Italeri 1:12 Fiat Mephistophele Finished
    May 2013
Posted by Greg on Thursday, December 17, 2020 4:39 PM
DRUMS01
Nice save....
Agreed. Yes
    August 2007
Posted by DUSTER on Thursday, December 17, 2020 12:22 PM
This is a real treat to watch your work. The kit seems to be pretty darn amazing itself. Like your detailing of the engine wire(s) as well.
Steve
    June 2018
Posted by DRUMS01 on Thursday, December 17, 2020 11:47 AM
Nice save....
Ben
"Everyones the normal until you get to know them" (Unknown)
LAST COMPLETED:
1/35 Churchill Mk IV AVRE with bridge - DONE
NEXT PROJECT:
1/35 CH-54A Tarhe Helicopter
Posted by Don Stauffer on Thursday, December 17, 2020 8:48 AM
Proud of my solution- lost a plug the other day.  Had it in tweezers while attaching lead and it launched.  Not able to find it so I had to scratch one.
The plugs are less than 1/4 inch long, max diameter of 80 mils, pins are 40 mil.  I lucked out- had 80 mil plastic rod and 40 mil brass rod on hand.  Biggest grief was drilling a 40 mil hole down middle of 80 mil rod, but I got it done.  Before putting rod through, I chucked the rod in my little adjustable chuck that fits in my battery dremel.  The speed control on it is awesome.  Filed the rod to shape.  Fit the rod through, then painted it.  Got wiring half done now.  Pics soon.
Posted by Don Stauffer on Monday, December 14, 2020 7:18 AM
dlh
Dashboard looks splendid.  Great work.  What did you use for the shiny brass finish?
Dave
Alclad brass.  I put it on directly over the kit plated parts. Brightened it up nicely.  I have also brush painted some small parts with Testors gold enamel.
dlh
    March 2017
Posted by dlh on Sunday, December 13, 2020 10:19 AM
Don Stauffer
dlh
This build was really fun. Wood floors/firewall are not as hard as you might think.  The engine is really a separate model.
 http://cs.finescale.com/fsm/modeling_subjects/f/4/t/182021.aspx
Dave
Beautiful.  I hope mine comes out as nice.  I did a new graphic for the big tach, to show it with the extant car, but otherwise OOB.
Phil, I did order the wire from Amazon, got it yesterday.  Started the plug wiring.
I made a booboo in not following the plans exactly.  I thought while waiting for the wire I could go ahead and mount the intake manifolds and carburetors.  That was a mistake.  Lack of room makes putting plug wiring in on that side very difficult.
I wish I had used smaller wire than the kit includes. I had a lot of trouble fitting the distributor bundles into the loom.  I'm still not happy with the result.  The kit wire is just too large.
Dave
dlh
    March 2017
Posted by dlh on Sunday, December 13, 2020 10:13 AM
Dave
Posted by Don Stauffer on Sunday, December 13, 2020 8:41 AM
dlh
Dave
    March 2015
Posted by JohnnyK on Tuesday, December 8, 2020 1:07 PM
Outstanding work!
Posted by Don Stauffer on Tuesday, December 8, 2020 10:45 AM
This thing has 24 spark plugs! For six cylinders. I know a lot of aero engines have two plugs per cylinder- but four?  Of course, I claim no expertise in Italian WW1 aircraft engines.  Anyway, there are two looms, one on each side of the engine.  The wires will just be going from distributer into the loom, and wires coming out of loom to plugs.  There are four distributers, each distributer has six leads going to six plugs (completely redundent ignition).  Making up the leads now- three down, 21 to go :-)  I do notice some learning curve even after only three.  By the way, those are mini craft clothspins, not full size ones.  I find them very useful for many modeling tasks.
There are then 24 leads going from looms to plugs.  Instructions call for a little sleeve on end of wire going onto pin on loom.  But photos of real engine show normal wiring with wires going through holes in loom.  So I cut the pins off (upper loom) and drilled them with a 57 drill.  I will just glue wire stub into hole in loom.
Even without the sleeve there are still three parts to plug and wire (sleeve between end of wire and plug terminal.  Haven't started on the plug wires yet.  Not sure how long the remaining 21 distributer wires will take.
    June 2018
Posted by DRUMS01 on Tuesday, December 1, 2020 9:36 AM
Looking really good Don
Ben
LAST COMPLETED:
NEXT PROJECT:
Posted by Don Stauffer on Tuesday, December 1, 2020 8:50 AM
The frame and suspension are now complete, waiting for a good gloss coat on body parts.
Finished the instrument panel- a project in itself.
Still working on engine. Parts on engine sprue do not have as good a fit as chassis sprue, but still manageable.  Mold relief angles are fairly steep and flat mounting surfaces of parts cast in two pieces have a pronounced shallow V that has to be filed flat.
    November 2020
Posted by TnT92 on Friday, November 27, 2020 1:50 AM
Great work. It is a shame to cover them springs up.
dlh
    March 2017
Posted by dlh on Monday, November 23, 2020 9:26 AM
Love your additions to the engine.  Beautifuly work.  Adds a lot.
Dave
Posted by midnightprowler on Monday, November 23, 2020 4:21 AM
That's a work of art.
Hi, I am Lee, I am a plastiholic.
Co. A, 682 Engineers, Ltchfield, MN, 1980-1986
1 Thessalonians 4:13-18 1 Corinthians 15:51-54
Ask me about Speedway Decals
    May 2013
Posted by Greg on Sunday, November 22, 2020 5:57 PM
Outstanding work.
Posted by jeaton01 on Sunday, November 22, 2020 3:34 PM
Great project and progress, Don.
John
    October 2020
Posted by Scale-Master on Sunday, November 22, 2020 3:26 PM
Looking very nice!
Build what you want and build it for yourself, the rest will follow... Mark D. Jones
    November 2020
Posted by Also known as Rob on Sunday, November 22, 2020 2:05 PM
Fabulous job!
Posted by Don Stauffer on Sunday, November 22, 2020 2:01 PM
I did it! Got 24 tiny holes drilled down into the head to hold the valve stems (pieces of steel wire).  Gave up trying to do it with pin vise.  The quality of today's small drills are so crappy I had to resort to my mini drill press.
Then I had to cut short lengths of the wire and glue them into the holes- easy job.  Next I had to paint valve springs.  I feared this job- the springs were stainless, but I stuck them down on a piece of double side tape and airbrushed them with graphite metallic.  They came out okay.  Next job was gluing on the rocker assemblies and cam housing.  I would have to hold all twenty four springs in the right position and fit them over the valve stems while gluing cam housing in place.  I first glued springs to rocker arm tappets, brought it down over the stems.  Took two tries, each time only one errant spring.  Got every thing lined up okay second time.  Fortunately, the springs were strong enough it held the cam assembly about a sixteenth of an inch up above mounting surfaces.  That was enough to get some CA glue on those surfaces.  Valve and cam stuff complete!
    May 2013
Posted by Greg on Sunday, November 22, 2020 9:29 AM
Don Stauffer
This is far superior to the Pocher kits. It is a quality kit- detail sharp, fit very good.
This is every exciting to me. I suffer from Pocher nostalgia, often feeling sad that the old kits aren't there anymore (yes, I know they are available occasionally from collector sites but though I could afford the new ones as a youngster, I cannot afford them now).
Thank you for the additional info and for making me feel better about my purchase, Don.
Posted by Don Stauffer on Sunday, November 22, 2020 8:25 AM
Greg
Been wondering how this might compare to the Pocher kits of the good old days. With your help, I'll be able to find out without cracking open the plastic seal.
This is far superior to the Pocher kits.  It is a quality kit- detail sharp, fit very good.  There are tiny parts, and some are supposed to be screwed in spots that do not have good access to screwdriver.  I have been drilling out more screw holes to clearance diameter and replacing screw with glued-in 80 mil styrene rod.  Painting is fun- I love painting small details by hand.  Been around race cars enough I know what colors small parts probably are.
    May 2013
Posted by Greg on Saturday, November 21, 2020 4:32 PM
I especially appreciate this WIP becuase I have one on my shelf, purchased some time ago from Hobbylink Japan at a price too good to pass up.
Looking good so far, and do keep it up please.
    June 2018
Posted by DRUMS01 on Saturday, November 21, 2020 3:04 PM
Wonderful build so far and nice colors on the engine.
Ben
LAST COMPLETED:
NEXT PROJECT:
    March 2015
Posted by JohnnyK on Saturday, November 21, 2020 1:30 PM
Great looking detail on the engine.
Posted by Don Stauffer on Saturday, November 21, 2020 9:32 AM
Got the front suspension onto the frame.  Sorry for the bad lighting.  Each axle has four friction shocks.  Each shock is seven pieces held together with screws and a screw fastens it to the frame.  These are tiny metal screws that self tap into the plastic. Holes are a little tight!  Hard to apply much torque to a small 1/16 tip screwdriver.  Already poked painful hole in thumb when screwdriver slipped.  I'm starting to drill out the pieces and glue screw in.
Also continuing on with engine.  Have cam housing ready to mount, but need to put in valve stems.  The valve stem, spring, and rocker arms are open.  They supply the spring, but it is a little thin in cross section, so valve stem should be visible, but they do not supply stems.  No problem, I thought- little pieces of steel wire will surface.  Problem is drilling the small holes.  We've discussed the problem of poor quality 60-80 drill bit sets.  I'm tearing my hair needing to drill 24 holes (4 valves per cylinder).  The soft plastic does not drill easily.
Posted by Don Stauffer on Sunday, November 15, 2020 3:05 PM
I have started working on the engine.  As someone said, the engine is a model kit in itself- I figure if I work on chassis, body painting, and the engine, sharing time, I will have the engine ready when needed.
The cylinder heads have a tube running between them.  The kit has little nubs on each head, and some vinyl tubing.  You are supposed to cut the black vinyl tubing to fit between the nubs, and leave it black.  But photos of the real engine shows these tubes were brass.  So I cut lengths of 5/32 brass tubing to replace the vinyl tubing.  Each length is less than 1/8 inch- I had to make a jig to control length- made this tube cutting jig from MDF.
Even with the jig I had to touch up several with a file to get them to fit.  But it looks good now.
I am also painting each molded in bolt head a different color than the casting itself.
Posted by Don Stauffer on Saturday, November 14, 2020 8:58 AM
Tanker-Builder
Don;
   Most folks look at the Name and say Uh Uh. What a horrible name for a neat Auto. Keep us in the loop okay? I have some cars I got from Gene so I will be watching. Also a perfect car to do real wire wheels on.
The wheels are not bad for plastic molding.  I suspect the wheels used pretty heavy spokes anyway because of the weight of the beast.  Name comes from loud sound and noxious fumes.  Big aircraft engine.
    October 2019
Posted by Tanker-Builder on Friday, November 13, 2020 10:07 AM
Don;
dlh
    March 2017
Posted by dlh on Friday, November 13, 2020 9:53 AM
Dave
