Academy MerkIV WIP
    September 2006
Posted by RBaer on Monday, June 1, 2015 4:23 PM
Ah, yep.
So I came back from Scalefest all jazzed up, and dove back into the man cave Sunday night while my sweetie was having a girls' night....
I decided to mark this for a tank on exercise, and some of the pics I have show them filthy, with old and new mud packed up in the suspension. I don't want do make it "muddy", but I do want to make it look like it has been through mud, so I'm building up some dried mud (good logic, huh?) around the suspension.
Above, the side skirt is not glued, there just for the pic. It has a brown wash, then a black pin wash, same as what I'm doing everywhere.
Turret below:
Tool bags are painted, other detail painting mostly done, washes on.
And the gratuitous "heinie shot":
Tracks (above) are primed and washed, will get some more washes.
And finally, the wheels and other bits:
Dust next.
Apprentice rivet counter.
Posted by midnightprowler on Monday, June 1, 2015 4:31 PM
Awesome!
Hi, I am Lee, I am a plastiholic.
Co. A, 682 Engineers, Ltchfield, MN, 1980-1986
1 Thessalonians 4:13-18 1 Corinthians 15:51-54
Ask me about Speedway Decals
    January 2007
Posted by the doog on Monday, June 1, 2015 8:22 PM
Yeahhhhh, that's just coming along superbly!
I hope my turret comes out as good, eventually!
    September 2012
Posted by GMorrison on Tuesday, June 2, 2015 11:43 AM
Looking good. Motivation to finish my M4.
I really suggest against Sharpies. If it's worked for you, fine. But they turn out to be really dark blue, not really black and it can show up under the right light. Also I found out the hard way that Dullcote dissolves the ink, and it bleeds all over the place.
Speaking of Rustoleum, I like the stuff too and use it on the bottoms of my ships. But recently I bought a can of their classic red primer, and after using maybe a quarter of it, it just stopped working. It's not the tip, that is nice and clean. Something in the can to do with the valve, just froze. I've tried about everything, including yes poking a skewer down the tube, to no effect.
$ 8.99 pain in the hiney.
So I went online and since I believe everything I read on the internet, this does seem to be a problem.
Shootski!
    September 2006
Posted by RBaer on Tuesday, June 2, 2015 1:22 PM
Krylon! Never fails, always sprays fine....
G, I've had to dribble a little brake cleaner in the valve of some cans, nozzle off, and it usually works.
    September 2012
Posted by GMorrison on Tuesday, June 2, 2015 1:27 PM
What is it made of?
    January 2007
Posted by the doog on Wednesday, June 3, 2015 9:15 AM
GMorrison
Shootski!
I agree with you about the Sharpies.
With the Rustoleum, have you tried writing to the company? And how about decanting it? I usually use decanted Krylon gray primers. That could help you at least avoid the freezing-up issue?
    September 2006
Posted by RBaer on Wednesday, June 3, 2015 10:04 AM
G, are you asking what brake cleaner is made of? Id so, I have no earthly idea, but it also makes a great upholstery cleaner, learned that as a dealership tech at Acura and Lexus.....
Same with Sharpies in my experience, they're funky. Tamiya's ink pens work better, but I still just hand-paint. After a dark detail/pin wash, nobody knows the difference, and I have an infinite range of colors available. Sometimes I'll sue an almost pure black for a "new" tire, and faded blacks or even burnt umbers for "old" tires, mixing them up on in-service vehicles, especially IDF.
    September 2006
Posted by RBaer on Thursday, June 18, 2015 3:27 PM
Argh, tracks. SpadeAce tracks are cast off-kilter, something I just now noticed, making fit on the sprocket difficult. In a huff, I pulled some Friuls being held for another build and quickly put ten together to check on the Academy Sprocket. No go, pitch is different. So I pulled the sprockets Friul supplies with the tracks, and shoot me, they don't fit the Friuls either.
Rather that stick the whole thing in a box and bury it in the stash, I went ahead and installed the tracks, just for grins:
Now if I can get over my disgust with the nasty looking Academy B&C on the turret, I may just wrap this thing up. If I think too hard about it, it's gonna get hidden and forgotten about, and not in a good way.
    September 2012
Posted by GMorrison on Thursday, June 18, 2015 4:30 PM
Maybe the Friul sprockets work with the SpadeAce tracks?Pirate
    September 2006
Posted by RBaer on Friday, June 19, 2015 10:34 AM
Tried that too......  nyet.
So I might have a little time tomorrow, and I'm going to do two things: One, pop the turret onto the hull and see if the dang ugly balls are bunched up on the hull like I just saw on another build of the exact same model, and if so stuff this model back into the box and forget about it for a while; and two, take another look at the Friul tracks and sprocket and determine if the over-size Friul sprocket teeth can be re-shaped so as to fit the Friul tracks. If not, into the box it goes.
Should all things work out, or at the very minimum the balls not dragging all over the rear deck and wrinkling up the PE "chains", I may just leave the SpadeAce tracks on and wrap this thing up. The problem with that is that I'm just not in a happy place with this thing, and I drug something out from underneath a pile of spare parts the other night that I might play with:
Hmm,  I need something easy.
    May 2009
Posted by Pawel on Monday, June 22, 2015 2:10 PM
RBaer - I say that tank looks good, although I can see that about the ball and chain. It's probably best to give it some time, take a fresh look some day. Good luck with your projects and have a nice day
Paweł
www.vietnam.net.pl
    September 2006
Posted by RBaer on Monday, June 22, 2015 2:16 PM
Thank you, Pawel. That's my plan, because you never know, I may get motivated one day and give some proper ball and chain another try.
Posted by midnightprowler on Monday, June 22, 2015 5:04 PM
Well done.
    March 2013
Posted by garzonh on Tuesday, June 23, 2015 9:47 AM
Very nice...it's very difficult to get color tone variations on modern vehicles and monotone, since they do not rust, get that damaged and un-mantained for long periods of time versus WWII armor.
I also have a Merkava on my stash...next build in the line...and want it to put it on a city dio...will see.
I like the color you used.
    September 2006
Posted by RBaer on Tuesday, June 23, 2015 10:18 AM
Lee, thanks.
Hugo, I agree, and add in the factor of modern paint, which is tough stuff. It leaves weathering as the main element in tonal variations.
I'm happy with the color also. I think it's extremely close to what I can see in some very good color pics, and it's Krylon.
Merkavas work well in urban dios, plenty of pics to go by. Have fun!
