GMorrisson - the way you did your lights looks pretty easy. Is your battery pack simply wired to the copper tape? With no diodes? I did not want to use a battery system on mine and, an article I looked at was telling me I would need to add diodes to change voltage depending on the number of lights, volts, amps etc. Over my head! So I went with a LED ribbon kit from HiLights that included a power outlet and dimmer switch. blackened out most of the lights so they wouldn't saturate the hull with light by covering most of lights with black acrylic paint. I now have to decide if I will bring the ribbon up through the bow or stern of gun deck to attach to underside of the spar deck.
Thank you for letting me know about the locator lugs on hull. I couldn't figure out what they were for. I'll get rid of them. As for the weathering powders, I'll go along with your advice to stop where I am. I just wanted to dull down the brilliance of the copper paint. I have no plans for doing any weathering on the rest of ship. Thanks for following this post and taking the time to give me your opinion I'm very grateful to these forums for the assistance and help they provide to other modelers. Cheers!
