Well thanks guys but! The first coat of gloss clear highlights my first glaring blunder! With the body having primer, two coats of matt white undercoat and three coats of gloss blue, prior to the gloss clear going on I test fitted the windscreen as all windows fit in grooves from the outside, I will need to scrape out the paint around each window area! OR shave off around each 'Glass' to fit!
![](https://images12.fotki.com/v1681/photos/6/1059406/16610536/photo2-th.jpg)
Yes the decal down the side of the windscreen came away so some red paint will be carefully brushed in! Oh the window decals are to be laid up inside!
