with
U Boat Jumping wires.
Taking notes while making boats isn't easy.
Been busy……….
The ones that I have seen and really DO look good were done with resin parts…..(but those aren’t in 1/144 scale either…
…..that I know of).
This is probably the hardest part (in this scale) to make this somewhat convincing. I’ve been doing a lot of “thinking
it out” before beginning.
I think these are going to come out quite nice.
Haven’t seen anyone doing the jumping wires in this manner. Most all I’ve seen use bits of play-doh, drops of glue or even bread dough (
yuck).
Now, how I laid out the forward & rear jumping wires.
It gets a more beady after this……. liike 2mm.
The insulators might be a bit too big for this scale but 2mm were the smallest thing I could find……
But, (of course) after all this was finished I've found ‘em in 1mm.
Careful measurements are required for all the following.
There is just barely enough
room for the functional snorkel to correctly engage the bridge connection.
There are no useable/viewable attachment points on the bridge
for the jumping wires to securely connect to, so I made my own.
You can connect them by making your own pintel connectors.
This picture should be self explanatory, it really isn’t difficult.
The smallest one on the left is made from tiny old mouse wires.
All the attachment points (cable wise) were made to allow the snorkel to dock with the bridge correctly.
Keep thinking ahead......
The part that divides the forward cable just before the bridge is a part I made
(3 pieces).
A lot of research has gone into this.....
Additional features added below, except for the antenna wire that I’m going to redo.
The way I have this mounted allows me to just slightly raise the cables above the styrofoam base and install the insulators in the required position wth some pva. Brush on some future while the pva has dried.
After the insulators have dried securely in place, add another brushing of future to keep them that way. This gives you a semi-rigid structure to work with.
The rear
jumping wires are done in the same manner.
It’s nowhere near finished yet………….. 37mm next.
Remember……
"The learning is in the doing."
I made all the tire chains on the M-20 armored car that you see below (at the bottom of this post) in the same manner as the cables were done. ⬇
