Hi Dale, I answered this a day or 2 ago & I probably forgot to hit send or as it does , I hit it & it doesn't go. I have the masts all glued in at -8% & have the rr-standing rigging main lines in but not fastened. One big problem with the Alabama over the kearsarge is the blocks to tie your shrouds to are way to small. I have added extra tie down s on the channels but the blocks are too small to drill a hole in. I do have it worked out tho
I am working the miz mast first to be able to tie back to. I will glue the line to the entire block & rope castings. I figured it out this morning. I have also made all the shrouds & ratlines . I made them to fit the castings on the ship. The kit shrouds do not line up & are too small.
Definetly buy the Cottage cannons as they are nice. I got mine shipped for $33.75. That is the cheapest I saw. The deck is nice & I have used them before, but $100 or $120 s an awful lot. I have another Alabama coming & I could get the deck for that. My panted deck does look good. Gotta go build now.
By the way I have a lot of new rigging ideas if you are interested. I leave one end loose but taped to get the masts straight & raked if needed . I do the same thing with the mast brace lines too.When you have them right I put on the shrouds to fix them tight. I will tell you more when i see you.
