Hi Everyone! Sorry this update took so long to get uploaded. December was a very rough month for my secular work so very little was done on Enterprise x 3. I have 22 new pics in the Updates for January page
For Enterprise updates:
I needed to get all of the viewport glass in place as well as the wiring and lighting for some of the spot lights and the warp engines in place before I could put the Hanger and Botany deck pieces in place. So I added the clear pieces into the hull first. This included the Botany Deck Viewports.
I was then able to add the exterior lighting on the other two engineering hulls and get all of the spot lights aimed to their proper locations. There are 7 Spots on each of the hulls. To insert them and secure them in place as well as aim them took about 2 - 3 hours each. No easy task because of the limited amount of room to work in with each of these models. In the November update I was able to get the first model done, but I learned from that one what NOT to do on the other 2. With the polar Lights Enterprise you can work on one half of the hull at a time, then assemble the 2 halves together. With the DeBoers, the hull is already one piece so you have to try to get your hands into that limited space. So it is very time consuming.
I was also able to finally put the saucers back on so all of the ships are basically assembled. I also added all of the upper and lower saucer spot lights and they are all in place. I was able to get one of the saucer Interior lighting in place this month. I'm using some 4" fluorescent tubes that run off of ballasts and require 12v. to operate. I just have 2 more saucers to put the lighting into, but I do have a good pic of the lighting tests with these fluorescent mini lights on. There are also a couple pics with the warp engines on. By the next update I should have all of the lighting done in the saucers as well as the torpedo launcher effect and other lighting effects such as the impulse engine effect. I am looking forward to sealing up this ships and getting ready for the next phase of 2 of these build.
That's all for this months update. We'll see you next month.
Mark
