1/35 AFV Club M-60A1
    January 2015
Posted by M. Brindos on Thursday, October 15, 2015 3:15 PM
I'm not sure when the bilge was added or if it was like other options that simply depended on who added the upgrades. To answer that question you'd need to have a source reference or specific photo I assume.
If only I'd been paying attention I wouldn't have cut all of those axles off, dangit lol. But yes, those M-48 wheels are beautifully done. Cudos to Def Model for those.
As to the adding of AM parts... I figured I'd just slap those resin top loaders on there and be done with it, but they are not as nice as the kit parts. They are that well detailed. So I pulled the kit's side loaders apart and I'm happy with what AFVC has provided.
If this is any indication of the dedication to accuracy they have then I'm a fan.
- Mike Brindos "Lost Boy"
    May 2009
Posted by Pawel on Thursday, October 15, 2015 3:05 PM
Hello Mike!
So that's the question now - bilge or not to bilge? :D
Those steel wheels are really beautiful - the M48 will benefit from them. And the AFV Club gives you two sets anyhow - ain't that lovable? And yeah, that kit is so good in places, that it's hard to add aftermarket sometimes - I've noticed that too.
Good luck with your build and have a nice day
Paweł
www.vietnam.net.pl
    January 2015
Posted by M. Brindos on Wednesday, October 14, 2015 3:38 PM
Hi Pawel!  :D
Yes, I think that part is for the bilge pump is B4. It sticks out by the heater exhaust. Not sure if you should have that for the CEV or not.
Funny you should mention that top loading air filters lol! I just got the call about that and the steel wheels. I need to change the boxes out and the wheels need to be aluminum. Those steel wheels were supposed to be for my M-48 build. [sigh] I need to build 'em one at a time I guess lol. Miscommunication is a shot trap.
Good thing I didn't glue any of these parts on yet lol.
    May 2009
Posted by Pawel on Wednesday, October 14, 2015 3:18 PM
Hello Mike!
Now I know what those little thingies on the air cleaners are. I don't need those on my CEV neither - I've just forgotten to fill the mounting hole for them. I'll do that now.  The parts meant here are F7 and K32 on both sides. The billge pump nozzle - would it be the B4? Would that part be there on my late-sixties CEV?
As for the AOS variant - I read it should sport the top loading air cleaners?
Your model is lookin' good - good luck with your build and have a nice day
Paweł
www.vietnam.net.pl
    January 2015
Posted by M. Brindos on Wednesday, October 14, 2015 2:21 PM
Thank you, Gamera.  :)
The battery box fits between the two bulges on the inside of the hull that the bumb stops fit into on the outside. I'll be painting it all black later to finish it off.
Thanks, Bish.
I needed to make it so the battery wouldn't go sliding into my turret basket lol.
Posted by Bish on Wednesday, October 14, 2015 2:04 PM
Some great progress there Mike and a real nice job getting the fit for the battery.
Posted by Gamera on Wednesday, October 14, 2015 1:54 PM
She's lookin' good Mike! Yes
    January 2015
Posted by M. Brindos on Wednesday, October 14, 2015 12:44 PM
    January 2015
Posted by M. Brindos on Thursday, October 8, 2015 9:37 PM
That's what the lights are for.  :D
Posted by Tojo72 on Thursday, October 8, 2015 9:28 PM
Unbelievable detail,can't believe that interior is going to be closed up.
    January 2015
Posted by M. Brindos on Thursday, October 8, 2015 1:13 PM
Pawel - Yes. There is a folding rack that attaches to the turret ring that holds them in place up top. They lift out of the way when the loader needs to grab a round. I haven't added it because my basket isn't attached to the turret ring as it should be and it would just cause problems. Besides, it's up and above where you can see it from the driver's position so you wouldn't see it anyways.
I haven't seen any rubber pads on the floor in any of my references, but they are mostly of the training simulator and a lot of details are missing. My Dad has been filling in the gaps and pointing out what should be different for the actual combat vehicles.
Arty- That's some info I didn't have yet. Thank you! I was also wondering about that.
I've been watching a lot of videos and documentaries on these tanks and there always seems to be hatches left open at all times in every situation where you think it would be much wiser to shut them.
Seems the honest answer is, that when they are all closed you can't see hardly anything at all. Those hatches are almost ALWAYS open because the crew values being able to see and that gives them greater combat awareness. Even if that means you can take an RPG to the loaders hatch and get your crew killed.
I've got the front hull glued on and all of the interior installed. However I did not anticipate one problem that I can not now fix. The driver's vison blocks, since they are clear parts, allow light to show through where the paint is thinnest. I'm just going to have to suck it up on that one as I didn't test for this. I was mainly concentrating on not leaving parts out that I had set aside weeks ago, such as the driver's hatch and the steering bar.
But I do have a couple of good pics and the interior looks sufficiently busy.
I'm okay with this. Not bad at all. Could be much better, but since you'd really have to look very close to see it, "That'll do pig, that'll do." lol
Posted by HeavyArty on Wednesday, October 7, 2015 2:31 PM
Pawel
Gino - how about a situation, where the top hatch couldn't be open? I don't know, like in an NBC situation, or airburst rounds exploding overhead or something like that?
The hatch may be left partly opened and then closed again after the round is ejected.  The NBC situation wouldn't matter as the M60 series did not have overpressure and the turret/hull are not sealed from NBC contamination.
    May 2009
Posted by Pawel on Wednesday, October 7, 2015 2:27 PM
Hello!
Lots of good info here! I didn't know that about the shell casings! How about that ready rack - do the rounds just stand there on their bases or are they secured in any way?
In my CEV I have a different arrangement but I also have rubber pads on the floor, so I'm wondering about that.
Mike - good luck with your build, it's looking really good, and have a nice day
Paweł
www.vietnam.net.pl
    January 2015
Posted by M. Brindos on Wednesday, October 7, 2015 11:57 AM
No I'm not leaving them in there, Arty. That was just for those pictures. I plan on having them tossed out of the tank once I have a base to put this build on.
I did notice that no U.S. tank has any kind of brass catcher in the turrets at all. I felt it was safe to assume that meant that they don't let them pile up inside.
Even if I had thought they did, your words of advice certainly would change my mind on that subject.  :) You would know better than I, right? Thank you for having my back on that!
Posted by HeavyArty on Wednesday, October 7, 2015 11:41 AM
The empty shell casings look good.  The color and finish look fine to me.  One thing though, do you plan on leaving them piled up inside the turret like that?  If so, the loader has nowhere to stand.  Usually, the loader will leave his hatch open and toss them out there as soon as they are fired.  He usually didn't leave them in the turret due to the cramped space and nowhere to stand if he did.
    January 2015
Posted by M. Brindos on Wednesday, October 7, 2015 11:36 AM
    January 2015
Posted by M. Brindos on Monday, October 5, 2015 7:56 PM
Details painted and cleared in preparation for weathering.
Nothing fancy or special going on here quite yet. Thanks for looking. :)
    January 2015
Posted by M. Brindos on Monday, October 5, 2015 12:03 PM
I sprayed some light grey/white over a medium grey this morning and I have some good results. I'm sure this will look pretty good after I add some mild weathering to make it match the rest of the inside and get the details painted.
I did not get any pictures yet of the view from the top hatches but it doesn't look too shabby already.
The shading is light and subtle just the way I prefer it. I'm back on track. :)
    January 2015
Posted by M. Brindos on Sunday, October 4, 2015 9:09 PM
No update today. I had to change something and it went back into primer again. :/
    January 2015
Posted by M. Brindos on Saturday, October 3, 2015 3:27 PM
Thanks guys! :)
They are not showing up as underlined to me at all. Not on my screen anyways. That's odd.
I still haven't got these pieces into the paint dept. lol I need to get on that so I can move forward.  :) Yes
    May 2009
Posted by Pawel on Saturday, October 3, 2015 7:51 AM
Hello Mike!
Nice detail! Now I have to scratchbuild some of that too - I'm leaving the driver out of his hatch, so I'd like to show the viewer something nice!
As for those underlined lines - somehow they are formatted as links, and so they are underlined. Did you set them up as links yourself, or did the new format do it for you?
Paweł
www.vietnam.net.pl
    January 2015
Posted by M. Brindos on Friday, October 2, 2015 11:01 PM
Thanks Karl. Its not nearly as detailed as it could be though. Just the basics in there and they're not even accurate lol.
??? I don't have anything underlined ???
    January 2007
Posted by the doog on Friday, October 2, 2015 10:13 PM
Wow, some really tremendous detailing, Mike. Quite a project you have going on!
One question---why does your text sometimes come out underlined? It's kinda hard to read like that..
