Chuck Fan wrote: |
Thanks to everyone for the detailed reply. I think I will go with Dragon. I am thinking of using the premium edition Porsche turret version as basis, and add a henshel turret from the Ardenne Tiger II kit. I want to build a Tiger II circa Ardenne. Please bear with me for a couple of more questions. 1. Are the commander's copula on Porsche turrets the same as the ones on the Henshel turret? Dragon's Porsche turret kit has far superior cupola which I am thinking of grafting onto a Henshel turret. 2. Are the ammunition doors at the back of the turret interchangiable between Henshel and Porsche? Again Dragon did a much better job with the Porsche turret and I want to build a Henshel. 3. Is there any important differences between the hulls of Porsche and Henshel Tiger IIs that I should be aware of? |
No, no & yes.
A little history first: when Henschel & Porsche built their Tiger II prototypes, Krupp was to be the sole supplier of the turrets. Krupp managed to produce about 50 of the so-called "Porsche" turrets before they found out the order went (again) to Henschel. The "Porsche" turrets were more streamlined, but they had a bad shot-trap under the mantlet, and the side of the turret, where the commander's cuppola was molded in, was a weak spot in the turret. A new turret design was submitted by Krupp that eliminated the shot-trap under the mantlet, used thicker armor, had more interior room, and was easier & cheaper to produce. Therefore, the "Henschel" turret and the "Porsche" turret are totally different; other than both mounting the KwK 43 L/71 gun & the commander's cuppola being on the same side of the turret, they were totally different.
As for the chassis, it depends on what you're talking about when you say "Porsche hull" and "Henschel hull"; the "Porsche hull" was never used on a Tiger II. The few Porsche chassis that were produced with the Porsche suspension ended up being completed with a fixed superstructure and a 128mm gun, and became the first "Jagdtigers" (after that, the rest of the Jagdtigers were built on Henschel hulls & suspension). The Porsche suspension was actually more efficient, but harder to produce, so production of the Porsche suspension was discontinued.
Interesting fact I discovered while "researching" this question: No evidence has ever been found to indicate that a Tiger II was ever knocked out by a shot to the front of the tank; the front armor of the Tiger II was virtually impenetrable by Allied tank guns except at very close range.
1/48th Monogram A-37 Dragonfly: 95% (so close!); 1/35th Academy UH-60L: 90%; 1/35th Dragon "Ersatz" M10: 75%; 1/35th DML E-100 Super Heavy Tank: 100%; 1/48 YF-12A, 95%; 1/48 U-2R: 90%; 1/48 B-58 Hustler: 50%; 1/32 F-117, 50%; 1/48 Rafale M: 50%; 1/48 F-105D: 75%; 1/48 SOS A-1H Skyraider: 50%; 1/48th Hobby Boss Su-27: 50%; 1/16th Revell Lamborghini Countach: 75%; 1/12th Otaki Lamborghini Countach: 25%; Tamiya 1/35th M3 Bradley Cavalry Fighting Vehicle: 25%
