Tamiya 1/12 Tyrrell P34 (six wheeler) WIP (Update Sep. 27).
Posted by Don Stauffer on Tuesday, August 11, 2020 8:56 AM
Very nice engine!
    March 2015
Posted by JohnnyK on Tuesday, August 11, 2020 1:08 PM
The driver's seat came in three diferent designs: One design was an unpadded fiderglass seat, the second design had holes drilled in the fiberglass seat to provide ventilation and the third design was a padded seat.
The kit's seat was the unventilated fiberglass version. That must have been really uncomfortable. I decided to add some padding.
I went to a Goodwill store and purchased a black leather purse. I cut the leather into four pieces. It took a lot of trimming to get the leather to fit correctly.
I glued the leather to the plastic seat with craft glue. In the actual car the padding was painted blue. I like the black better.
The kit includes a pre-cut, cloth seat harness with PE buckles. I am not too sure how accurate the harness is, but I think that it looks okay. It might look better if the seat belt was flopped over the sides of the seat.
    June 2008
Posted by lewbud on Tuesday, August 11, 2020 3:31 PM
Looking good Johnny!
Buddy- Those who say there are no stupid questions have never worked in customer service.
    March 2015
Posted by JohnnyK on Tuesday, August 11, 2020 3:40 PM
Lewbud, Thanks!
    March 2015
Posted by JohnnyK on Wednesday, August 12, 2020 2:35 PM
If you are the kind of person that likes to swear, you will love trying to assemble this kit's exhaust systemSuper Angry
Here is the problems with the exhaust system. The pins that attach the headers to the collector are too small and too short. The other end of the headers fit into really large openings in the engine block. The result is that the entire header assembly just flops around making it difficult to keep it in proper alignment while the glue sets. Also note parts labeled G17 and K7. If you install them now they will break off. Put those on later.
The plastic exhaust pipes that are supplied with the kit are not pefectly round, there are mold lines that need to be removed, the diameter of the pipe varies, and the plastic is bumpy. I decided to ditch the plastic pipe and use an aluminum tube. I flared the end of the tube by inserting it onto a pair of needle nosed plyers and twisting the tube. A small diameter aluminum tube will be glued into the collector and the other side inserted and glued into the exhaust pipe. That will provide a positive joint. I painted the exhaust pipe and headers with Testors' Metalizer Titanium sealed with clear flat.
I chucked the engine into a vice. You can see how loosely the header fits into the engine block.
I put red Bondo into the collector to provide a stiff fit with the exhause headers. I preasembled the headers before gluing them into the engine.
I put a big blob of Testors' plastic glue into the slots in the engine block and let the glue set until it became gooey and stiff. I then pushed the headers into the slots and moved around the headers until they were in the proper position.. I let the assembly sit for two days while the glue set. I then pulled off the collector, sanded the excess Bondo and glued it to the headers and exhaust pipe with super glue.
The final result looks pretty good. Tomorrow I'll discuss the front suspension which requires more swearing.
Posted by keavdog on Wednesday, August 12, 2020 3:04 PM
Great stuff!  Very convincing engine.
Thanks,
John
    March 2015
Posted by JohnnyK on Wednesday, August 12, 2020 4:50 PM
Thanks! A lot of detail can be added to a 1/12 scale engine that would be difficult to add  to a 1/24 scale engine.
This is a comparison between a 1/12 scale engine/tranaxle and a 1/25 scale model.
    January 2015
Posted by TheMongoose on Wednesday, August 12, 2020 5:36 PM
enjoyed the exhaust tutorial! Very convincing results. Looking forward to the front suspension.
In the pattern: Scale Shipyard's 1/48 Balao Class Sub! leaning out the list...NOT! Ha, added to it again - Viper MkVii, 1/32 THUD & F-15J plus a weekend madness build!
    January 2020
Posted by Space Ranger on Wednesday, August 12, 2020 6:43 PM
Here's some trivia for you. This kit has a Star Trek connection. Can you name it?
    March 2015
Posted by JohnnyK on Wednesday, August 12, 2020 7:46 PM
Give me a hint.
    January 2020
Posted by Space Ranger on Thursday, August 13, 2020 8:04 AM
Sulu's command.
    May 2013
Posted by Greg on Thursday, August 13, 2020 8:14 AM
Very interesting to see how you worked through the engine fit issues. Bunch of very good tips and ideas.
How did you manage to put the bends in the aluminum tubing without it flattening out?
The leather seat cover looks great. Good choice leaving it black. First I've heard of cloth and PE belts included in a kit. That's cool.
    October 2019
Posted by Tanker-Builder on Thursday, August 13, 2020 11:59 AM
Hmmmm;
 Bet you learned some new swear words, didn't ya?
    March 2015
Posted by JohnnyK on Thursday, August 13, 2020 2:37 PM
Greg
I guess that I didn't expain the exhaust system correctly. The following picture should make things clear:
    March 2015
Posted by JohnnyK on Thursday, August 13, 2020 2:40 PM
Tanker-Builder
Hmmmm;
Not only that but I was able to make complete sentences where all the words were swear words.
    March 2015
Posted by JohnnyK on Thursday, August 13, 2020 2:54 PM
Now it's time for more craziness.
This a photo of the parts that make up only one side of the front suspension! Remember, there are two wheels per side.
Tamiya did a really good job of duplicating the appearance of the actual car's front suspension (top photo). There are a number of suspension control rods that snap onto pins. Luckly I didn't break any of the snap connections.
    May 2011
Posted by Real G on Thursday, August 13, 2020 5:32 PM
Superb progress!
I had similar problems with the 1/20 kit's exhaust system.  My fix was to shorten the straight sections and the last header pipes a bit, as they were throwing the header pipes out of alignment and causing the collector to rotate 45 degrees out.  The loosey-goosey fit of the parts did not help either.  I am using two kits to build one, and I ruined the first set of pipes trying to get the unmodified parts to work.
“Ya ya ya, unicorn papoi!”
    March 2015
Posted by JohnnyK on Thursday, August 13, 2020 7:33 PM
Real G,
Nice tight fit where the  headers connect to the collector. The loosey-goosey fit is a real problem. I don't understand why Tamiya did that.
Space Ranger,
I'm still thinking about the Sulu question.
dlh
    March 2017
Posted by dlh on Saturday, August 15, 2020 11:40 AM
Great work.  You've motivated me.  I've bought that model.  Can't wait to start it.  Well, I can't wait to start about 3 or 4 models on the shelf right now.  You have certainly provided many ideas.  Most of my models look better because of contributions of others on this forum. Looking forward to seeing that completed.
Thanks for the hard work.
Dave
    May 2013
Posted by Greg on Saturday, August 15, 2020 12:23 PM
Holy cow, your right side front suspension assy looks real. Surprise
Slick workmanship, John. Yes
    March 2015
Posted by JohnnyK on Saturday, August 15, 2020 3:33 PM
The hood (drivers pod?) is molded in twi pieces:
The alaigment pins are too small and the thickness of the plastic at the joint is too thin to provide a strong joint. Parts N2 and N3 are clear plastic "portholes".
I taped the two sides of the hood together with masking tape and then I taped the hood to the top panel of the fuselage to insure proper alaignment after the glue set.
I reinforced the joint with strips of plastic.
The joint was filled with putty and sanded smooth. The joint was invisible after painting.
    January 2015
Posted by TheMongoose on Saturday, August 15, 2020 7:06 PM
Wunderbar!!
    January 2020
Posted by Space Ranger on Saturday, August 15, 2020 7:23 PM
Hint: U.S.S. Excelsior
Posted by keavdog on Saturday, August 15, 2020 7:50 PM
Suspension looks impressive!  Coming along nicely.
Thanks,
John
    March 2015
Posted by JohnnyK on Saturday, August 15, 2020 11:21 PM
It's slowly getting there.
    March 2015
Posted by JohnnyK on Sunday, August 16, 2020 9:00 PM
Space Ranger
Does the plastic model of the P34 have something to do with the cargo bay of the filming model of the U.S.S. Excelsior?
    January 2020
Posted by Space Ranger on Monday, August 17, 2020 3:29 AM
JohnnyK
Space Ranger
Yes.
    May 2013
Posted by Greg on Monday, August 17, 2020 10:31 AM
Seeing what you did with the hood reminds me I need to be more patient and do better with joins, especially if I think I'm going to start doing more things with 4 wheels (or this case 6 wheels).
Looks good. Yes
    May 2011
Posted by Real G on Monday, August 17, 2020 1:16 PM
I cheated and used my Google.  The upper monocoque of the P34 is used as a roof detail in the hangar bay.
I also noticed the Narcussus from "Alien" used two upper cowls as fairings for greeblies under the hull.
Nice progress on your kit, and I must say your silver parts certainly look better than mine!  Darn it, I might have to repaint!
    March 2015
Posted by JohnnyK on Monday, August 17, 2020 3:42 PM
This is the bottom pan of the car. To duplicate the color of the original car's pan I used Testor's metalizer Aluminum Plate. I burnished the paint using a cotton ball and then used a mud colored wash to simulate dust and dirt. I wiped the wash in the direction of the airflow under the car. Originally I was going to finish the pan in Bare Metal Foil (insanity strikes again). But my alter ego said, "No way dude!!!!"
