Academy 1/350 Graf Spee WIP-Completed 2/29, many pics
    July 2004
Posted by stikpusher on Sunday, May 9, 2010 6:55 PM
I started building this a couple weeks ago for the "Battle of the Atlantic" Group Build here. This is my second ship kit in almost 30 years, and my first "newly tooled" ship build as well. So anyways I thought i would share some pics of my work here in the Ship forum. I am usually an Aircraft and Armor builder, so this is certainly out of my comfort zone. Anyways, any and all helpful advice is welcome and encouraged. I am building this one straight OOB and the only mods I will make are to close improve overall fit/appearance.
So I started of course with the hull. The kit gives the option of full hull or waterline, I am going with the full hull option.
I only placed the main decks on for the photos. I also built the main turrets on the first weekend. The bases had a gap at the mounting lugs that was slightly visible, so I filled those with sheet plastic and putty then sand them smooth to fill the gaps. The kit comes with hollow molded bores for the main guns. A nice touch I thought. One other correction I made was sanding off a raised chevron on the front sloping upper plate of the turrets.
I also built the basic fore and aft superstructures and then placed them on the main deck for this photo as well as the torpedo mounts.
This weekend I began painting her. First I painted the black for the boot topping then let it dry overnight. the next day I masked off the lower edge of the boot topping and painted the hull red. I also painted the wood decks a wood yellow tan color. Today I masked off the upper edge of the boot topping and painted the hull gray.
During my brief times in the week I can work on her, I have been building the smaller assemblies.
Upper forward superstructure and range finders/ gun directors.
Secondary batteries and heavy/medium FLAK guns
Cranes and catapult
Then everything placed just to see how it is gonna look
As I said before any help hints, tips, advice will be greatly appreciated. Just keep in mind this will be OOB, no After Market items on this one. I am still working up to that.
Pirate
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
Posted by Tojo72 on Monday, May 10, 2010 3:50 PM
Looks good so far Stik,I'm an OOB guy myself,not too much advice,but I am looking foward to see it done.I got the Trumpeter version in my stash.
    July 2004
Posted by stikpusher on Monday, May 10, 2010 4:00 PM
I would be very interested in seeing your Trumpeter one built up. I am curious as to how they look side by side.
       - Plankton
LSM
Posted by Tojo72 on Monday, May 10, 2010 4:24 PM
Someday,It's in the stash,but no real plans to start it,but Iwill keep you in mind.
    March 2005
Posted by gpal on Thursday, May 20, 2010 12:11 PM
Looks good, keep us posted on the progress.
George
    December 2003
Posted by scottrc on Thursday, May 20, 2010 10:08 PM
I agree, looks good and thanks for posting.  Nice job.
Scott
    July 2004
Posted by stikpusher on Friday, May 21, 2010 3:12 AM
Thanks guys. Hopefully this weekend I will be able to make some more progress on her. I will post pics when I do.
       - Plankton
LSM
    March 2007
Posted by JMart on Friday, May 21, 2010 8:31 AM
really nice job so far!
if you want suggestions, here are a couple:
For ships, the one item of PE/AM that you may want to ebetually add to your ship builds are the rails. Sort of engine grills for armor, or seatbelts/buckles for A/c. Ships just look a lot better with rails, and plastic molds of rails are way off scale (thick).
Ships have so much "grey", it is hard to break up the color monotone of the build. Weathering won't help you there, since most (if not all) weather decks (no pun intended!) were always kept clean/painted, except for a few ships at the end of long trips. You may want to give the decks a light wash to bring up some of the details. You can drybrush some areas of the turrets (as an example), to simulate some sun fading. You can add some rust-weathering to the anchor region.
My apologies if this is all well known to you : )   I have both the Shipcraft and Osprey volumes on German pocket battleships, let me know if you need any specific info or pic scans. I am in the planning stages for building the other two of the class, maybe I should check out the BoA GB!
Look forward to the rest of your build, cheers!
    July 2004
Posted by stikpusher on Friday, May 21, 2010 8:15 PM
Thanks Jmart! I had considered a wash for added depth to the decks, but not the sun fading on the turrets. Good idea! As I said, any and all suggestions are welcome. I am all new to serious ship building and am taking it one step at a time here. I do plan on adding PE rails to other kits I Have in the stash, because I do see your point about the thick railings. I think the skid marking on deck plates nd planking it out of scale as well, but I am on baby steps here. My basic intent is to have her looking as she did on the morning before joining battle off the River Plate. At this point I am not overly pleased with the Deck Tan shade I have. Any suggestions for a "Teak" in the Testors, Humbrol, or Tamiya lines?
       - Plankton
LSM
    August 2005
Posted by Tracy White on Friday, May 21, 2010 10:07 PM
The skid markings are at best over scale, and at worst a fabrication.
Be careful with washes; I see a lot of guys slop it on and call it good; the true intent with a wash is to replicate the affect light has on real objects in a smaller scale.
Here's a technique for wood decks you might want to consider:
http://www.steelnavy.com/wood deck.htm
http://www.rollmodels.net/nworkbench/onlinebuild/arizona/arizona3.php
Tracy White Researcher@Large
    July 2004
Posted by stikpusher on Tuesday, November 2, 2010 8:57 PM
Thank you for the links. I will be coming up with something to try along those lines for the wood decking. I have been plugging away at this kit a little at a time.Today I removed all masking and touched up the wooden planks for an even base color. I also applied some dark gray to the appropriate areas on the forward superstructure.
After I took these pics, I finally glued down the main decks to the hull, but don't have any pics yet of that.
       - Plankton
LSM
Posted by Anonymous on Tuesday, November 2, 2010 9:09 PM
Cool...I disagree about not using washes on ships...I think the proper use of washes will make your decking more pleasing to the eye and break (and tone down) up some of the large swathes of grey...just be patient w/ them and don't try to do it all at once...Yes
    July 2004
Posted by stikpusher on Tuesday, November 2, 2010 9:26 PM
Thanks for the encouragement on the washes. I am gonna attempt some subdued washes on the decking. That  is really the only way to get some detail to stand out.
       - Plankton
LSM
    December 2006
Posted by Jester75 on Tuesday, February 1, 2011 4:52 PM
Any updates on this one stik??
Eric
    July 2004
Posted by stikpusher on Wednesday, February 2, 2011 12:38 PM
Eric, at the moment I have this build sidelined while I finish up some other builds that are near completion.
       - Plankton
LSM
Posted by Anonymous on Wednesday, February 2, 2011 1:58 PM
stikpusher
Sounds like you are part of my 229 GB...
    July 2004
Posted by stikpusher on Wednesday, February 2, 2011 3:14 PM
I will have to look and see if I qualify for that oneWink
       - Plankton
LSM
    July 2004
Posted by stikpusher on Sunday, April 3, 2011 4:05 PM
Graf Spee has been moved to the front of my build batting order now that I have completed most of those "near complete" builds from last year.  After watching one of the ship experten WIPs on the Trumpeter Zerstorer I formed some ideas as to how to proceed with building and finishing this beauty. Sub assemblies of building, painting and washes before being attached to the larger compnonents...Idea
So here are some components such as the bridge area partially painted
the stack....
And forward area of the superstructure
 I made some mods to the Arado float plane. I hollowed out the area of the float supports as that had been molded solid...No Also the raised detail lines were way too heavy so I used those a a guide, scribed in new ones, and sanded off the raised ones. I still need to attach the cowl.
and a teaser shot of all sub assemblies placed on the hull. This makes me want to finish her up...
       - Plankton
LSM
    September 2003
Posted by mstazz62 on Monday, April 4, 2011 3:21 PM
Stikpusher - Your pics on the first post won't open for me for some reason - dang technology! But your second set of pics did open, and they look great! Can you repost some more pics? She's lookin' good and I'm waiting to see more. I personally like washes on ships to bring out the detail - in fact I think that ships, being in smaller scales than say aircraft or armor, benefit from heavier washes to highlight all the detail. I think it's referred to as scale viewing distance? Not sure, but I notice that close up pics of my ships do look a little "dirty" from the wash - but looking at them in real life in my display case you can really see the smallest details quite clearly.
I realize that it's really personal preference and I have to admit that after several modelers commented on my washes were too heavy (they were right) I lightened up things a bit and I am happy with the results.
Anyway, more pics please!
Mark
mstazz62
Posted by Anonymous on Monday, April 4, 2011 3:27 PM
I love your Graf Spee and want to scuttle him...
    July 2004
Posted by stikpusher on Monday, April 4, 2011 3:49 PM
NO SCUTTLING!!! At least until we get a plastic RN Cruiser...Whistling
I will repost the original pics on the early WIP on my days off this week. (Tomorrow thru Thursday) I rearranged my Photobucket account and it killed all the old links when I did...
       - Plankton
LSM
Posted by Tojo72 on Monday, April 4, 2011 5:13 PM
Looking good Stik.......nice progress.
    January 2007
Posted by Pavlvs on Tuesday, April 5, 2011 3:28 PM
Rescribing panel lines on a 1/350 plane?! Now that's impressive!!!Bow DownWow  Will the Captain have blue eyes?
Deus in minutiae est. Fr. Pavlvs
On the Bench: 1:200 Titanic; 1:16 CSA Parrott rifle and Limber
On Deck: 1/200 Arizona.
Recently Completed: 1/72 Gato (as USS Silversides)
    July 2004
Posted by stikpusher on Tuesday, April 5, 2011 4:36 PM
No... Manny had the Captain shoot himself after scuttling...Whistling
       - Plankton
LSM
    July 2004
Posted by stikpusher on Tuesday, April 5, 2011 5:37 PM
Today's update on the Graf... first off I fixed the first page's pics  as requested.
As for actual work I applied a "tint" of heavily thinned Tamiya Deck Tan to the wood decking areas. Not thinned as much as a wash but not opaque like standard paint coat. Just enough to tone down and gray out a bit the Testors Deck Tan I used orginally. Tomorrow after this has dried well I will apply a wash of Raw Umber to make it "pop". The original Testors color was just too bright and vivid in my eye for weathered wood decking.
In hindsight, after working with the MM Acryl Marine Colors (with their horrible adhesion properties) I should have approached this in a slightly different manner. 1st prime the plastic (Humbrol enamel is my prefferred), 2nd apply the MM base colors, 3rd apply the tints and washes, 4th glue the decks down... live and learn for the next one.Hmm
Anyways here is the original hull decking color
and after the "tint" coat
And here are the superstractures before...
and after "tint"
       - Plankton
LSM
    March 2007
Posted by JMart on Tuesday, April 5, 2011 6:01 PM
Stik - nice to see this one back at the bench. Look forward to the rest!  Beer
Posted by Anonymous on Tuesday, April 5, 2011 6:19 PM
...cool...
    July 2004
Posted by stikpusher on Tuesday, April 5, 2011 8:25 PM
Oh yes, I added the cowl to the Arado yesterday. I am debating what to do about the canopy for finishing. Paint to represent a clear canopy, paint to represent a tarp over it, or use clear sprue to screatch build a clear canopy... Hmm
       - Plankton
LSM
Posted by Anonymous on Wednesday, April 6, 2011 9:48 AM
Paint the canopy gloss black or very dark gloss blue and be done with it---in that scale it will look fine...
    July 2004
Posted by stikpusher on Wednesday, April 6, 2011 7:58 PM
That sounds reasonable....
Today's progress: A wash of Raw Umber to all wood decking areas. The wash worked great and looks better to my eyes than it does in these pics.  The overall effect is a weathered wood now...
the hull
Hull with superstructures in place
close ups of the fore and aft supperstructures
and a close up of the fantail for a better look at the effect achieved
After the wash dried madesome touch ups of the Hellgraucamo basecolor on small parts that needed it , painted the 20mm guns on the stack platform, and began the camo painting...
Stack
aft rangefinder
gun directors
catapult
forward rangefinder
and after twin 105mm AA mount
       - Plankton
LSM
