Bandai 1/72 Destroid Spartan
    October 2021
Posted by PhoenixG on Tuesday, December 12, 2023 3:58 PM
Bakster
I am right there with you. It looks good until you put paint on it. Then, not so much. Maddening.
I often wonder if putty is more trouble than it is worth. Admittedly the scratches and gouges will look pretty bad on a finished product, but the amount of time and effort necessary to fix them is as you said, maddening.  Putty requires hours of curing.  Meaning it can take days to finish a minor fix.
I've started using CA for smaller corrections not because it needs less work but because the cure time is almost zero.  I can fill sand, fill sand, fill sand back to back without waiting.  CA allows me to finish in hours instead of the days required for putty.
On the Bench:
Bandai 1/72 Defender Destroid
    July 2014
Posted by Bakster on Tuesday, December 12, 2023 7:05 PM
Yup, about the CA. Same deal here. That has been my go to solution as well. Just every now and then I regret the decision. Most instances it works fantastic. Mainly, I think, to fill joins it works well. Beyond that, it gets dicey. Like I tried filling a depression on a flat surface. That was a MAJOR struggle. No matter what, I could not get it smoothed out. I had to abandon that and switch to a conventional filler.
Like you were saying, fillers are a major time suck.
I am stull looking for that perfect recipe.
Posted by Gamera on Wednesday, December 13, 2023 9:21 PM
Looks great Phonenix, good show!
I like to use Perfect Plastic Putty. Dries pretty fast and seems to be less trouble than superglue.
    October 2021
Posted by PhoenixG on Friday, December 22, 2023 10:22 PM
New post!
Been a while since I was back here.  "Life" had the audacity to claim it was more important than working on a build.  The lack of a post for nearly two weeks lends credence to life's claim. Smile
Thankfully it relinquished it's claim long enough for me to get some quality time at the bench today.
Missiles are done!  Almost.
I had some length consistency issues.  It's truly amazing to realize the human eye/brain can discern differences of a few thousandths of an inch.  As it were, my errors measured in the hundredths of an inch.  The differences were rather egregious.  Especially when placed side by side. Not to despair. 30 minutes with a sanding stick and I was able to fix 19 of the required 24.  Not enough to fill both shoulders, but it is more than enough to fiinish a single one.
Time for the slideshow.
My parts bin where I've been storing the missile parts.
parts bin
Beginning the assembly of the missiles and the remaining shoulder missile box/cover.  I decided to cap both ends of the missile rather than leave one end open.  I figured capping both ends would make it easier to secure them in place.
initial assembly
Capped and the edges rounded.  It was about an hour of sanding to bevel all those edges.  Boy were my finger tips and thumbnail sensitive after that.  I was worried I was going to sand a hole in my thumbnail!
beveled
First layer of the detonators installed.
detonator1
The second and final layer of the detonator was made with a .5mm punch in .01" thick styrene.  They were smaller than most grains of sand.
teenytiny
Wax pencil for the win on those.  It picked them up really well.  Held onto them well, usually, when dipping them into the glue.  And let go the moment they were applied.
I'd tried doing this with tweezers and a needle point.  Doable but not really effective or efficient.  The pencil just worked.  If placing lots of small parts, a wax pencil is totally worth the investment.
19 missiles are now ready to be primed for paint.
missiles at the ready
I'm glad I decided to put in the extra effort to add those tiny discs to the top.  They break up an otherwise monotonously smooth surface.  Plus, they should take a wash nicely to add depth to them.
I'll probably use a little blue tack to attach them to some cardboard so I can use the airbrush to prime them.
The box art makes it difficult to tell whether they are dark grey but washed out due to light.  Or light grey but darkened due to shadow.
I have some time ponder this while finishing the second missile box and installing it.
On the Bench:
    July 2014
Posted by Bakster on Saturday, December 23, 2023 8:08 PM
I can sooo relate.
I agree. Those discs add much to them. Nice work, PG! Yes
    May 2011
Posted by Real G on Sunday, December 24, 2023 1:52 PM
I'm pleased that you took the high road and made all those missiles.  They will no doubt look terrific packed into the Spartan's bays.  You're going to have one mean-a$$ looking Destroid!
“Ya ya ya, unicorn papoi!”
    October 2021
Posted by PhoenixG on Sunday, December 24, 2023 11:37 PM
Bakster
I can sooo relate.
I bet you can!
It's been an odd year.  Compared to the previous years my output has been practically nill.  The builds are becoming more involved, which I like, but the real influence seems to be less available time at the bench.  Which is somewhat annoying as I have many things I'd like to accomplish.  The proof of that is my stash finally growing to the point where it will take years to build what I have.  Not a bad thing.  Just hit that particular milestone a little earlier than expected.  :)
Bakster
I agree. Those discs add much to them. Nice work, PG!Yes
Thanks!  I was really wondering if I'd bit off more than I can chew when I started down this path, but I've been pleasantly surprised by how well things have gone.
On the Bench:
    October 2021
Real G
I so hope it will!
On the Bench:
    October 2021
Posted by PhoenixG on Sunday, December 24, 2023 11:54 PM
Hit a major speed bump on this build.  Most of the glue joints on the missile box and cover failed.  For some reason the plastic didn't meld together well.  I've spent most of today re-gluing the joints.
Yesteday I discovered I had a box of a thousand popsicle sticks.  Turns out they make really nifty part holders for airbrushing.  I attached the missiles to the popsicle sticks with a small dab of CA.  They should pop right off once they're finished and ready to be installed.
The missiles have been primed, covered with the base color, and then hit with sealer.  I picked up a bottle of Vallejo Mecha Z grey on a whim a while back and this seemed like a good time to give it a try.
missiles
I think that color will do perfectly for the missiles.
And you truly can make a paint booth out of just about anything.  In my case a cardboard box and an old vacuum cleaner.
paint booth
Literally just put the end of the hose in the bottom of the box and turn it on.  It's an old cannister vac.  The vacs standard bag/filter catches the particulates and fumes really well.  I only use acryclics but I don't get any odors with the setup. Light is provided by an LED cabinet light that I installed by cutting out a trough in the top side of my cardboard box booth.  The trough lets the light in and holds the light in place.
The guy on the left is my personal coach.  He keeps me going when I feel dishearthened.  He also helps takes care of any extra paint I have left in my airbrush. lol
On the Bench:
    July 2014
Posted by Bakster on Monday, December 25, 2023 12:35 PM
PhoenixG
I could not have said it better.
PhoenixG
Enjoy it while it lasts! The other shoe is still there. Lol. Wink
    July 2014
Posted by Bakster on Monday, December 25, 2023 12:38 PM
PhoenixG
And there it is! If it works-- the builds shall come. Stick out tongue
I love the personal coach! Lol.
Posted by Gamera on Monday, December 25, 2023 4:52 PM
Wow those look amazing Phoenix!
Good luck on finding a good cement for the boxes. I tend to just reach for the two-part epoxy when I'm in doubt.
And neat looking airbrushing box. I've done similar sorts of stuff. When you mess up the cardboard box enough instead of cleaning it I just toss it and grab another.
    October 2021
Posted by PhoenixG on Wednesday, December 27, 2023 1:27 AM
Bakster
It's always there.  Waiting.  Lurking.  I can feel it's eyes on me...Indifferent
lol Big Smile
On the Bench:
    October 2021
Posted by PhoenixG on Wednesday, December 27, 2023 1:35 AM
Gamera
Thanks Gamera!
I got them back together with some judiciously applied Tamiya extra thin, plus clamping with the newly found popsicle sticks.
I'll have to find some of that perfect plastic putty you mentioned earlier.  I got the boxes installed but having to do a lot filling and sanding to clean up the areas where they join the shoulders.  Thinking I should have those done in the next day or two.
In the meantime the missiles have received their yellow dabs of paint on the tips and are awaiting a dark wash to add some shadow.
For the moment I am deliberately avoiding the hinge for the missile covers.  I think that can wait till almost the very end.
Looking forward to finishing the cleanup of the missile boxes and resuming the rest of the build.
On the Bench:
Posted by Gamera on Wednesday, December 27, 2023 9:32 PM
Sounds good!!!
I ordered my PPP off Amazon. I don't remember if it was from them or someone else that sells though them.
    October 2021
Posted by PhoenixG on Thursday, January 4, 2024 12:24 AM
Have both missile boxes installed and primed.  The joins aren't perfect but they are good enough for me.  Still need to build and affix the emblems to the missile covers before they can be primed.
Quick and dirty photo of a dry fit.
lousy photo
Nothing is glued together.  The torso is just resting on the legs.  Completely missing the waist, but wow.
Dang he's looking mean, but in a good way.
On the Bench:
Posted by Gamera on Thursday, January 4, 2024 5:05 PM
Good to see her still coming along!
    May 2011
Posted by Real G on Friday, January 5, 2024 12:27 PM
Big SmileBig SmileBig Smile
    October 2021
Posted by PhoenixG on Saturday, January 6, 2024 1:26 AM
Momentum on this is building now that I've been able to shift focus.
A few months back I picked up a bottle of Vallejo Mecha Matte Varnish to try out.  After testing it out discovered it is more of a very soft satin finish that is quite nice, but not matte.  However, when cured it seems to be a lot harder than Vallejo's normal line of varnishes.
sheen
I painted the joints black and then covered them with that varnish as these are high wear areas and prone to rubbing and scrabbing.  This will be a real test of the durability.
Because all the legs joints are black I painted them before assembly and then masked them to protect them during the painting of the rest of the model.
masking
If I did it right the mask should easily peel off once everything else is done.
The main torso is glued up with the central cannon door painted before installation and masked for protection during the rest of the build.  Arms are attached using semi-permanent method. The vents on the back of the shoulders have been installed with a light coating of white glue.  That way if the arms ever become loose I can easily get access to the plastic eclip to remove the arms and work on tightening them up.  Having said that I am now thinking about the rare earth magnet method Real G brought up a while back.  Something to consider...
glueing
I've had to glue the torso and legs together panel by panel because the parts were warped just enough that it wasn't possible to glue them all at once and maintain good alingment. Even with clamping.  It's been a slow process but it will mean a lot less correction needed on the back end.
Once the glue on the legs and torso completely cure the cockpit and final bits and bobs can be installed.  At which point painting will begin in earnest.
Funny story about the glueing.
I'd started on the first leg (the ones being held by the large yellow clamps).  Clamping them together with the little green and black clamps you see.  While the glue was setting up I was across my garage drying some CA (different story) when I hear this loud "BANG" like something metal had fallen off a shelf or from my workbench.  What made it weird is there is nothing large or metallic on or above my bench that could have fallen.
I start looking around and can't find anything out of place. Everything looks normal.  I'm about to attribute the noise to poltergeists when I notice one of the clamps on the leg is missing. After some searching I find it on the ground 8 feet away.  It had flown off with enough force to go sailing across the garage.  The noise I'd heard was it hitting and bouncing off an old empty paint can that had been sitting on top of the opposite bench!
Pretty sure that would have left a mark if I'd been near it when it let go.  LOL
Needless to say no more little clamps on those legs.  Only the big beefy ones now.Big Smile
On the Bench:
    October 2021
Posted by PhoenixG on Friday, January 12, 2024 12:10 AM
And just as quickly as progress started speeding up, it slowed down.  During painting I found lots of places where it would be possible to see internal unpainted sections in the original green.  I didn't like the effect this would create.  The solution was simple, but it added another step.  IE it took more time, but it is of benefit to the overall aesthetic of the build.
Taking the path of least reasistance meant a simple black coat to all the internals which would hide the green and any overspray should look like shadows. That is the hope.
The last few days have been spent blacking and then clear coating for durability due to proximity to rub spots.  Then time curing in the drybox so as to harden the paint and clear coat as much as possible.
Progress!
legs
Most of the priming coat went down beautifully.
It did reveal a few seams that would have a negative effect on the model.  Much sanding has been done and most issues have been fixed.  YAY!
However, a few stubborn ones required putty.
Have I mentioned lately how much I loathe putty?  Vile stuff.  Fills where you don't want it and sticks everywhere but where you need it.  Bang Head
gag-putty
Despite the putty's attempts to sabotage me I did manage to get some decent work in.
Still, not good enough.  I was getting a little fed up with the putty so decided to go back to CA because I tend to have better luck with it.  Somewhere I read about coloring the CA so as to be able to better see the work.  My paints are water based so that was a no go.  Tried adding a little Chalk pastel to it.  It sorta worked.
CApastels
One hiccup though.  My pastels appear to act like a slow acting accelerator.  After a couple of mixes and applications it turned to rock.  Despite that slight drawback it seemed to work pretty well.
sanded off
CASandedPastels2
But then my bottle of CA glued it's cap to the applicator tip.  When I tried to take it off, it broke off at the base.  Indifferent sigh.
Back to putty till I get a new bottle of CA.  Which is inconvenient as the cockpit had several unsightly pin holes appear in the seams around it's base.  Apparently the plastic was still soft when I unclamped it a day later and the body flexed just enough to cause it to pull away in a couple of spots.
The putty didn't apply very well.  Thinking it could be good enough.
cockpit
I'm really hoping those streaks of putty won't show up in the primer.  Finger crossed.
Despite these little frustrating moments the build is coming together nicely.  I'm starting to be able to visualize how the final product will look.
Gamera, I purchased a bottle of Perfect Plastic Putty to try.  It will be intersting to see how different it is from the Tamiya and Vallejo putties.
Sometimes the problem is the materials being used. Sometimes it's the person using the materials.  The jury is out as to which is which when it comes to me and putty. Big Smile
On the Bench:
Posted by Gamera on Friday, January 12, 2024 10:31 PM
Somehow I missed you earlier post Phoenix but you're making solid progress now.
Hope the PPP works out for you. I've had good luck with it.
Maybe I'm weird but I've had much better luck with putty than superglue. Never had much luck with it.
    October 2021
Posted by PhoenixG on Wednesday, January 17, 2024 7:05 PM
Good news.  The legs turned out great.  Only a few small spots that I think are acceptable.
legs
However,  the torso still has many visible seams.  Not horrible, but they bug me.
This is effectively the abdomen of the torso.
Lower front
The cockpit canopy has a very sloppy putty bead that I want to clean up. That bit of a dent on the cockpit I believe was part of the mold.  Should make for a fun bit of wear or battle damage. :)
right side of pilot
left canopy
This back panel on the torso is troublesome.
back plate
back plate 2
Cleaned and puttied up everything.  Left it to cure overnight.  Hopefully tonight I'll get some time sanding and priming.  Fingers crossed that this is the final round and can move onto the next step of assembly.  :)
On the Bench:
    October 2021
Posted by PhoenixG on Wednesday, January 17, 2024 7:21 PM
Gamera
Hey Gamera,
Gamera
I'd hoped the ordered PPP would show in time for testing, but I've ended up doing everything with the Vallejo.
Moment of irony.  Did all that puttying last night and guess what shows up today?  That's right, the new tube of PPP.  LOL
Gamera
I think fillers are kind of like paints.  We all have different experiences with them.  In the end we work with whats best for us.  I just keep hoping that I can find a putty because my biggest fear is that I accidentally glue the model to my bench while trying to fill a seam.  Big Smile
On the Bench:
    October 2021
Posted by PhoenixG on Tuesday, January 23, 2024 12:09 PM
A small delay in updates as I recently picked up some items to help organize my bench.  It took a little time to implement them.
With that, back to where I left off.  Which was putty.
I'll save y'all from more macro photos of putty and summarize.  That last attempt was good enough.  Moving on.  :)
I  added slots to the ring at the waist ring so that I could easily separate the upper and lower halves for painting and final tuches.
half ringfull ring
Assembled and primed.  Missiles won't be added till everything else is done.
posed
pose2
This will essentially be a duplication of the paint Scheme I did on the Missile Phalanx.  Starts with pre-shading with Vallejo Gunship Green.
About halfway through I thought I'd grabbed the wrong green.  Why? because it was same color as the original plastic!
I placed a part of the model still in bare plastic at it's feet to show the color similarity.
ICK
Went back to photos of my work on the Missile Phalanx to verify the color.
phalanx comparison
Looks like Gunship Green to me.  It feels weird painting it the same color I put in so much effort to hide.
Apparently Gunship Green is a good color for pre-shading but not as a base color for the Spartan. :)
Now that bit of confusion is cleared up I can resume the pre-shading and get the upper torso done.
Bit of a tangent here.  Question for the group.  Do any of you keep a record of the paints used on a specific model as well as any notes on custom mixes?  I guess it could be called a paint or build journal?  Just curious.  Now that I've been building for a few years I'm finding that on occasion I want to duplicate something I did before but I can't always remember what I did or find the random notes I may have scribbled down.
Right now my paint journal consists of whatever notes I wrote on the walls of my paint booth.  Which isn't exactly the best place to keep them.  Be interested to hear any tips or practices that have worked well for others.
On the Bench:
Posted by Gamera on Tuesday, January 23, 2024 8:26 PM
That looks great to me Phoenix! I know what you mean about painting something the same colour as the plastic. When I was a kid if I had a tank etc in the right shade I only painted the tires etc. But the plastic never looks right without paint. And considering you're puttying and sanding the seams you pretty much have to paint it to get everything the same colour.
Looks like you've got all the seams knocked out in the newer photos.
And you're very right about the putty, it's just a matter of finding what works for you and then use it. One of the things I like about the PPP is that you don't always have to sand it. Just put it on and wait five mins. and then rub it with a moist cotton swab and it will take off the PPP except what's in the gap.
I haven't cemented a model to a desk yet but I have used superglue to cover seams and had only the outside dry. When I started sanding it broke though and I got superglue all over the sandpaper, the model, my hands, everywhere. I was only using a little bit of superglue or I would have ended up with the model glued to my hands... Sad
I don't generally keep any records of what paint I used but I wish I did. Working on a T-64 and I have about five bottles of Soviet/Russian green that are slightly different shades and I'm not sure which one I used on the model. I don't often mix my own batches simply because if I need to redo something rematching is such a pain.
    October 2021
Posted by PhoenixG on Wednesday, January 24, 2024 2:04 AM
Made the emblems today.  Simple trapezoid so I figured I could just measure it.
The original piece
original
Then draw it out and cut it.
diagram
Taped two pieces of sheet together so a single cut would produce two identical pieces.
prepped
However, my cuts weren't or diagram wasn't as accurate as needed.  They turned out a little wonky.
wonky
Figures sanding to round the corners would even it out some.  It worked well enough.  They'll get some clean up sanding once the glue has set.
attached
The covers just resting on the shoulders.
model
I must say that I like the look of the scratchbuilt covers better than the originals.  Something about the slightly uneven creases gives lends veracity to look.  At least to my eye it does. Smile
Needed to get these done so they could be finished, primed and then preshaded with the rest of the model.  Because I painted all the parts of the Missile Phalanx separately the color didn't look very consistent.  My goal here is to get all the major pieces painted together so the overall color scheme looks more consistent.
The covers will be posed open in the final portion of the build.  Still haven't figured out a workable hinge attachement.  I tried slightly scoring some sheet styrene to create a hinge but it simply snapped where it had been scored.  May try heating a wide strip of styrene to create a soft bend like I did for the tops of the covers.  We'll see.
On the Bench:
    October 2021
Posted by PhoenixG on Wednesday, January 24, 2024 2:22 AM
Gamera
That looks great to me Phoenix! I know what you mean about painting something the same colour as the plastic. When I was a kid if I had a tank etc in the right shade I only painted the tires etc. But the plastic never looks right without paint. And considering you're puttying and sanding the seams you pretty much have to paint it to get everything the same colour. Looks like you've got all the seams knocked out in the newer photos.
Thanks Gamera.  The color matching for the pre-shade was unexpected and simply surprised me.  The final color will be a mix of ochre and sandy yellow.  The green pre-shade is to make the edges stand out more.
The seams are definitely better and it turns out most of the ones I was stressing about were hidden by the arms when they were attached.  Live and learn.  :)
Gamera
And you're very right about the putty, it's just a matter of finding what works for you and then use it. One of the things I like about the PPP is that you don't always have to sand it. Just put it on and wait five mins. and then rub it with a moist cotton swab and it will take off the PPP except what's in the gap. I haven't cemented a model to a desk yet but I have used superglue to cover seams and had only the outside dry. When I started sanding it broke though and I got superglue all over the sandpaper, the model, my hands, everywhere. I was only using a little bit of superglue or I would have ended up with the model glued to my hands... Sad
I've had the exact same problem with the center of the CA being wet when the rest seemed hard and dry.  Because of that I've taken to hitting it with a blast from what is effectively a hot air gun.  That's taken care of the problem with the thickest parts of the CA being unexpectedly wet..
I'm looking forward to giving the PPP a try on my next model.  I'd really like to settle on a putty that works well for me and can stop griping about it.  :)
Gamera
Most of my models have at least one custom mixed color.  It's been the best way for me achieve a color match.  The problem you described with the T64 is pretty much what I've been experiencing.  My current thoughts are to take something like a composition notebook and label each build with mfg., model, and scale. Including specific paints selected and any details around any customization I've done.
For this build I misplaced the sheet where I had recorded the measurements of the missiles.  I found it only to discover it coverd with paint from using it as prep for dybrushing.  Thankfully the numbers I needed weren't completely obscured so I'll be able to cut the rest of the missiles I need to the proper length.
I'm thinking that having a book specifically for recording the info will help prevent the problem in the future.  I'm not the most organized person so it's a new habit I'll be trying to form.  Time will tell as to how successful I am with it.
On the Bench:
    July 2014
Posted by Bakster on Wednesday, January 24, 2024 10:11 PM
Nice progress on this and nice work with the scratchbuiding. Yes
    May 2011
Posted by Real G on Thursday, January 25, 2024 11:51 AM
Looking good PhoenixG!  I'm liking it more and more as you progress through the build!
    October 2021
Posted by PhoenixG on Thursday, January 25, 2024 11:40 PM
Well I broke my airbrush again.  Ruined another nozzle and this time the needle too.  Apparently I managed to put a pretty significant bend in the tip of the needle and just chewed up the tip of the nozzle.  I'm thankful I finished the preshading before that happened.  My back airbrush isn't quite as nice but does a good job of with general coverage.
What the preshade looked like finished.
preshade
First base color applied.
first base
The light is realy strong so the colore is slight washed out.  It's actually darked than pictured.  A second slightly lighter color will be added for highlighting.  The missile covers will be done in an off white with the emblems painted a scarlett red.
Then the fun of detailing and weathering will begin!  Big Smile
On the Bench:
