Trumpeter 1/35 12.8cm PaK 44 Waffentrager WIP
    January 2015
Posted by Moff on Monday, January 25, 2016 1:11 PM
Kit:
  • Trumpeter 12.8cm PaK 44 Waffentrager
  • Voyager 128mm K44 Barrel for Rheinmetall
  • Friulmodel Tracks for German 12.8cm PaK 44 Waffentrager
Possible additions:
  • Alliance Model Works 1:35 German WWII 12.8cm Pzgr 43 Ammo
  • Alliance Model Works 1:35 Late War German Vehicle Tool Set
  • Panzer Art WWII German 20l Canisters
"Gaiety is the most outstanding feature of the Soviet Union." - Josef Stalin
    May 2013
Posted by hogfanfs on Monday, January 25, 2016 1:14 PM
Moff,
Looking forward to seeing some WIP pictures!
 Bruce
 On the bench:  1/48 Eduard MiG-21MF
                        1/35 Takom Merkava Mk.I
    January 2015
Posted by Moff on Tuesday, January 26, 2016 1:03 PM
Ok, first update.
Unlike Doog, I have found Trumpeter's kit engineering to be less than satisfactory...if I have one modeling pet peeve, it's seam lines in inconvenient places. This kit has plenty of that. I've really only spent about 6 hours on this kit so far, as life has taken a busy turn. I've finished the suspension and spent a ton of time attempting to fill gaps.
Waffentrager Full Hull Starboard UnpaintedWaffentrager Rear Hull StarboardWaffentrager Rear Hull Port Unpainted #2Waffentrager Rear Hull UnpaintedWaffentrager Front Hull UnpaintedWaffentrager Front Hull Port UnpaintedWaffentrager Final Drive UnpaintedWaffentrager Bogies Unpainted #2
I have a couple questions for Doog, if he would be kind enough to answer them when he gets a chance.
From what I saw of your build Doog, you hollowed out these headlight thingies, correct? You didn't have a photo with a good view of the drilled out section, so I decided to wing it.
Waffentrager Hook Attachment Point Starboard UnpaintedWaffentrager Hook Attachment Point Port Unpainted
There you go: update number one. Like I said, life's gotten busy at present, so don't expect a deluge of posts for a while.
    December 2006
Posted by Jester75 on Tuesday, January 26, 2016 1:11 PM
Nice start! I'll be following along.
Eric
    January 2007
Posted by the doog on Wednesday, January 27, 2016 3:44 AM
Hi Moff!
Sorry to hear hat you're not quite enamored with the kit; yeah, it has some warts, but it build up nicely with a little care....anyway, I replaced those towing pintles on the rear if I recall according to my blog build on this, which is here if you don't have it marked...
http://cs.finescale.com/fsm/modeling_subjects/f/3/t/144480.aspx
--they were solid I recall now after reading it. I scratchbuilt new ones.
The gun assembly is a hoot; watch that seat when you remove it from the Sprite--it's a daisy if you don't cut it with care and you can ruin it if not careful. I'll try to help you out with anything else you might need an answer on; just leave me a call-out and I'll get back to you when I can; I'm in Europe right now business, so it may take a day or so..
Looking forward to seeing your take on this cool weapon!
Posted by Gamera on Wednesday, January 27, 2016 7:57 AM
She looks good Moff, and I know what you mean about putting seams where they're hard to get to without ruining the detail. I didn't notice you're adding all the extra goodies before- cool!
    January 2015
Posted by Moff on Wednesday, January 27, 2016 10:11 AM
the doog
But your scratchbuilt ones were hollow, correct?
    January 2015
Posted by Moff on Friday, April 29, 2016 8:10 PM
Here's a quick update. I've gotten the front hull and fenders on, but I haven't gotten much farther than that. I've basically taken a 4-month break from modeling after the intense JS-3 build. I finished the Waffentrager's wheels in February, and that was about it for 4 months.
My building skills are horrible, and you can tell in the pics. Oh well, I can say it's weathering...that's what I love about modeling Big Smile
Waffentrager Top Unpainted Waffentrager Front UnpaintedWaffentrager Front Unpainted #2Waffentrager Back UnpaintedWaffentrager Back Unpainted #2Waffentrager Back Angle UnpaintedWaffentrager Front Angle UnpaintedWaffentrager Front Angle Unpainted #2
    October 2015
Posted by Modelrob on Saturday, April 30, 2016 7:39 AM
We all need a brake sometimes the haul is coming along and looking good.
Robert
Posted by tigerman on Saturday, April 30, 2016 8:42 PM
I do like to see unusual subjects. This will be fun to watch.
 Eric
    January 2007
Posted by the doog on Monday, May 2, 2016 7:48 PM
Clean up that front seam, but other than that it looks like you're making decent progress!
    January 2015
Posted by Moff on Thursday, May 5, 2016 10:43 AM
the doog
Hey, thank you for giving me some criticism! Sometimes I'm dissapointed, because group builds seem to end up as a big echo chamber: lots of compliments going around, but no constructive criticism.
I'm into fine art (part of the reason my modeling participation has slowed a little) and I know from experience that constructive criticism is the best way to improve.
I'll be sure to do what you recommend! I'm very bad at filling/sanding, but I guess practice makes perfect. I actually need some new sanding pads, so I'll put that on my shopping list.
    January 2015
Posted by Moff on Thursday, May 26, 2016 7:08 AM
I've gotten to the point where I need to attach the muzzle brake. Unfortunately, the muzzle brake is a very thick piece of PE that needs to be bent into shape. I know basic soldering skills, so I could solder it, but I don't have any equipment or space. I do know somewhere where they have a soldering setup, so maybe I can pull some strings and use their equipment.
The other option is to buy an aftermarket metal barrel/muzzle brake. I might do that, because I'm lazy. Problem is, I need to be sure it's the right gun barrel and it's compatible with the kit...aftermarket manufacturers really don't seem very clear on stuff like that. It's hard enough even finding their products online, let alone figuring out compatibility!
I'll try to upload some pics soon.
    January 2015
Posted by Moff on Sunday, June 5, 2016 9:25 AM
Here are some WIP pictures of the Waffentrager. Please pardon the recurring smudge in the lower right corner, I didn't notice it was there until I was uploading the pictures.
I'm still a little nervous about how my filling will look on the finished piece, but you learn through mistakes I guess.
Waffentrager WIP Gun ChassisWaffentrager WIP Gun MantleWaffentrager WIP Main Hull
    January 2015
Posted by Moff on Thursday, June 9, 2016 3:41 PM
I'm waiting for a Voyager turned metal muzzle brake I ordered from Down Under, it's supposed to come before the end of the month. I'll be laying low until then.
    January 2015
Posted by Moff on Thursday, June 16, 2016 12:03 PM
I received the replacement barrel two days ago. I would have posted an update with pictures earlier, but when I had finally gotten around to downloading the pictures, I discovered that someone had been putting finger smudges on the lens againConfused
So, here's the rundown, currently without pictures.
The actual turned metal barrel that comes with the Voyager set seems decent. The details look like they could have been crisper, and it seems too light compared to the Trumpeter barrel, but it's okay.
The star of the show is the brass muzzle. Absolutely superb! It's just two pieces, and it looks great. I'll be fitting it to the Trumpeter barrel I think, since the connecting peg on the Voyager barrel isn't actually a good fit for the muzzle, and it looks like someone did a really bad job with the metal lathe, as it's really rough around the connecting peg. It takes a lot of force to jam the muzzle into place, and even then it's not quite flush.
This must have been an early product from when Voyager was a new company, because otherwise I can't explain the quality issues. Still, the muzzle is great, and that's all I care about.
    January 2015
Posted by Moff on Monday, June 27, 2016 1:00 PM
The building phase of the Waffentrager is done, bar some minor filling.
A special shout out to Doog for helping me scratchbuild pistons for the recoil spades...his guidance was crucial.
Waffentrager 12.8 Port ViewWaffentrager 12.8 Rear Port ViewWaffentrager 12.8 Both PistonsWaffentrager 12.8 Port PistonWaffentrager 12.8 Port Piston SideWaffentrager 12.8 Port Piston Side ZoomWaffentrager 12.8 Full Gun Turret PortWaffentrager 12.8 Gun Assembly PortWaffentrager 12.8 Gun Assembly Port ZoomWaffentrager 12.8 Gun Assembly Above RearWaffentrager 12.8 Gun Assembly StarboardWaffentrager 12.8 Muzzle
I'm still not entirely sure what I want my paint scheme to be - any ideas? This is what I'm currently aiming for, though I'm sure I won't be able to make it look this nice:
    March 2013
Posted by garzonh on Monday, June 27, 2016 5:08 PM
Nice kit. Im sure you will turn it to be a great kit!
I like this ...tank?...since it's in WOT.
Keep us posted, specially interested in the painting portion.
    January 2015
Posted by Moff on Friday, July 1, 2016 2:27 PM
garzonh
Thanks! The painting portion is my favorite too.
    January 2015
Posted by Moff on Sunday, July 17, 2016 7:46 AM
The hull and turret are primed and I am now moving along to the construction of the Friuls. I got one side done in 4 days, at the expense of my battered left index finger and thumb. It's amazing how uncomfortable just holding a lumpy piece of metal can be! Hopefully I can get a move on, I'd love to get this thing to the "real" painting and weathering stage soon.
Waffentrager Primed Front Port ViewWaffentrager Primed Port ViewWaffentrager Primed Port Turret ViewWaffentrager Primed Rear Turret ViewWaffentrager Primed Starboard Rear Turret ZoomWaffentrager Primed Starboard Rear Turret ViewWaffentrager Primed Starboard ViewWaffentrager Friul Links
    January 2015
Posted by Moff on Friday, August 12, 2016 6:19 AM
Sorry for being MIA for so long. This has not been my year for model building, apparently. After a lot of procrastination, I'm almost done with the last set of tracks.
    January 2007
Posted by the doog on Friday, August 12, 2016 2:47 PM
Wow, outstanding progress so far, Mott! You've really done this kit justice! The recoil shocks look tremendous as well!!! BeerYes
    January 2015
Posted by Moff on Sunday, August 14, 2016 8:51 PM
the doog
Thanks! The shocks were my first attempt at scratchbuilding, but all told they turned out okay. Your phenomenal job with Waffentrager is a great inspiration, and I appreciate all the helpful directions and tips you provided for the shocks.
    November 2012
Posted by feldgrau23 on Tuesday, August 16, 2016 5:17 PM
Moff,, some really nice work going on here. I look forward to watching your weathering for this. The King Tiger looked great!
    January 2015
Posted by Moff on Thursday, August 18, 2016 7:54 PM
feldgrau23
I actually never built a Kingtiger...are you thinking of the JS-3?
    November 2012
Posted by feldgrau23 on Thursday, August 18, 2016 9:38 PM
Moff
feldgrau23
My bad Moff. I miss read your post where you showed pics of the King Tiger. I thought you had built it!!
    January 2015
Posted by Moff on Saturday, August 27, 2016 12:49 PM
feldgrau23
Moff
feldgrau23
Ha! Big Smile I wish!
