~ U.S. Armored Infantry for my 1/35th scale E.T.O.~
    April 2008
Posted by *INDY on Sunday, June 13, 2010 10:27 PM
~I''m just getting some elements going for an upcoming Diorama, the title of which at the time of this writing is " Beyond the Rhine "   . As usual for me there will be a number of resin figures involved,  from varied  manufacturers, representing some variation in uniforms & equipment.
To say that clean-up & assembly was a breeze would be an understatement. Actually I think this is the best resin figure I''ve seen--even fitting both arms and the Garand with attached hands was simple, with keyed attachments for both arms, there was nearly no play, and after gluing the arms in place, the weapon/hands part can dry-fitted  perfectly. I''ll have this piece seperate for painting, and  am using a small piece of clay to keep it in place here. The head is in place with a music-wire pin, and will likely be left free to turn until final placement in the Dio.
~It was really difficult to photo, as this is a extremely small detail on an uncoated part, but you can see that the hilt of the bayonet is actually drilled out to scale--a feature of detail I haven''t seen before.
 Another detail I thought was quite exquisite, was the complex Garand sling, cast as a seperate resin part, which easily fit in just the right spot.
Everthing was mounted-up on music wire 'pins' and sprayed with a few very ligth coats of Tamiya TS-3 Dark Yellow as a primer/basecoat
 Next was a few washes of W&N  #2 Burnt Sienna & then # 41 Van Dy ke Brown in White Spirits
 Next went a thin layer of flesh-base made of #45 Zinc White , #44 Yellow Ocre, & #2 Burnt Sienna
Even a thin flesh layer makes those hands look less skeletal.
~~~~Plenty more coming right up...............
"Well...you gunna pull them pistols, or just whistle Dixie?"
    April 2008
Posted by *INDY on Sunday, June 13, 2010 10:42 PM
Next up, is the man 'Heading-up this operation'
What I would say is a very average resin 1/35 scale figure, From kit #1928 from Verlinden
 supplied in an odd green material,   with considerable(but normal) amount of pour blocks to remove and scraping & filing to get done----but I really, really love the pose---it reminds me of John Wayne in action (though I don't recall him in the field in any E.T.O. based film---but lots of USMC roles in the Pacific--maybe I forgot one?)
The barrel of his M1 Carbine was mutilated as delivered, as I find is usually the case with Verlinden figures---I like them ---they are great after you put the work in--but there is always plenty to do , judging from the several I've built. I scratched a new barrel from some appropriately sized drillstock, with gave me a perfectly straight barrel (for a change), with the drawback of having no way to bore it out--still, I liked the result and so kept going and made a new muzzle-lug and front sight using UV setting resin (don't ask me where you're going to find that)Surprise He also got a replacement head from Hornet.Yes
I started the painting in the exact same way as the previous figure.
 ...and with the flesh-base...
and with another layer of flesh-base and some blended shadow & a 1st highlight
    April 2008
Posted by *INDY on Sunday, June 13, 2010 10:54 PM
~~The 3rd figure going into my Germany 1945 scene will be
Sold as "Sniper", his Garand is fitted with flash-suppressor and cheek rest, but no scope! In fact some other detail is missing from the rifle including triggerguard & trigger. I may yet  add details or replace it, not sure yet. The rest of his seperate gear looks very good, but I will likely replace his model 1918  'T' handle shovel, it looks a little outdated I think.
The castings look Exactly like a kit from Warriors. I sense a shared manufacturing source. Most of the pour blocks are not a big problem to deal with, but the weapon is nearly impossible to recover properly---be nice if there was a scope there when finaly done!
Everything was prepared and painting started, again, same as above.
I'm really, really liking the stock head. Eastwood in my scene too?
 I've got goosebumps  Sad
~~More comin right up......
    April 2008
Posted by *INDY on Sunday, June 13, 2010 11:04 PM
Next on the hit parade.....this Good 'Ole Boy
Brand new release from a fairly new company(though I have a suspicion these guys are Tank's Allied division--just a theory-the pour blocks look the same and Tank seems steadfast against releasing American figures.....
The attachment points are smallish, andthe left arm came loose, with a hand missing the ring fingure---there's plent of hands in the spares box, but still, for this kind of money.....
Most of the casting is brilliant, really nicely proportioned and sculpted and cast---the arms are dryfitted here only--they fit that well! As you can see the head is moulded in place with a sub-sized cranium--I guess they figure it's better to be able to adjust the 'sit' of the helmet than have the whole head seperate for painting. My major problem with the figure is the .30 carbine is too small--it's out of scale with the figure unless he's suposed to be HUGE--the .30's not even as long as his arm--that's not just foreshortening in the photo-it's small. i used to own one and I know they are compact, but this one will not work for me, especially with  the nice looking M1 gripped by my Verlinden figure.. This guy has some really well moulded .30 carbine ammo pouches, so no changing his weapon. Likely I'll change out both hands , those in the kit are nothing to special, and worry about arming him much later.
 I selected some new hands for him from a Legend set and painted alongside
 I think they'll do the job by time they're all finished. One thing, I always like to paint the hands as I go, so the end up matching the rest of the fleshtones--something often missed.
 More updates to follow shortly.........
    April 2008
Posted by *INDY on Sunday, June 13, 2010 11:24 PM
Using just the color in my basic skin palette, I've added some shadows & lights to these heads
 Layer by layer.....allowing up to a day in between for drying...
Fiddling around at length on some of the finer features of these still....
    April 2009
Posted by deafpanzer on Sunday, June 13, 2010 11:28 PM
WOW!  American GIs... this is going to be great for me to follow your work.  There's no question one of your guys reminds me of the Sgt from Saving Private Ryan... Sgt. Mike (Tom Sizemore).   I think he even carried a Carbine too!  Let me guess you are planning to rename your diomara 'Saving Private Indy'?
http://www.militarymodelling.com/sites/1/images/member_albums/41116/bevol4.jpg
Andy
    April 2008
Posted by *INDY on Sunday, June 13, 2010 11:35 PM
Adding some indication of the eyes goes a long way towards being more life-like. Adding a tiny amount of W&N #6 Cadmium Red Deep Hue to the light flesh color gives the color for the lower lip, with a highlight at it's center.
And a bit of progress painting "Bob"
 Now switching from the oils palette to Vallejo, I begin blocking in the uniforms base colors..
 Just basecoats, nothings the right color yet--I tend to shoot for a medium tone to start--or to the darker or lighter side of medium for a little different effect. Above trousers are a mix of 894 Cam. Olive Green & 976 Buff--the jacket & putties 913 Yellow Ochre & 919 White & some of that Olive mix  (to tasteWink)
The next two chaps feature the wool trousers, based with 873 US Field Drab with a little 967 Olive Green. You can see I've changed-up the tone of the O.D. on his gear as much as possible--by time it's finished it will not look so starkly different but retain some contrast. The ammo bandolier was an item shipped as additional supplies , and coloured for the Marines in the Pacific--I painted it with a mix of Cam Olive Green , White, & some 925 Intense Blue. He wears the heavy winter coat that replaced the Mackinaw overcoat
These two also both have the later-style leather putties, and to base the leather I've used  819 Iraqui Sand with a little 873 (If I remember correctly)
Ammo belt & straps are painted the same mix for the 1st figures jacket,
 with a bit more of the  O.D.
I had planned to paint this G.I. with the the light drab field jacket, but when I went to do it thought it should be more a medium O.D. Now I'm thinking it whould be lightened, with only a light contrast to his gear, like the example below.
A good representation of a typical G.I. thanks to a re-enactment site(regretfully I forget which one and cannot credit the photos barrowed for discussion puposes only--no betting!)
Note the slightly different khaki tones which the modeller can mix 'n' match
 Thanks for checking out the progress---We'll get this attack underway shortly!
    April 2008
Posted by *INDY on Sunday, June 13, 2010 11:48 PM
deafpanzer
~~Stick out tongueHee Hee Andy--yeah, he does look alot like 'Mike' from SPR doesn't he? A bit like our friend M1 Carbine too, that's why I'm naming him "Sarge' and "Bob'  Sargent Bob, I guess....
Someone did sculpt that charactor quite on purpose
  at least that's who he had in mind(and in his reference picture)--there's a great tutorial on sculpting a figure based on this one somewhere on Timeslines
Stay tuned, Buddy, lots more coming..................
    July 2004
Posted by stikpusher on Sunday, June 13, 2010 11:49 PM
Indy, you have got four figures with three different GI uniforms going there. Figure 1 is perfect for 1945, M1943 Field Pants and Field Jacket, OG-107 shade water repellent treated cotton clothes. Figures 2 and 4 are wearing HBT fatigue pants and Tankers jackets. and then figure 3 in M1943 combat boots, OD wool trousers and the M1941 Field Jacket. Depending on the unit you have a mixture of cherries and vets or different units in the same piece of AO. Units were usually equipped or re equipped with the same  uniforms when they were pulled off the line. Just some thoughts.
So far your work is looking great as usual.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    April 2008
Posted by *INDY on Monday, June 14, 2010 12:02 AM
I know Stick--You're totally right---Like I said, I want to show varied uniforms & equipment as much as possible--It's just too dull for me to want to have them all in the same gear--even if it's a little bit of a stretch with some in winter coats--not too unlikely going into spring--units being moved around--some guys getting re-equiped, others not, still others being deployed in more updated kit.
~Anyway there's going to be three different groups of men in this scene(not yet displayed in any way) There's a few guys up on an M2 half-track, a few standing around the area, and a couple more who just rolled up in a Jeep
Doesn't the 2nd guy back look like maybe the source of the S & T figure?
    April 2008
Posted by *INDY on Monday, June 14, 2010 12:36 AM
Layering the Vallejo in layer by layer
 The shadow colors used for the O.D. trousers(the trousers with the cargo pockets we're always one O.D. or another) we're layed in after an over-all dark green wash of Floquil enamel, accounting for the sheen seen below, after that step. Such a wash goes a long way towards  revealing every fold and shadow area, but does not sufficiently portray the play of light on the fabric. For this I used  a 1st shadow of 889 & USA Olive Drab & 894 Cam. Olive Green  and a dash of 950 Black. The second shadow is 889 alone and it's a very dark colour. The  1st highlight was  straight 894 and the 2nd  894 & 978 Dark Yellow. The 3rd light is that mix with varried amounts of  919 Foundation White for any area directly hit with light (tops of folds)
Here's what it looked like with just the wash:
The dark wash went along way to revealing the fine detail of the pistol belt. The ammo pouches recieved several layers of yellow-greens, and have a bit more to go.
 The trousers above and the coat for the S&T G.I. are going through a similar treatment, but I haven't had as much time to devote to them yet and they require lots more lights.
The bayonette scabbard shows the 889 USA Olive Drabs dark colour.
One really nice casting from Verlinden are these entrenching shovels--some of the best I've seen on that item. I painted in a like fashion to the above but used some Tesors Zinc Cromate enamel mixed into some Flat Green to get that faded look. The wood handles are painted in the usual way we've come to use for on vehicle equipment--a Vallejo base with oils thickly brushed over it. Later some traces of the issue O.D. paint with cover much of it.
The completed heads needed some detail work to thier headgear. Later I'll add a bit more highs.
Some spare Hornet Heads I've also been painting along the way, including this dent in this G.I.'s steal pot, with came that way and I never wanted to repair it. At this point I've painted it into place for a little charactor.
 Some reference :
Exactly what that U.S. bayo looked like--you can also see that the ammo pouch snaps are blackened brass
A good look at the texture of the steal pot helmet(note the silvery steal worn edge)
The pouch for the M1 .30 Carbine magazines
The famous flap for the M1911 .45
That's right...you guessed it....more coming up!
    July 2004
Posted by stikpusher on Monday, June 14, 2010 12:47 AM
Indy, I really like your figure work. A meeting of elements sounds like a good way to blend them in. To be honest Ithing that photo is more the basis of several Tamiya figures from tehir old and new US infantry sets.
       - Plankton
LSM
    April 2008
Posted by *INDY on Monday, June 14, 2010 1:33 AM
stikpusher
A big Thank you  Stick---
I see what you mean about that photo maybe influencing Tamiya's artist too--except they're too tall by thier standards--if ya know what I'm saying...Tamiya figures  often seem on the small side to me....
    April 2008
Posted by *INDY on Monday, June 14, 2010 1:42 AM
I've added the arms to 'Bob' in preparation of finishing his jacket
It has to be just a little easier to paint the coat prior to fitting hands, if given the option
These boys have come along quite a ways since last update
 I've dry fit the heads to take a look, in fact they are pinned in an movable/removable and will stay that way all the way until final placement on the Diorama, in case adjustments are needed. Nothing worse than having the figure nicely finished looking the wrong waySurprise
I've painted both Riflemen with the field drab wool trousers using the 873 Field Drab as base, the shadows made with the 889 USA Drab (no black) --the lights with 919 White
The CD figure has his rucksack attached, but not his other equipment items yet. All the snaps.buckles, and bayonettes basepainted with Testors Flat Black (good 'ole square bottle)
    April 2008
Posted by *INDY on Monday, June 14, 2010 1:46 AM
Most of the colour is layed in with our favorite '0' & '00' pointy round brushes, but for 'drawing' along the fine folds with highlights I like a 5/0 or 10/0 Liner brush
 My palette keeps growing with each cloth attacked. I try to mix enough of 1 or 2 shadow & light colors to keep it around through the process. Other in-between shades are mixed on the go  right on the tin.
More coming right up......
    April 2008
Posted by *INDY on Monday, June 14, 2010 1:52 AM
I was working on on Bob's (or "the Sarge's") "tanker's jacket"
 The base colour is 919 White, tinged with a tad of977 Desert Yellow on one layer,  & 916 Sand Yellow on another. Any shadows done again by adding small amounts of 889 USA Olive Drab
    July 2004
Posted by stikpusher on Monday, June 14, 2010 1:59 AM
Figure 3, the sniper, the shade on his jacket should be the same on his as the the two wearing the tankers jackets. When brand new the jackets had a khaki olive shade but once worn and faded they went to a tan khaki shade. Only the guy in the M1943 Field jacket would stay in an olive green shade.
       - Plankton
LSM
    April 2008
Posted by *INDY on Monday, June 14, 2010 2:21 AM
stikpusher
Right--like the guy in the re-enactor picture
http://www.militarymodelling.com/sites/1/images/member_albums/41116/aagi10.jpg
You might like it better in this picture, since the others I got rid of the high-contrast, green shadow areas and brought it up to something less green and I think more in line with possible colors for that jacket, but I dont want it the same as the others in the scene.
 He and his bud. both need some refinements  to the uniforms still, and all the little details--but that's really my favorite part of painting figures. Then fitting of hands/weapons before completing.
 Trying to remember to save the boots for last--I'm always rubbing the paint off them otherwise, even when properly mounted on pins.
Actually, the 2 tanker's jackets I have here are pretty different colors, as every example I've seen is different too.
~back soon with more>>>>>>
    July 2004
Posted by stikpusher on Monday, June 14, 2010 3:53 AM
Yes. I own a bunch of that gear that I picked up surplus back in the  days before the re enactors and reproduction gear. The jackets fade to a grayish tan shade with age and use, something along the lines of US armor sand 30277. the canvas gear keeps as yellowish hue as it fades. When new it is like Humbrol Ochre, but fades to something similar to Mid Stone (old shade). I stil have some of my dads old HBT fatigues. A very unique shade of Olive I must say. Your shade of od for the wool trousers looks great! Yes
       - Plankton
LSM
    January 2012
Posted by I make stuff on Monday, June 14, 2010 10:19 PM
Adam, that guys is the spitting image for Mike Horvath/Tom Sizemore, so much so that I decided to post it even before I Read through to where you said it.
No question about it.
Painting is coming along very nicely, too.
Keep it up,
Bill
    April 2008
Posted by *INDY on Tuesday, June 15, 2010 12:24 AM
~Stickpusher~ Thanks for your comments, Buddy. That's cool you hang onto those old relics--glad someone is--If you get a chance and want to throw down some photos of some of the 'unique shades of O.D.' it would be welcome to see. The re-enactors show somewhat usefull stuff sometimes, but as we know, often not quite==certainly most of them make an effort to get it right-- i always try to get a number of references for any one thing--which makes it even harder to decide what the thing looks like!--But taking all available data into account, I shoot for what seems right to me--waht else can we really do, right?
~CaliBill~ Hey Bro--it works for me-LOL-, yes it looks alot like him--should I start calling the figure Mike? Is it kooky to name 2" tall  men at all? Seems easier to blog them with namesWink Thanks for dropping in--plese do so again---keep in touch one wawy or another--ieght?
~~Update is coming up~~~~
    May 2009
Posted by Pawel on Tuesday, June 15, 2010 5:10 AM
Hello Adam!
I see you have your share of GI's too now! They're looking good! What impresses me is how many different shades of OD & OG are on them at the same time. Keep 'em comin' & have a nice day
Pawel
www.vietnam.net.pl
Mic
    June 2009
Posted by Mic on Tuesday, June 15, 2010 8:51 AM
Yeah, that Evolution figure seems definitely based on Sizemore... I'm waiting for the Hanks figure from them to fill out a scene idea I've got goin. Big Smile
Your figures are lookin good, Indy.
Steve M.
On the workbench: every tool, paint, brush, glue I own
    January 2008
Posted by Bodge on Tuesday, June 15, 2010 5:25 PM
Great figures and your doing a great job on them. The Dio should look great with those on it.
    April 2008
Posted by *INDY on Tuesday, June 15, 2010 10:36 PM
Pawel~ Thanks for comments Buddy--yeah, I like to vary the colors as much as possible  and stay in the realm of possibility--I usually mix a different color even on same-colored items--or try to fade one more than the other--to get away from any 'toy soldier' productionline look
Steve~What's up man? Long time - no post   . I appreciate your comments--don't be a stranger!
Andy~  Thanks out to you -- they're shapin up, but alot on my plate right now---should really have something good looking in a few days if I carve out a little tiime.
    April 2008
Posted by *INDY on Tuesday, June 15, 2010 10:49 PM
~Next up is another nice figure from S & T
Part of the team, with the first figure I posted, another really nice work by John Rosengrant, this one titled "Squad Leader" Winter 44.
This casting was in no way as nice and easy to clean-up as other one, but i was not deturred by the miles of flash, although removing it revealed a few pocks and air bubbles that needed filling. The worst thing by far was a misaligned parting you can see on the edge of his left leg--this is one of the worst things that leaves you having to sculpt-in the legs detail, as there was a real 'step' there. The large long chunk is the pour block for the (again) included cast sling(sorry to say I've by now lost the nice sling for the 1st guys Garand some how--I'll leave this one off till much later as its a good deal smaller and requires shaping.)
Here it is all cleaned-up, with again, the arms just dry-fitted and hanging on thier 'key' pegs
Again--with this figure they just fit that well! No way to botch that--The helmet is temp placed with a little ball of clay for now.
He's got the bigger type rucksack and wears his mag-pouch like a weight-lifters belt.
The holster fits right in that spot  next to the mag-pouch.
No option as to position of head--short of grinding it away and replacing it--not that I want to -I think this head should be great. You can see in this pic the worst of the air bubbles--where he appears to have taken a 20mm to the head*(IndifferentEd) and a big hole under the arm--all made tidy by now and ready to pull apart and prime.
Here I've got the Lieutenant mounted-up and primed
I've done things the same as with the Evolution figure 'Bob',masking hands and face (looking a good deal like one of Mac's hostage videos Tongue Tied and sprayed the rest with a TS can of Dark Yellow
Afterwards I painted the flesh with the Tamiya mix and sprayed the helmet with the  TS-5 Drab
The Lt. took to the 1st round of oil washes pretty well...
This is interesting--with application of the 2nd, darker wash, look how that eye detail has appeared--a truelly gifted sculpter!
more coming up very soon!
    May 2009
Posted by Pawel on Wednesday, June 16, 2010 1:55 AM
Adam, looks like you have another very nice GI in the cue.
I was actually amazed on the variety of colours on the real things. This gives a skilled modeller like yourself an opportunity to do something eyecatching and realistic at the same time. Keep 'em comin & have a nice day
Pawel
www.vietnam.net.pl
    January 2008
Posted by Bodge on Wednesday, June 16, 2010 6:38 AM
Those S&T figures are something else. I have seen a dio with a bunch of them in and it was superb. I will try and dig out a pic of it for you. I have three of thier figures on order in 1/16 scale and i cant wait to do them.
    April 2008
Posted by *INDY on Wednesday, June 16, 2010 11:23 PM
Pawel
Thanks, ya Pawel--those John Rosengrant figures are very very good--same as in the Dio I believe Bodgey is talkin about----------here's one more step for that one----oil color flesh-base applied
Pawel
 ~~Yeah totally---a huge range of possible colors for each item--of course research is needed to see what range for what items to some degree(or this blog can serve as somewhat of a shortcut )
    April 2008
Posted by *INDY on Wednesday, June 16, 2010 11:44 PM
Bodge
~~Andy---I agree everything I've seen from S&T has been smokin cool---now....if they'd just put out some more 1/35th mini-men!   I've never touched that large-scale stuff--but I'll look forward to seeing your work on them---
Now that Dio you we're speaking of --was it Rosengrant's  "Calm Before the Storm"    ?
One of the best I've seen .  John sculpted every one of these figures for the build!! (and later we're of course marketed by S&T)  This Dio was one of my inspirations for  doing something with these figures. The whole article by John is found     HERE            On painting his figures, interestingly enough, he says :
"The figures were painted in my usual mix of paints: Vallejo, Humbrol, and a bit of artists oil colour. My philosophy on painting figures is to use whichever paint type works best for the effect I'm trying to achieve. For example, my faces are painted in Humbrol enamels, but details such as eyes and brows are done in Vallejo acrylics. The 5 o'clock shadow beard tone is done with thin oil washes. It's a bit unorthodox, but it's a system I'm comfortable with."
~~It's also a system I could relate to some--I tend to use acrylic or laquer primer, paint uniforms in Vallejo and sometimes Tamiya acrylics, usually heads too--but recently taken to using oils, and for some textures and effects I use oils,enamels and inks~~
