I was just helping Dad give the '74 a tune up yesterday. Plugs, wires, timing. We managed to get that old 232ci humming pretty well. We have a 258ci on a stand that we're going to rebuild with some mild performance upgrades. Lope the cam a bit, maybe a slight bore increase and such.
I must admit more work has been done on the 1:1 than the model lol.
Also I have an amusing story. The last owner decided to remove the rear marker lights and used a copious amount of Bondo to fill the holes instead of welding in some sheet metal. Dad decided he wanted to put them back in and took a drill to it, but as he did the entire "block" of Bondo just fell out into the car lol! Both sides just took a little push.
Well the rear marker lights went back in without much of a problem after that lol!
Can you imagine that happening after a nice paint job was put on it? We (not being body guys, just wrench monkeys) know you don't use heavy ammounts of Bondo to fill holes. You gotta have things spot welded if you want them to stay put lol.
What works in small scale does not work in 1:1 lol!
Anyways I think I should probably make some sort of progress on this kit some time this summer. :)
