Sherman Firefly 1/35 Tamiya/Tasca/Asuka
    January 2015
Posted by M. Brindos on Monday, November 21, 2016 9:07 PM
Yep. When I get to that exact same point, I have to push just a little farther. Just keep going, and remember, its a SLOW process. You really can't rush it and short cuts will leave you dissatisfied every time.
- Mike Brindos "Lost Boy"
Posted by Tojo72 on Monday, November 21, 2016 10:28 PM
Shoot straight from the bottle,clean up with lacquer thinner.
    August 2015
Posted by SpursN17 on Sunday, November 27, 2016 5:01 AM
A little bit of progress this week, I've been trying to work in daylight rather than artificial but it's difficult at this time of year!
Base coated the hatch pads and tools, lashed up one though by painting it a metal colour when it should be wood.
Used the oil dot technique on the hull and turret but kept the effect as subtle as I could, I don't like the 'stripy' effect that you can sometimes get. Also I didn't think that a Normandy Sherman would look as battered as one that had survived a few months under battle conditions, it'll probably get a good coating of dust though.
Left side before
Right side after
So subtle that you can hardly see it! I like this as you don't notice it, but would know if it wasn't there.
A bit more done to the 'lads' inbetween the Sherman work. The uniforms have been shaded and highlighted, just the boots/gaiters and the berets to do now. I still have to paint some insignia on the infantry, they will be from the Essex regiment as their headquarters were about 5 miles from where I live and they were fighting around Tilly sur Seulles, which ties in nicely with the Lancers tank. This has been a sharp learing curve for me but I'm detremined to do more figures in the future.
Thanks for looking (and the comments).
Posted by Bish on Sunday, November 27, 2016 7:57 AM
Nice work.I like the tools and the nice subtle weathering. Figures are coming along really well.
    August 2015
Posted by SpursN17 on Monday, December 12, 2016 3:43 PM
After a brief lull in the action I'm back, work is getting in the way of this project at the moment!
Sprayed the kit tracks with Xtracolour enamel as I thought that it would hold better on the flexible track better than acrylic, I used X504 Exhaust as this gives a nice dull bare metal colour. I thinned it with Lidl own brand paint thinner which worked a treat and dried really quickly. Not bad for 2 quid a tin. After drying the tracks were given a wash of Lifecolor rust (can't remember which one from the 'rust set' it was), then I applied some Vallejo metalcolor steel to the tracks with my finger. This was the first time I've used this paint and I was very impressed, definitely going to buy more of it.
I was recommended to use Alclad II Klear Kote Flat so on it went with my old Neo AB, I've got a new(ish) Iwata but I still like to use the Neo for general stuff like this. I left it for about two hours wondering when it was going to go nice and matt, a quick poke with my finger proved that it was now dry but still shiny? Buggerbuggerbugger, I forgot to shake the bottle before using it!
Another go over with the freshly shaken Klear Kote and all was well, nice stuff to use apart from some strings of dried clear shooting out of the AB but I think the air pressure may have been too high.
My next step was to give it a good dusting with ground up pastel chalks. I like to overdo this slightly as subsequent handling will wear it off and leave the dust in places where it will natuarally gather. I also put some dirt on top of the suspension units as I've seen this in a lot of photo's, the dirt was made from two pinches of compost from a window box, two pinches of sand from the grand-kids sand pit, and some of the pastel dust to colour it. I stuck it on by wetting the areas where I wanted it with the Alclad flat.
I put some of the dirt mix on the wheels but it didn’t look right so I had a go at it with a toothpick, it looked better without it.
This is where I am at the moment, still some final touches to do such as the antenna (anyone know if it's 1 or 2, and what length?).
Now on to have another bash at the figures, watch this space!
Posted by Bish on Thursday, December 15, 2016 6:46 AM
Looking nice, i like the dusting effects on the top. The tracks area bit to rusty for my taste and should have bare steel especially where thge road wheels run.
Look forwardto seeing your figures.
Posted by Gamera on Thursday, December 15, 2016 7:44 AM
How did I miss this? Great work there, looking forward to seeing her and the figures finished.
I just assumed it was supposed to be mud/dirt on the tracks instead of rust though.
    August 2015
Posted by SpursN17 on Thursday, December 15, 2016 8:35 AM
Thanks Bish/Gamera
The rust wash for the tracks was extremely  thin and only shows if you look very hard between the links, what you can see is mostly dust. The high points on the tracks were rubbed over with a finger wetted in Vallejo Metalcolor steel (this shows up best if you enlarge the second to last pic) but they still need some work, I'll probably use a silver pencil or some Xtracolour oily steel enamel to brighten up some of the edges.
I really need to take some better pics as they are pretty rubbish! At the moment I'm using my phone camera indoors, but I'll try and take some outside next week. Honestly, it looks a lot better 'in the flesh'.Smile
Posted by Tojo72 on Thursday, December 15, 2016 9:05 AM
Really looking good,mines coming down the home stretch,pics by the weekend.
Your figures look real good,I can't do faces for sure.
    August 2015
Posted by SpursN17 on Friday, December 16, 2016 9:56 AM
Cheers Tojo. I thought I couldn't do faces either, I just kept redoing them until I was at a point that I could live with them.
They're not perfect, and I'm not entirely satisfied with them, they'll do for now though!
    August 2015
Posted by SpursN17 on Tuesday, January 31, 2017 10:12 AM
Hello all.
It's been a while since I last updated this thread, unfortunately 1/1 life has got in the way of 1/35 updates recently!
I'm calling this one done now, although I still plan to put it on some sort of base and the aerials will be added at that point due to me being so ham-fisted that I'll keep breaking them off.
At the end I decided to put a pistol holster in the standing infantryman’s hand as if he was offfering it to the driver, it's since been pointed out that he looks like he's taking a 'selfie'. Oops
Should this be posted in the 'Diorama' section when it's on it's base or left in the 'Armour' section? I'm confused!Big Smile
Anyway, on to the pics, apologies as usual for using a rubbish phone to take them...
Thanks everyone for the comments and advice throughout this build, it's been enjoyable.
Spursn17 (Dave)
    September 2016
Posted by ManCityFan on Tuesday, January 31, 2017 5:46 PM
Nice job. The figures look great! Oh, by the way, Man City is killing me this year. Grumble, grumble.
Dwayne or Dman or just D.  All comments are welcome on my builds.
    August 2015
Posted by SpursN17 on Wednesday, February 1, 2017 2:46 AM
Cheers ManCityFan.
I know what you mean, it's all going a bit 'spursy' for us as well. The Wycombe game nearly gave me several heart attacks! Big Smile
    August 2016
Posted by WannabeFarmboy on Wednesday, February 1, 2017 4:15 AM
Amazing work! I've been away from the forums for a couple of months. Seems I've really been missing out on some good stuff here in the armor forums.
