to get some ' fine motor skills' back since my surgery,  but it looks as though I am going to need another anyway.
thanks everyone for the help
tread
    March 2006
Posted by Shellback on Saturday, May 26, 2012 7:37 PM
Tread , now i see that i made some mistakes on the mounting of the "tanker bar" on my M4A3 . 1 or 2 pics of your M4 105 will not be enough .  Yes
    June 2008
Posted by Hans von Hammer on Monday, May 28, 2012 9:34 AM
... this is Tamiya's 1/16 M4 105, not an M4A3E8, although they make conversions and turrets to make one...
Ain't the chasis about the same for both? Both have the HVSS suspension right?
Posted by Rob Gronovius on Monday, May 28, 2012 9:54 AM
Suspension is the same for the M4 105 and the M4A3E8, but the main portion, the hull and powerplant is different with the M4 having the radial engine and the M4A3E8 having the Ford GAA. A simple turret swap won't get you even a 50% solution. The entire back deck including most fuel and other filler spots and even the rear portion of the hull will differ. The running gear is about the only thing alike.
Tread, that is a good looking job. I've got the old (from around 2000) Tamiya M4 105. I remember my hands hurting from assembling the metal tracks and always breaking track (just like a real tank) when running it R/C.
    June 2008
Posted by Hans von Hammer on Monday, May 28, 2012 10:24 AM
Sherman variants & sub-variants have always eluded me, Rob.. Dunno an M4 from an M4/A-whatever... Only things I knew were that there was a cast hull version, a welded hull version, "Screamin' Mimi"version , a 105 howitzer version and the hatches would vary, and that there was a VVSS and an HVSS (Which I knew was on the "Easy -8" and "Isherman"), and that the Iraeli Sherman had a Frog 105 gun and bigg-azzcounter-weight on the turret...   And that was a LOT more than I know about German armor, what with all "Aufs"-stuff on 'em..
Now, ask me about M109s, well.... That's another matter altogether, lol..
Sherman variants are probably as confusing for me as it is for Clankers not knowing about all the variants of a Messerschmitt, Spitfire, Zeke, or Mustang, lol..
Guess I'll stick to "Accessories, Gear, and Stowage" when it ccomes to things that go, "Clank", lol..
Posted by Rob Gronovius on Monday, May 28, 2012 11:14 AM
What confuses most people about Shermans is that they tend to think of them as sequential; like the M4 then M4A1, M4A2, etc. when in fact, they were produced almost simultaneously in a parallel fashion.
For instance, the M4A1 came first but the US lacked the widespread ability to produce a cast hull so a welded hull M4 was also produced. Virtually identical except for the material of the hull. Both were powered with radial engines.
Then when the aircraft industry needed radial engines and got priority over the tank industry, the Ordnance Corps tried various engines leading to the twin diesel M4A2, Ford GAA M4A3, and the Chrysler multibank M4A4.
The diesel engined A2 didn't see widespread US Army use because we knew a thing or two about logistics and the non-standard fuel would double the logistics load. We shipped them to allies and the Marines (who had more ample supplies of diesel because of ship use). For the allies, well, beggars can't be choosers.
The M4A3 became standard US Army use because of the gasoline engine.
The M4A4 (British called it Sherman V) had an over complicated 5-engine design and was rejected from standard US use. The Brits got them because it was still better than any tank they could field and they could get them quicker and in superior numbers to what their industry could produce. It was sort of a dead end of the Sherman branch.
Because of their parallel development, you'll see M4A4s (what you would might think of as a later Sherman variant) with earlier features than an M4, M4A1, M4A2 or M4A3 that continued to be produced and improved as the war went on.
Also many improvements took place during production. In the drive to make as many tanks as possible, just because new designed parts are developed, doesn't mean you stop using the old design parts. They are used until the supplies are exhausted.
The US Army was a master rebuilder. As territory was overtaken, depot rebuild facilities were set up and damaged and detroyed tanks were cobbled together and returned to the supply chain and eventually to the front lines. Then you end up with a mishmash of Sherman variants (late parts on early or mid tanks and vice versa).
Then add the Israelis getting these second or third hand and continuing to cobble them together and things get even more mixed up. Bottom line, it is had to say what can and can't be on Shermans. Although the 105mm howitzer was only produced and fielded on late M4 or M4A3 hulls.
Sherman turrets are a whole 'nother animal as well; low bustle, high bustle, 75mm vs 76mm, 76mm guns retro fitted into 75mm turrets (ala Kelly's Heroes tanks).
    September 2005
Posted by treadwell on Monday, May 28, 2012 12:10 PM
Thanks,Rob, for the clear concise explanation.  Even the Hunnicutt bible never really gets to the point : they were made simultaneously , and I think you are absolutely correct that is where much confusion arises, both for history buffs and model builders alike. I like to research everything I build. I even got out the 'bible' just for the tanker bar.
Thank you for the compliment on my job, and I hope you are having a terrific Memorial Day. God bless all who serve.
Best regards,
treadCool
    July 2003
  • From: On my kitchen counter top somewhere in central North Carolina.
Posted by disastermaster on Monday, May 28, 2012 1:56 PM
Shellback
......i see that i made some mistakes on the mounting of the "tanker bar" on my M4A3 ......
http://wordforge.net/images/smilies/meme.gif
This should make it clear for you.
Front location designed for the square and angled end
http://www.toadmanstankpictures.com/alabama_m4a3e2_58.jpg
 and the rear location (smaller size?) for the smaller rounded end (although it might? possibly be placed in a reverse position also)
http://www.toadmanstankpictures.com/alabama_m4a3e2_51.jpg
  I'm out'ta here......http://wordforge.net/images/smilies/flamingmob.gif
 https://i.imgur.com/LjRRaV1.png
    September 2005
Posted by treadwell on Monday, May 28, 2012 2:29 PM
Heya Steve :  )
I have them showing both ways, some fancy and specialized as your example and some just angle iron or  ' U  ' channel.... and of course different for each chassis. I must say I haven't seen this type mount yet, but I like it...it looks like maybe M4A3E2...I might scrape off my end holders and flip it... it would be easy... I DID find out the different lengths  ... the shorter one is 4' 9''  ...so just a 3" difference
thanks for the help,buddy !  Have a nice Memorial day
yer pal
tread
    March 2006
Posted by Shellback on Monday, May 28, 2012 10:17 PM
Steve , thanks . I will keep the pics for my next M4 .Yes
    July 2003
Posted by disastermaster on Tuesday, May 29, 2012 8:54 AM
http://freeemoticonsandsmileys.com/animated%20emoticons/Buddy%20Animated%20Emoticons/true%20buddy.gif  Carl and Carls... glad to help.
And yep, that's from a M4A3E2.
 Hope y'all had a nice holiday.
    September 2005
Posted by treadwell on Tuesday, May 29, 2012 9:45 PM
Hi guys :  )
I hate to beat a post to death, but sometimes you get new reference or someone posts a new picture and things change .  When I build a model, I just try to do the best I can with the available data.
Thanks, Steve ( diaster master) for posting that pic.(M4A3E2).. I hope you , and others like how I have translated  your data. I think it is finally correct , although alternatives are out there.
Thanks,
tread
Posted by Rob Gronovius on Tuesday, May 29, 2012 10:26 PM
Looks good, great work. I know researching can be a royal pain. Shermans will always be popular because even though they all look alike, there are so many minute differences, even within a single model line, vehicles built at one plant had unique characteristics from the same exact model built at another.
Sort of like when the Abrams came out. There were slight differences between a tank built at the Detroit plant and the Lima, Ohio plant.
    July 2003
Posted by disastermaster on Wednesday, May 30, 2012 7:07 AM
   http://files.myopera.com/debplatt/smiley/browraise.gif   Excellente' mon ami!http://files.myopera.com/debplatt/smiley/bow.gif
You'd never know it had ever been any other way.
That hand of yours must have recovered nicely.
    March 2006
Posted by Shellback on Wednesday, May 30, 2012 10:32 AM
Tread , that forward bracket on the bar looks completely like Steves pic Yes What is it made from , brass sheet ?
    September 2005
Posted by treadwell on Wednesday, May 30, 2012 11:23 AM
Hi Shell :  )   .... it is .010 " styrene, cut and carved with the tip of my trusty # 11 blade.  It is very fragile, but gluing it on the hull gave it strength....brass would have been the way to go, but I do not have a bending tool yet.
thanks for checkin' it out!
treadCool
P.S. my next thing (after I finish the repaint) for my Sherm is the commander... I'm dreading it, but I think I will assemble him today
    March 2006
Posted by Shellback on Wednesday, May 30, 2012 11:35 AM
Tread , dont dread ..........Hmm........hmmm , anyway, its another challenge that you will master .Yes
