SUB ASSEMBLY (Type VIIC/41 UBOOT ....October UPDATE 10-1-23)
    July 2003
  • From: On my kitchen counter top somewhere in North Carolina
Posted by disastermaster on Sunday, August 20, 2023 5:26 PM
05100 Revell Type VIIC/41 U-BOOT 1/144 scale
It’s been a while since I’ve posted a subject build, so here I go. It won’t be fast but I hope you'll enjoy it.
Make sure to click on the pics for a larger view.
 There’s been more submersible projects here lately, so today I thought I’d dive in also.
Fire one!
Starting with the hull assembly. I decided to install a 8” steel rod (10 ounces) for some stability and, just because I can.
Fitment check. I will remove the deck to paint it separately and save a lot of masking time.
I've added texture to the armor plate of the lower hull but it doesn't really show up here.
But don't worry, I will make it so.
After an overall aerosol of light grey, I masked the upper section and
painted all of it spray can black.
                                More to come as I have the time.
    July 2003
Posted by disastermaster on Tuesday, August 22, 2023 3:34 PM
Type VIIC/41 8-24-23 update
 I airbrushed the deck with dullcote for good surface/paint adhesion then applied a yellowish/brown Tamiya mix with some airbrush shading till it looked good to me. I followed with an airbrushed layer of Future followed with some hairspray.
Click the pics for a larger view.
Next, a layer of Tamiya XF-85 rubber black.
I’ll add more wearing and color later.
* Has anyone wondered what the four hatches on the forward port side of the deck are for… ..?
Each hatch is storage for a for a Dinghy.
 Except for Tamiya paints and alternating coats of future and dullcote, nearly everything past this point will be hand painted using;
Delta
Folk art
Graphite
Charcoal
Americana
Apple barrel
water color paint
water color pencils
Pastels and Oil paints
fine tip acrylic color markers
http://th38.photobucket.com/albums/e105/CommentCrazyGirl/Smileys%20Action/Read%20School/th_backpack.gif and about anything else that will stick.
                                              Until next time.......
    July 2003
Posted by disastermaster on Thursday, August 24, 2023 5:38 PM
http://th302.photobucket.com/albums/nn116/imagoodone4sure/smileys/th_themoticon_confused.gif........Where is everybody?
    July 2003
Posted by disastermaster on Tuesday, August 29, 2023 1:00 AM
Type VIIC/41 8-29-23 update
Wake up folks...............
Moving astern.
Assembled and painted snorkel.
The running gear before any painting.
And my “proper props” as painted. More embellishment later.
Forward bow planes with cables (in progress) and a bit of paint.
Here are the unpainted railings for the Conn.
Added some screening detail to the railing of the upper forward conn.
After sub assemblies are complete, It'll all start coming together fast.
More coming later…………..
    May 2009
Posted by Pawel on Tuesday, August 29, 2023 4:36 AM
Hello DM!
I hate it when I post a WIP and nobody says anything... I'm going to help you out!
Those rails are a challenge at 1/144 - very fine castings and yet in this scale they look a tad heavy, at least in this close-up. But I guess there's no realistic work around on that...
And could you tell me what "Americana" and "Apple Barrel" are?
Good luck with your Boot and have a nice day
Paweł
www.vietnam.net.pl
    July 2003
Posted by disastermaster on Tuesday, August 29, 2023 2:00 PM
Pawel
Hello DM!
Paweł
 Thanks Pawel!
You've helped me several times before and I appreciate it!
 I guess they're so overcome with awe their hands are paralyzed.
 It's been a while since I've posted a build. A few weeks back some one here mentioned that there wasn't as many build postings since taking the time to compose & take in-progress pictures can be so time consuming.
Well, quite honestly..... it is. In my case it has been doubly time consuming..... but I rarely ever quit.
*That's why I decided to put this post up a second time to help remedy that.
With all the trouble I had trying to figure out what the problem was with the first one (when the picures were all screwed up) I was just about to abandon this subject and let it float (sink?) away. Thanks to Tim, he graciously took that post off the forum.
 Apparently there was an image problem that covered over the "edit" option. I've never had any problems with composing a subject before and I couldn't fix it from my end.
And yes, those railings look a bit overweight but they are really frail, delicate and very  prone to breakage. So because I enjoy weathering, the final finish might be a bit heavy too.
The "Americana" and "Apple Barrel" are cheap craft paints found in a lot of the thrift stores, Hobby Lobby, Michaels and Walmart that can be used for brush painting.
They are very helpful when being used with clearcoats. Here are some sample images.
                   I'm A........
Check here......https://www.google.com/search?sca_esv=561038293&sxsrf=AB5stBg8dcYKHVNIUUBI9iVi9Xzy9lKkbg:1693335148297&q=craft+paints&tbm=isch&source=lnms&sa=X&ved=2ahUKEwjOuv__xIKBAxX2FmIAHQEMBv4Q0pQJegQIDRAB
                                    Thanks again....
*  And to add more aggravation I had to retype this all over again because Finescale logged me out.
                                                           What's next?
    July 2003
Posted by disastermaster on Saturday, September 2, 2023 12:31 AM
(Type VIIC/41 UBOOT 9-2-23 update)
                   http://th210.photobucket.com/albums/bb252/Ronnies_Pets/smileys%20emoticons/th_21cid5F00ec01c5e28d2454a4cdc0247d02.gif
I’ve just about finished modifying the stern jumping wire supports using heated/stretched plastic Q-tips.
And testing the fitment…..
 Yes,  more “SUB Assemblies required.”
And the source for some of the cable parts shown below.
Drilled out for cable detail.
Coming together piece by piece.
    May 2020
Posted by Hutch6390 on Saturday, September 2, 2023 7:33 AM
I like the paint prep you've done, DM, and the cable detail is great!  This is a very nice kit - I built one for the 50 shades of Grey GB a while back, I look forward to seeing yours finished.
Vell, Zaphod's just zis guy, you know?
TakkaTakkaTakkaTakkaTakkaTakka
    March 2009
Posted by surfsup on Saturday, September 2, 2023 9:59 PM
Really nice work so far. Will be watching along with this one.....Cheers mark
If i was your wife, i'd poison your tea! If Iwas your husband, I would drink it! WINSTON CHURCHILL
    July 2003
Posted by disastermaster on Saturday, September 2, 2023 10:21 PM
Hutch6390
Good to hear from across the pond!
 I'm taking a day or two to do some things around the house... things like cleaning up my car and a bit of maintenance on my truck.
 I'm going all out on this subject and creating a lot of scratched parts along with using a LOT of hand brushed painting. No photoetched parts will be used on this.
 I'll be back to this project soon and I'm going to make it look as real and used as I 've always done with all of my tank projects.
Stayed tuned. You and Pawel are the only replies so far. All the others were ME updating progress.
GAF
    June 2012
Posted by GAF on Sunday, September 3, 2023 11:20 AM
Well, add a third to the replies, though I can't say much concerning ships.  I will say that the detail work you've endeavored to create is amazing, considering.  I did a Gato class submarine sometime back and realized even the rigging for the antenna masts and guardrails was a chore!  I'll try to follow along.
Gary
    May 2020
Posted by Hutch6390 on Sunday, September 3, 2023 2:50 PM
disastermaster
Stayed tuned.
Yes, for sure Big Smile  I was quite pleased with how mine turned out, but I'm watching to see what ideas I can pinch from you in case I fancy doing another one - I'm taking notes already, looking good! Wink
    July 2003
Posted by disastermaster on Monday, September 4, 2023 12:35 PM
surfsup
Really nice work so far. Will be watching along with this one.....Cheers mark.
More stuff  on the list
                                    ......coming soon.
    July 2003
Posted by disastermaster on Tuesday, September 5, 2023 4:08 PM
GAF
Gary
 Doh emoticon (Hand gesture emoticons)Ships really aren't my forte, but for some unknown reason I'm attracted to WWII submarines. Of course the smaller the scale, the harder it is when concerning intricate detail. The reverse of that would be, the bigger the scale the less room you have for the result.
 And as we all know, there has to be a trade-off there somewhere
 Hang with me, because when you see how I'm doing the rigging and the overall results I expect when this is completed, you just might want to challenge yourself too.
http://fc04.deviantart.net/fs70/f/2010/020/2/0/Eyes_by_krissi001.gif Any model you build just teaches how to do the next one better.
 Right now I'm working with the fore and aft jumping wire details. Making the required parts just makes me think harder. I'll be putting it up here soon.
    http://th231.photobucket.com/albums/ee109/mfhooligan/Smileys/th_thencore-1.gifThanks for looking in.
    July 2003
Posted by disastermaster on Sunday, September 10, 2023 5:33 PM
back.gif image by CommentCrazyGirl
             with
             :frantic:
U Boat Jumping wires.
http://i1160.photobucket.com/albums/q482/GlamGolden/Silly%20Smileys/writing1-smiley.gifTaking notes while making boats isn't easy.
Been busy……….
The ones that I have seen and really DO look good were done with resin parts…..(but those aren’t in 1/144 scale either…:-to…..that I know of).
This is probably the hardest part (in this scale) to make this somewhat convincing. I’ve been doing a lot of “thinking  it out” before beginning.
Grin.gif image by SVT-GT500
I think these are going to come out quite nice.
Haven’t seen anyone doing the jumping wires in this manner. Most all I’ve seen use bits of play-doh, drops of glue or even bread dough (http://th108.photobucket.com/albums/n16/MellaBellaJean/smileys/th_confused-18.gifyuck).
Now, how I laid out the forward & rear  jumping wires.
 It gets a more beady after this…….  liike 2mm.
The insulators might be a bit too big for this scale but 2mm were the smallest thing I could find…… But, (of course) after all this was finished I've found  ‘em in 1mm.
Careful measurements are required for all the following.
Forward layout…
    There is just barely enough  room for the functional snorkel to correctly engage the bridge connection.
    There are no useable/viewable attachment points on the bridge  for the jumping wires to securely connect to, so I made my own.
     You can connect them by making your own pintel connectors.
This picture should be self explanatory, it really isn’t difficult.
The smallest one on the left is made from tiny old mouse wires.
  All  the attachment points (cable wise) were made to allow the snorkel to dock with the bridge correctly.
Keep thinking ahead......http://www.anchoredbygrace.com/smileys/juggle.gif
 The part that divides the forward cable just before the bridge is a part I made (3 pieces).
A lot of research has gone into this.....http://www.millan.net/minimations/smileys/bokmal.gif
Additional features added below, except for the antenna wire that I’m going to redo.
The way I have this mounted allows me to just slightly raise the cables above the styrofoam base and install the insulators in the required position wth some pva. Brush on some future while the pva has dried.
   After the insulators have dried securely in place, add another brushing of future to keep them that way. This gives you a semi-rigid structure to work with.
        The rear  jumping wires are done in the same manner.
        It’s nowhere near finished yet…………..  37mm next.
          Remember……
                     "The learning is in the doing."
                                      http://th636.photobucket.com/albums/uu89/ZeeOO_01/smileys/th_31d977f9d3993363b99cc36332b31a34.gif
    I made all the tire chains on the M-20 armored car that you see below (at the bottom of this post) in the same manner as the cables were done.
GAF
    June 2012
Posted by GAF on Sunday, September 10, 2023 7:30 PM
Amazing detail work.  Your creativity shows.
Gary
    May 2020
Posted by Hutch6390 on Monday, September 11, 2023 12:07 PM
Great work here, DM, on a very small scale - I'm getting eye strain just from the photos!
    July 2003
Posted by disastermaster on Tuesday, September 12, 2023 6:54 PM
Hutch6390
disastermaster
Stayed tuned.
Don't pinch,
 grab it up and enjoy.
    July 2003
Posted by disastermaster on Friday, September 15, 2023 1:44 AM
GAF
Gary
 Thank you Gary.
        Working on the next episode.
    July 2003
Posted by disastermaster on Saturday, September 16, 2023 2:35 PM
Hutch6390
Thanks Hutch!
Stack on some readers 'cause things are gonn'a get even smaller.
Computer work animated emoticon
I'm currently working on a missing parts problem.
            ......'ya know what that means.
    July 2003
Posted by disastermaster on Sunday, September 17, 2023 2:48 PM
This is the 37mm gun as shown in the instructions.
Nothing complicated.
http://myphoto.eu/img/smiles_dark/smileySweating.gifBut, as it looks right now I’m going to have to break out the calipers and research some measurements from the internet.
At some point the partially prepped parts (including the small plastic box I put them in) was apparently devoured by a hideous carpet monster.
I’ve looked for hours employing every search trick I know.
How in the ‘ell did it swallow the 2” plastic box I put it all in?
I don’t want to buy another kit or do 3D printing just to get the gun either.
So, I guess there’ll be a lull here since I’m going to have to redo it all by hand.
I’ll have it up as soon as I can get it finished.
                         A short while from now…………..
fox
    January 2007
Posted by fox on Sunday, September 17, 2023 3:28 PM
You know when you're going to find it don't you?
Anyhow, just getting around to seeing your great work on this build. I'll be watching from here on. Yes Yes
Stay safe.
Jim Captain
 Main WIP:
   On the Bench:  1/48 Tamiya - Vought F4U-1A Corsair for Group Build 'Absent Friends' 50%    1/48 Encore Models - A-37B/OA-37B Dragonfly 50%
    July 2003
Posted by disastermaster on Thursday, September 21, 2023 12:41 AM
Hey Fox,
I get'cha on that.
Thank you for your interest and inclusion with this subject.
 This has only happened to me one time before, about 12 years ago. That part (thankfully a simple, one piece part) showed up about 3 years later..... in a far corner all the way across the living room where no one ever goes.
 I'm still working on the 37mm............http://myphoto.eu/img/smiles_dark/smileySweating.gif
    January 2010
Posted by CrashTestDummy on Thursday, September 21, 2023 3:09 PM
disastermaster
<SNIP>
                                                           What's next?
Logged you out?!?  Amazing!!  My old account 'disappeared' when I reset the email address on it, but after a few backs-and-forths with the admin team here, that all got straightened.  They told me to log out and back in and things should be fixed.  Luckily, the changes happened dynamically, as I have NEVER been able to log out, on purpose, or accidentally.  Indifferent
Nice work, though.  I have a couple of subs in my stash, mostly really wierd stuff, like the Hunley and Proteus, but I do appreciate WIPs of all types, since there's stuff to learn from almost each and every one.
Regards,
Gene Beaird,
Pearland, Texas
G. Beaird,
Pearland, Texas
GAF
    June 2012
Posted by GAF on Saturday, September 23, 2023 11:45 AM
How do you lose a 2 inch box?  Obviously sabotage! Surprise
But I'm sure the 37mm will look even better when you build the parts yourself.
Gary
    July 2003
Posted by disastermaster on Saturday, September 23, 2023 5:18 PM
CrashTestDummy
 disastermaster
<SNIP>
                                                           What's next?
Regards,
Gene Beaird,
Pearland, Texas
First time in  20+ years that THAT has ever happened to me.
Next time I went back and typed it onTextEdit first , https://forum.ultravnc.net/images/smilies/_icon_tomato.gifso it wouldn't happen again.
Stay close.
         You'll probably like what you see when this surfaces.
    March 2018
Posted by Luvspinball on Sunday, September 24, 2023 9:37 AM
If you lost the whole box, then chances are you did what I do.  You moved it to a "safe place" so it wouldn't get lost.  Now where that safe place is, is anyone's guess.  But I am betting it is quite safe.  Some day in the near future, you will wake up at 3:23am and dramatically remember where you put it.  Do not drift back to sleep, or you will immediately forget it again.
Been there, done that.
Great work by the way.
Bob
Bob Frysztak
Luvspinball
Current builds:  Revell 1/96 USS Constitution with extensive scratch building
    July 2003
Posted by disastermaster on Wednesday, September 27, 2023 12:29 AM
GAF
Gary
      Gary,
                   http://www.sherv.net/cm/emoticons/fighting/seeing-stars.gif
                   I still have NO idea. I'm still looking even though
                    I've almost got the 37mm finished.
                    Thank you for the positive comment.
                     Been out doing some target practice this week so that's
                      put me a bit behind.
                             It's coming very soon though.
fox
    January 2007
Posted by fox on Wednesday, September 27, 2023 6:06 PM
DM, just a thought. Do you have a trash can near the bench? I've dropped or accidently pushed stuff off the bench into mine quite a few times. Each time I had to dump it out and go thru it.
Stay safe.
Jim Captain
 Main WIP:
    July 2003
Posted by disastermaster on Thursday, September 28, 2023 12:18 PM
http://www.sherv.net/cm/emoticons/hello/little-cutie-says-hello-smiley-emoticon.gifLuvspinball
I'm always putting stuff in a safe place.
http://www.sherv.net/cm/emoticons/yes/ok-sign-smiley-emoticon.gif Good to know I'm not the only one here that does that.
In every instance I keep my safe place right on the counter within an area of about two feet right under my nosehttp://www.sherv.net/cm/emo/funny/1/nose-pick.giffrom what I'm working on.
My safe place is in clear plastic boxes right before my very eyes.
http://www.sherv.net/cm/emoticons/school/math-problem-smiley-emoticon.gifThis is only the second time this has ever happened to me. I never start another project until I finish the one I'm working on.
I think I'll take a nap now.....
                                 http://www.sherv.net/cm/emoticons/sleep/dreaming-1.gif maybe it'll come back to me.
