Chris - Glad to have been of help! The old Tamiya SU-85 kit is mixed... goes together very easy, great fit, hardly any flash. But detail is laciking and the tracks are very simplistic. A great kit to build for a newbie like me ;) easy to put together, not much detailing, no camo. The only tricky part in terms of build is the external fuel tanks. You have to do some careful dry fitting and sanding, and probably use a 'welder" type of glue like tenax in order to keep the tanks looking "cylindrical". I have mine will all hatches closed, since it has zero interior. Kit does come with one figure, which is useful for practice purposes I guess.
Here is my progress: major construction done, you can see the ugly dark pseudo OD color of the plastic:
The holes on the side are for the external fuel tanks, which are being painted separately:
you can see the almost complete lack of detail in the suspension section. The grab handles are also on the thick side, I tried to shave them down a bit carefuly with an Xblade
I glued all the hatches shut; no sense in opening them since there is no interior at all. The holes up front are for the spare track, currently drying from a basecoat of gunmetal metalizer.
Grill is plastic of course, you need PE if you want a better build. I tried to do a good job on the simple construction aspects, no seams, etc. Anyone please let me know if you see any construction errors!
---- and of course, disaster happens! I get my AB compressor out to do the basecoat and paint the wheels and... "something" fell on it during the winter and sheared off the valve connecting the gauge to the compressor. Half of the metal chunk is wedged in the valve... cant get it out :( I spent couple hours hand brush painting the wheel rims black, and the wheels MM Russian Armor Green. I got the thinner ratio OK for hand painting, but there is no way I will be able to finish by the deadline :( hand painting (or brush painting), you really need to slowly put down the coats and wait long enough for drying, to avoid brush strokes.
I am going to my niece's wedding this weekend, so... unless I can get an extension, I will be unable to finish in time! Boo hoo
