m113 with TOW?
    May 2006
m113 with TOW?
Posted by CarnivourousDonut on Tuesday, May 16, 2006 1:52 PM
A long time ago, I built an m113 with an aftermarket resin (Verlinden [sp?]) TOW attached on top.
The resin kit was my 1st, and predictibly, a disaster (I didn't know how brittle resin was).
Nonetheless, I'd like to return to the kit, assuming I can find one. I'd like it stock, that is, out of the box with the TOW (I think it was called a Dragon), but if I have to go aftermarket, so be it.
Any ideas?
Let's rattle the cage, crack the machine. Let 'em know who you are, shine to be seen.
Posted by HeavyArty on Tuesday, May 16, 2006 2:06 PM
An M47 Dragon is not the same as a TOW.
If it was a standard M113 with a TOW attached, there are no plastic kits of this type set-up that I know of.  I believe Verlinden did make a resin set for this version.  It simply bolted into the floor and stuck up out of the top troop hatch.
If it was an M901 Improved TOW Vehicle (ITV), an M113 with the TOW head on top, it is made by Italeri.  Verlinden also did a resin conversion set for the TOW head.
If it was in fact a Dragon launcher up top, Academy's M113A2 comes with the Dragon set-up in the kit.
Posted by ajlafleche on Tuesday, May 16, 2006 2:29 PM
If it was the single TOW launcher, this is an easy conversion. I can get you drawings of he set up. All you really need is a stand alone TOW that comes with the Dragon anti tank figures or the Italeri waepons set/
    November 2004
Posted by barrovian on Wednesday, May 17, 2006 2:06 AM
    May 2006
Posted by CarnivourousDonut on Wednesday, May 17, 2006 10:29 AM
I stand corrected, it was the Hammerhead version. m901 I guess.
Thanks for the heads up
    February 2020
Posted by Conifer on Sunday, February 9, 2020 12:05 PM
13 Years ago?... If your still around HeavyArty thanks for the post,  I have looking for such a model as I served in a unit in Berlin about 1982 ...M113 with single TOW launcher on a pedestal.  Found no such model but did find a few pictures.  Also found a similar set up in the IDF and Canadain forces.  I was going to get the Jeep/TOW setup which is about $10 at the moment and mash it with a M113 model but will look at the Dragon anti tank figues and the Italeri Weapons set you mentioned.
Thanks
    February 2020
Posted by Conifer on Sunday, February 9, 2020 12:57 PM
Ref the M113 with TOW missle launcer...This is a correction on my first post... I was not in Berlin, that came later.  I was in Swienfurt Germany with the Army.  It was a Single TOW launcher on and M113.  I had my time line screwed up - I was stationed in Berlin about 5 years later  with the Air Force.
Posted by HeavyArty on Wednesday, February 12, 2020 9:11 AM
I am still here and glad to help.  Since the original post, there are quite a few resin TOW sets available, mainly from Legend.  Also check out Shapeways for 3-D printed TOW sets.  Good luck.
Posted by Rob Gronovius on Wednesday, February 12, 2020 11:53 AM
Conifer
If it was this vehicle, it is the standard M113A1 or A2 with an M233 TOW kit. It is also the reason why the M901 is called the Improved TOW Vehicle or ITV. It is an improvement over the original TOW M113 variant.
    July 2004
Posted by stikpusher on Wednesday, February 12, 2020 1:07 PM
M901 Improved Tow Vehicle. The improvement being that the shooting and reload is done under armor. Ideally from a hull down position so only the remote hammerhead is exposed. And with two missiles in the hammerhead, the second shot can be launched immediately as soon as a target is acquired. The track commander had a separate periscope for just that task.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
Posted by Rob Gronovius on Thursday, February 13, 2020 12:26 PM
stikpusher
He was asking about a single TOW mount on an M113. I'm not sure Verlinden did one of a single TOW mount, but they did the 901 conversion. I got one in a show raffle once. That thing is very heavy.
    July 2004
Posted by stikpusher on Thursday, February 13, 2020 12:49 PM
Rob Gronovius
stikpusher
As far as I’ve seen, there is only the Hobbyfan TOW track conversion in 1/35. But it would not be too hard to do a basic conversion using a standard 113 and something like the Tamiya TOW Jeep for most of the TOW components. The biggest challenge will be to create the missile rack inside. Scratching up the pedestal for the gunner is pretty simple. The .50 mount had some kind of pivot modification to keep it from interfering with the TOW system.
I remember the Verlinden M901 conversion set. I was so happy when Italeri released their 1/35 M901 kit
       - Plankton
LSM
Posted by HeavyArty on Thursday, February 13, 2020 12:54 PM
stikpusher
You could use/modify this one from Shapeways for the TOW rack.
Link to Shapeways store:  https://www.shapeways.com/product/8J8M8GTAF/1-35-spm-35-027-tow-07-tow-missile-containers-rack?optionId=63763760&li=marketplace
It looks similar to the actual one used.
Here is a really nice build of one at Armorama a few years ago:  http://www.armorama.com/modules.php?op=modload&name=SquawkBox&file=index&req=viewtopic&topic_id=230953&page=1&ord=0
