thanks for all the comments guys!
Eric, You're not seeing things. I got the idea for this after seeing it on a couple of pz Iv's where the crew had painted the camo with the tracks on, but then needed to use the spare tracks. So in the end it was like it was masked. I did this by putting the spare tracks on the rack when painting camo, then took them out when I was done.
M60, The german numbers where usually no more than three. The numbers stood for company, platoon and vehicle. I've seen four numbers on halftracks and some other non tank vehicles. The instructions call for the 4 numbers on all of their schemes so I just followed directions. It could have something to do with it being a recon vehicle.
Terry, It was a great kit!
Waffensoldier, I had no troubles with the working suspension at all. It was very simple and a great design. I did use the kits rubber tracks. They are very well detailed for rubber tracks, but for this vehicle it wouldn't be a bad thing to get am tracks (sag, and working suspension would be easier to replicate).
The antenna was a piece of cake. Its a plastic rod with a pe part for the top. They include a special forming cone that allows you to bend it into the correct shape.
The figure is not the Tasca figure. I am currently painting the tasca guy.
As far as I know the kit is still in production.
