GAF
That's great! What did you use for the monolith?
I built up the monolith by using some leftover styrofoam (which next time I do this I'm getting the purple foam core stuff, the white stuff is a mess to work with), measured out the correct dimensions on plastic styrene sheets and then glued it over the styrene. The plastic sheets I had couldn't cover the complete height, so I had to glue two together, which did result in some uneven bowing on one side :(
Turns out making a box, and making it nice and smooth and even is pretty tricky! LOL.
I made sure I could take out the foam core, and that's what will hold my LED lights. I attached some sprue scraps to form attachment support so it would mount to the bottom section.
Now I'm trying to add some detail with bits of stone and foam and then modeling paste.
![](https://lh3.googleusercontent.com/pw/ADCreHdlelANGVmOaYCeXn6WjtbjPmDjh2PP5FJTeC1hj52_mxk78cLb-iv0EC1Mv3SWQ2mbg1rSwmtlXNqzP4gR1MqCWlNeol8LPFSJknT3Trc5uHvSZBJbIG1pz6harmAVXxtUfsQ-LCmlKduN_zay7Lk1LQ=w656-h875-s-no-gm?authuser=0)
![](https://lh3.googleusercontent.com/pw/ADCreHe2IRRfNM8Yw0RlzXEXWB4yO5xgJMPGDGCbGR9SDB6le2cnhkD61k68HqoLuLGrCwr6HB9w47CJO0cuf1QDYYwIMAefnGuBZc_bb2ydpD02PNYX886Z9r5MapSZCphBVSd0EZ_v2rfUW-6mIkr_6KcJfg=w656-h875-s-no-gm?authuser=0)
![](https://lh3.googleusercontent.com/pw/ADCreHdBjmyL7JzWuk9Ct5yKoYhvn2zh15qmAgXLymj39OjuW3fuTt_okE1pmnGk9C271zoBdZ1j5yiY3XhpQ-wq3uhxgrSFSM0XilXQO_O5J67julJd-M-nUoXkG5Qg5fO2SzsaOk97W4GmoH9iuzQ5DvNZSw=w1167-h875-s-no-gm?authuser=0)
![](https://lh3.googleusercontent.com/pw/ADCreHfLutiYi1zBOxqrObw8WusZGh2OfDkZDPTkRHPejliaNa4HsztUpK-kr_uBso-Ec5KGL4ILUmav9wOVASXZ2jmkXhli_UYYKpojECCuYE-H5wzcRpW0Hz7xCot3PtDE4W8pqJdc3BwVvoHmZ1BWRJV5eA=w1167-h875-s-no-gm?authuser=0)
Not sure how this is going to turn out, this is my first time doing something like this. The modeling paste goes quick! And it's $17 a jar!
