There are a few other issues with this kit. The gun mantlet has been simplified. It is missing several facets. These can be seen by comparing photos or even the box art to the kit part. I corrected the problem on mine by simply sanding the facets into the kit part, or you can replace the part with a AM resin replacement from Artisian Mori.
The front edge of the hull side has been faceted along the weld seam, this is not correct. It can be easily fixed with a piece of styrene stock.
The rotating periscope in front of the commander's hatch should be removed, filled and a weld bead added. This feature was present on the original drawings but not included on the finial vehicle.
The turret pistol ports are too large, in the wrong location and are lacking a plug.
There several other small details to be added as well.
