Sinanju WIP *warning very pic heavy*
    April 2008
Posted by smeagol the vile on Wednesday, April 22, 2009 7:24 AM
Thats a very cool weapon
    February 2009
Posted by Sian on Tuesday, April 28, 2009 10:07 PM
Okay, bazooka is painted, still needs details.
 The bazooka rockets are painted as high explosive dual purpose. I don't like how they turned out, deciding to paint them by hand was a terrible idea.
 Thrusters are painted, still need to be cleaned up a little and detailed. Most of them are really rough around the masked edge. This will probably take a good deal of cleanup.
Shoulders
Hips
Back
Wings
Legs
Sadly I misplaced the thrusters that go on the calves, just found them, and they need painted separately. *sigh*
    February 2009
Posted by Sian on Sunday, May 10, 2009 6:51 PM
Okay, got the thrusters sorted out. Calf thrusters are painted, and the best looking job of
the bunch. I sprayed them all with tamiya smoke on the outside, and it's a pretty good look.
 I modified the calf thruster mounts as the new mechaskunk thrusters are a few mm too
long. This was easy because there was a panel line at just the right spot, and I could saw
right through with my xacto razor saw blade.
Thrusters: DONE!
Fuel tanks: DONE except for decals and black
Weapons: DONE except for decals and clearcoat
I swear the next thing I do will be the red armor. I'm still trying to decide whether to go with
clear red or guards red. I've got to make sure my preshading work shows through, but isn't
too obvious. augh.
    December 2003
Posted by psstoff995 on Sunday, May 10, 2009 7:49 PM
Never done a Gundam model, wanted to, just never have. I'd say though, start layering on the clear red, maybe after a few coats if it's still too clear, layer on the guards, which I'm assuming isn't translucent. I think that way would be easier to correct as opposed to starting out with the solid color then changing your mind for the clear?
Don’t know if that made sense...
-Chris
US Army Infantryman
    February 2009
Posted by Sian on Sunday, May 10, 2009 9:40 PM
Yeah, and I'm leaning this direction.
Not the least reason being that the tamiya paints are just so blasted easy to use and airbrush so well. the modelmaster paint keeps clogging my airbrush tip.
    February 2009
Posted by Sian on Tuesday, May 26, 2009 4:24 PM
Just an update to show I'm still making (slow) progress.
Yes, it CAN hold the Monster Gun O' Doom!
    February 2009
Posted by Sian on Monday, June 1, 2009 7:53 PM
Got my primary painting done today.
First, I shot it with just thinned Tamiya Clear Red.
That just wasn't covering my rather heavy-handed undershading. So I added most of a bottle of MM Guards Red.
There we go!
I'm gonna need to temporarily re-assemble the head again to get the faceplate alignment right. A couple of tube beads are going into the gun ports up here, I've already got them widened.
Primary painting: Done! I'm gonna let this cure so I can hit it with some Future tomorrow, and then dry transfers! Aiiee.
    February 2009
Posted by Sian on Tuesday, June 2, 2009 5:28 AM
Masked the zeon winged crest on the chest and shield with BMF
FFFFFFFFFFffff That was hard!
I'm going to spray these then forget I ever wanted to do this.
The rest of the gold trim will be hand-painted.
    April 2008
Posted by smeagol the vile on Tuesday, June 2, 2009 3:02 PM
BMF?  Whats that, looks like tin foil to me
    December 2003
Posted by psstoff995 on Tuesday, June 2, 2009 5:50 PM
Bare Metal Foil, self-adhesive backing I think? Aircraft thing... lol
Looking great!! Love how that red turned out Thumbs Up [tup] And I'm still shocked it can hold that huge gun... Shock [:O]
-Chris
US Army Infantryman
    January 2009
Posted by Mercedesman on Tuesday, June 2, 2009 5:50 PM
BMF - Bare Metal Foil - a modelers self adhesive super thin metal foil - comes in aluminum, bare metal, gold, black, etc...
    April 2008
Posted by smeagol the vile on Tuesday, June 2, 2009 6:18 PM
These kits arent like the kits of old, the Joints are so well reinforced, many of the master grade kits actuially have screws for the shoulders and elbows.  I did the Perfect grade Zaku II, every joint had atleast two metal screws to hold it.
    February 2009
Posted by Sian on Tuesday, June 2, 2009 6:36 PM
 smeagol the vile wrote:
These kits arent like the kits of old, the Joints are so well reinforced, many of the master grade kits actuially have screws for the shoulders and elbows.  I did the master grade Zaku II, every joint had atleast two metal screws to hold it.
The latest generation seems to have gone to ABS plastic for the inner frame, which has some natural give and can are basically really tight polycaps on their own without wearing down like the old styrene-on-styrene joints. (I'm looking square at you, Gouf Custom)
So the masking experiment was a total failure. Not only did it produce results worse than if I had just hand-painted, but the old BMF left behind residue, and the painters-tape I used on the shield pulled up the paint. I'm never going to combine masking and unprimed painting again. I'm pretty sure I'll have to re-do the red shield completely, the black parts might be salvagable if I can clean the adhesive residue off without marring up the paint too bad.
    February 2009
Posted by Sian on Friday, June 5, 2009 7:39 PM
Jeez the sinanju dry transfers are impossible.
I've just finished up the fuel tanks, 14 decals, I've ruined 2 (one of them actually flipped itself over on the film before I could apply it) and there's 123 of them in total.
 is there *any* account of anyone actually applying all 123 without incident?
 *orders waterslides from hobbywave*
    April 2008
Posted by smeagol the vile on Friday, June 5, 2009 9:53 PM
I dont know which I like better, waterslide or dry transfer... Dry transfer go on SO clean and look real, no edges no nothing, but waterslide are so easy to put on.
    January 2009
Posted by Mercedesman on Friday, June 5, 2009 10:13 PM
Waterslides are THE way to go in my opinion.  The dry stransfer, even when go on correctly - have a lot of silvering aorund the open parts.  With waterslide, once you gloss the surface and apply the decal, then top coat it - the edges completely disappear and they look painted on.... but thats been my experience.
    February 2009
Posted by Sian on Thursday, June 11, 2009 10:43 PM
About half-way done with decals now, and damn.
Forget about using the white line dry-transfer decals. Just forget it. They'll partially attach while you're positioning them or the piece will just be too sharply curved or something, but you'll be lucky to get half of them down. Just get the waterslides.
Other than the white lines though it's fairly successful.
up next:
Finish Decals
Hand Paint Gold
Hand Paint Details
Gloss Coat All Again
Blacklining
Dull Coat Red Parts
DONE
I hope to be finished before July. >_>
Tomorrow I get the stand and waterslide decals.
    February 2009
Posted by Sian on Saturday, June 13, 2009 3:51 AM
Got another couple of hours into decals, about 100 left, I think. About 6 moure hours should do it.
Got my Sinanju base too, opened it up and sprayed the base with the same red mix the Sinanju is covered with.
 Then I tried to decal it.
 After the decal wouldn't release from the backing after 5 minutes underwater, I started to wonder.
NOBODY TOLD ME THE ACTION BASE HAD STICKERS, OKAY?
Once that was sorted out, things went swimmingly. but.. stickers? Really?If I had to do it over I'd be sorely tempted to scan the sheet, color correct, and print out waterslides.
    April 2008
Posted by smeagol the vile on Saturday, June 13, 2009 2:10 PM
HAHAHAHAHA OMG HAHAHAHAHAHAHAHA
you soaked stickers in water, Thats so ****ing funny.  Oh my god I almost fell out of my chair im laughing so hard.
Bandai kits in general come with 2 things
A - stickers
B - Dry transfers
also, your insaine for doing that many decals.
    February 2009
Posted by Sian on Saturday, June 13, 2009 4:33 PM
Some pics.
Turned out pretty good. I've still gotta give it a layer of future, and flat the red, to match the Sinanju itself. red on top of red gave it a bit of a different tone from the red-on-preshaded b&w of the sinanju, but I call it close enough for an action base.
Shield crest cleaned up quite well with just some gundam marker. I had to scrub a lot of the Future off to fix some oopses, but a fresh coat on top and I think it will look *fine*
    April 2008
Posted by smeagol the vile on Saturday, June 13, 2009 5:42 PM
are you not going to detail the action base?  Im working on mine right now, Im REALLY enjoying it.
    February 2009
Posted by Sian on Saturday, June 13, 2009 6:04 PM
 probably not past blacklining to bring out the texture. I don't want it to distract from the model! ;)
    February 2009
Posted by Sian on Sunday, June 14, 2009 3:53 AM
quick poll: does the MM brass look good, or is it too pale? I can go over the top of it with some bright yellow gold, or leave it as is.
    April 2008
Posted by smeagol the vile on Sunday, June 14, 2009 12:55 PM
do alittle mix.  Get a piece of scrap and put the brass, the gold, mix it to diff consistancies, till you find what you want
    February 2009
Posted by Sian on Thursday, June 25, 2009 6:52 AM
Redid the gold, putting reaper gold over the top. I still need to do some touch-ups, and I kinda boneheaded it a bit, but it's a lot better now.
before:
after:
Using the toothpick technique to insert the tube beads, 1mm and 2mm. Here's a 1mm in the heel.
I had to modify this piece, as to install it after filling the seams on the hip pieces, the bottom part had to go. It doesn't hurt a thing.
Just got some touch-ups left to go. The dull red and shiny black really do look nice together!
    February 2009
Posted by Sian on Friday, July 3, 2009 9:54 PM
I've painted some highlights onto the gun and bazooka to make them look less plastic, and added some more silver details.
Now here's some preview images. Excuse the dust, I didn't brush it off before taking these shots. Here I'm mostly showing off the addon parts. Mechaskunk thrusters, tube beads, model-up verniers, etc. The head vulcans use the socket pins from the model-up foot vernier pins, which worked out really well.
little verniers on the bicep were drilled out and replaced with 1mm tube beads.
Showing off the leg thrusters and bits.
Backpack
Hip thrusters
Some of the inner detail on the wings, and more tube beads, 1mm and 2mm
Rear shot
Ankle. You can kind of see how shiny the black is in contrast here.
I still need to go over the gold once or twice more, it still looks uneven. I'm getting there!
    December 2003
Posted by psstoff995 on Saturday, July 4, 2009 11:13 AM
wow... looking reaal good
-Chris
US Army Infantryman
    February 2009
Posted by Sian on Saturday, August 1, 2009 1:35 AM
Is finished! Pics in a new thread tomorrow after a daylight photo session.
    February 2009
Posted by Sian on Saturday, August 1, 2009 11:21 PM
Thanks for watching, everybody!
/forums/1168948/ShowPost.aspx#1168948
