Building a brig / corvette wood model ship from scratch
Posted by CapnMac82 on Sunday, August 26, 2018 8:05 PM
Bals has a long (logn, long) tradition for modeling the bodies of ships.
Botanically, it is a hard wood, but physically (materials science-wise), quite soft.
It is, as our esteemed GMorrison points out, a wretched mess to sand or finish.
Back in the ancient old days, hobby shops used to stock "flying" balso, which was heartwood and a bit stiffer than "ordinary" (sapwood) balso.  Some flying balsa was hard to tell from basswood.  My old test was pretty simple, take a single edge razor blade (or a #11 xacto, in a pinch) hold it about 45º and drag the edge (reverse direction to cutting) along a test bit of the material.  Basswood should show a bit of a sheen, with no surface compression.  Balso will show far less sheen, but will compress a great deal.
Basswood has much to recommend it.  Not least of which being able to get it already cut in a number of thicknesses.  So that, had a person, say, bulked out a hull shape in balso, one could plank in wales ata scale thibkness in basswood, and then use a hull thickness bass wood for the "show" planking.
One need not get quite to C. Nepan Longridge's zeal for planking to find it an enjoyable business.
    August 2018
Posted by Jamie Dominie on Sunday, August 26, 2018 8:20 PM
I've actually had a few problems with wood as I've had to change all of my wood so far but I believe I'm set now
Intermediate builder from the lakes of Canada
    August 2018
Posted by Jamie Dominie on Sunday, August 26, 2018 8:29 PM
So today I decided to do some much redesign to my ship as the wood I used for the bulkheads turned out to be very weak and I've decided to switch to plywood for the bulkheads which I should've used from the start but scratch building is trial and error and that's one of the best parts. So here's the new look for the ship
I've decided to do a victory style flat bow at the bow deck rather than one like the constitution which curves with the bow. I've also curved the bulkheads more to create a more smooth transition between the three main decks as well as adding some carvings and finally figured out how my mast should look. I'll be in a design faze until Friday when I'm hoping to get some plywood and put the bulkheads together.
    December 2006
Posted by crackers on Sunday, August 26, 2018 11:03 PM
If you are going to have human figures with your model, this chart might be of some help, even if it is not for metrics. As far as the kind of wood, use lime wood. This wood is soft and best of all, has no knots. It is clear with out any blemishes. I do not know if there is a Michaels, hobby store near where you live. They always have a supply of lime wood for wood carvers.    Your post is very interesting as a scratch builder ship modeler myself. I will follow each thread of yours.
Happy modeling    Crackers    Smile
Anthony V. Santos
    August 2018
Posted by Jamie Dominie on Sunday, August 26, 2018 11:25 PM
Thanks crackers for the support as always. Line wood sounds like a good choice for some of the parts I will need to build. if I use plywood it will only be for the bulkheads only which will be mostly hidden.
    December 2006
Posted by crackers on Sunday, August 26, 2018 11:25 PM
  Jamie, if possible get yourself a 1/50 ruler and a pair of dividers to accurately make the correct proportions on you model.   Happy modeling   Crackers  Big Smile
Anthony V. Santos
    September 2012
Posted by GMorrison on Monday, August 27, 2018 1:26 AM
Plywood of a quality and size (small, lots of laminations) for what you are doing, is expensive. I'm a firm believer in repurposing things you'll find about. So is Anthony.
Judging from that wonderful band saw, you are up to good woodworking. There's a material, used to make boxes, easy to find in the fruit market. Or shingles.
I recall, Cap'n, that hardwood is a tree that blooms flowers, and softwood is a tree that polinates with cones. Angiosperms versus gymnosperms, or some such. Decidous versus evergreen.
That said, out west here the dominant softwood lumber tree is a devil known as "Douglas Fir". Hard as a rock, prone to curl, makes screws squeal, dulls saw blades.
Our best hardwood is all of the oaks, they being a Mediterranian species. Lovely wood, but not suitable for building models.
No pine is available at all, which is not a problem. A weed of a wood.
Where I live we have a rare Cypress. It will throw pitch from its lumber for decades.
I have a nice little table saw that can make fine wood strips. It's a rum thing though, getting 256 strips each 1/16" square ( 1.5 mm to you Jamie) from a 25mm x 25 mm block takes 4000 cuts plus more for loss. A cut, set-up, takes 2 minutes. Do the math but it is a slow process.
I suggest you draw the hull only until you get her right. No use in thinking about the rig in the sense of any detail.
    August 2018
Posted by Jamie Dominie on Thursday, August 30, 2018 6:48 PM
it's been a few busy days but I've finally come around to doing a bit of design work on the ship hopefully I'll have wood to start Tommorow but all that depends on the day anyways so I decided to come up with a basic deck plan drawn from above
Alot is going to change with this but it gives me a basic idea of the deck layout
I also did some design to the front though it's not set in stone
So hopefully i'll get wood Tomorrow and get my frames at least cut but I might with some luck get them assembled to. Asides from this I'm buying some parts I need tonight to and hopefully they will be here soon aswell.
Posted by Don Stauffer on Friday, August 31, 2018 8:53 AM
Jamie Dominie
When I bought it I was told it was bass wood but it could be balsa of so I'll have to head into town to buy new planks which shouldn't hurt consideing I got the bundle for around 10$
I concur on the recommendation to use basswood.  It bends more reliably- balsa sometimes has weak spots that break.  But the real reason to use basswood is its tight grain that fills and finishes easily.  Getting a good finish on balsa is a real challenge.
    August 2018
Posted by Jamie Dominie on Friday, August 31, 2018 9:04 AM
I also very familiar working with it as I used it on my last model
Posted by CapnMac82 on Saturday, September 1, 2018 1:36 PM
I have a cousin in practice up in Oregon, and all their framing lumber is typically specified as Doug Fir, much as, down here in Texas our lumber is specified using Southern Yellow Pine.
In point of fact, they are using a goodly amount of Hemlock, much as we are seeing rather a lot of Loblolly and Sugar Pine--as long as the material tests out on the SYP (or DF for my cousin) tables, it scant matters (other than to the poor souls on the saws).
It often amazes me to read modeling articles from the early 60s which speak of carving things from clear white pine.  But, that's becasue the "white pine" I'm used to has about 5 grain lines in a 6/4 (40mm) thick slice.
The best modeling woods have a very fine, even, knot-free grain, and, hopefully not so rare as hen's teeth.  In my 1:1 boat building, I have come into balks of Apple, which is really neat stuff--not long, but very fine grained.  Excellent for carving.  I really should have saved some for modeling.  Grape was also nice, just ridiculous hard to find.  Ipé would be a decent modeling wood, other than for the reason it's called Brazillian Ironwood (hard as steel, doubly so at scale).  Ditto for Goncalvo alves and Cocobolo; both gorgeous furniture woods that require all-carbide tooling to work.
The only "hobby shop" wood I really dislike is the "flying" spruce plywood.  Probably good for flying RC models, but the 3 or 5 ply stuff is awful for ship work.
    December 2006
Posted by crackers on Saturday, September 1, 2018 2:49 PM
The traditional wood in the construction of admiralty models, such as seen at the National Maritime Museum at Greenwich, England, is boxwood, a small tree or bush, (Buxus sempervirens ), a native of Western and Southern Europe. It is hard, heavy and fine grained without blemishes, or knots. Box wood carves well, holds a sharp edge and bends without splintering. Other varities of boxwood are native to Asia, Africa and the Caribbean, but the European variety has been the all time favorite for serious ship modelers. The one drawback of true boxwood, is that it is very expensive to purchase, unless one has deep pockets to afford this type of wood.
Happy modeling    Crackers   Surprise
Anthony V. Santos
Posted by CapnMac82 on Monday, September 3, 2018 4:59 PM
Oh, unless you have a lot of spare hours for a serious time-suck, do not look up "Acorn to Arabella" on youtube.  Rather a lot of 1:1 ship & boat wright work shown, but, at about 30-something episoded, not a speedy trip trhough a build (which is only to keel, stempost and sternpost so far.  Cool story, fascinating dedication, but not brief.
    September 2012
Posted by GMorrison on Tuesday, September 4, 2018 4:55 PM
If you are interested, I could recommend a couple of publications that I have found helpful. I've never taken on anything as complicated as you are doing, so consider these a reflection of my own level of modeling.
https://www.micromark.com/Instructions/88052-model-shipways-syren-instructions.pdf
https://modelexpo-online.com/The-Neophyte-Shipmodelers-Jackstay
I have not built the Syren, however anything from Chuck Passaro is worth reading. I have the Phantom Pilot Boat instructions.
    August 2018
Posted by Jamie Dominie on Tuesday, September 4, 2018 5:09 PM
Thanks GMorrison
