Trumpeter 1/350 U.S.S. Texas BB-35
    January 2015
Posted by Aggieman on Thursday, April 18, 2019 4:51 PM
Today I wrapped up a near-4-month long build of the old battleship, U.S.S. Texas.  I am a native Houstonian, which of course is where the Texas is berthed at San Jacinto, and have toured her many times.  I've always wanted to build her, but up until this kit was released in 2015, I think the only kit I'd ever seen was a resin offering that was way beyond my abilities at the time I saw it around the year 2000.
When this was released, I grabbed it.  It has been tucked deep in the stash ever since. This year I decided I was going to build a wider variety of subjects rather than simply Allied or Axis warbirds (to which I will be returning later this year).  After the Wright Flier, I turned my attention to the Texas.
For a mostly airplane builder, this kit was daunting.  I'd only ever built one ship before, the original U.S.S. Lexington.  I didn't feel as if I'd done a very good job on her.  That build was taxing to my patience and my nerves, and I think that played a role in my reluctance to tackle Texas.
The kit comes with 4 PE frets containing a lot of railing, 2 OS2U Kingfisher float planes (but decals for only 1), and a bunch of tiny parts that my eyes don't like without the Optivisor.
Currently the Texas is painted in a very monochromatic dark gray.  I knew I didn't want to go with such a simple paint scheme (although that would have made life easier).  I had bought the Squadron Signals book on the Texas, and found reference to the various paint schemes Texas wore throughout her WWII service (measures).  I liked the tonal variation of the Measure 22 scheme, so that's how I decided to paint her.
I honestly don't know if the kit is accurate for the time frame that Texas wore the Measure 22 scheme; some of the photos from late 1942 into 1943 show some differences between the kit and the actual ship.  I decided the kit would have to do; I'm sure there are some folks far better acquainted with US Naval subjects such as the Texas than am I, so if I missed something, consider it my mistake.
The majority of the paints I used for this build are new to me - LifeColor and ColourCoats.  The LifeColor paints are for the Measure 22 scheme - Navy Blue 5N for vertical surfaces above the waterline (or however the black stripe is referred to), Haze Gray 5H for all vertical surfaces at the main deck and above, and Deck Blue 20-B for all horizontal surfaces.  The ColorCoat paint is Norfolk 65A Anti-fouling Red for the area below the water.  I used some Vallejo USN colors for the Kingfisher, Model Master brass for the screws, and Tamiya semi-gloss black for a small number of details.  I weathered with Mig brown wash and a tiny bit of Tamiya weathering compounds, mostly rust.
I found the ColorCoat paints to be difficult to work with through my airbrush.  It is quite likely because I didn't thin the paint properly, but I was able to get the Navy Blue painted with the airbrush, as well as the Deck Blue on the main deck pieces.  I also did the anti-fouling red with the airbrush.  Everything else I painted by hand with a 10/0 brush, an Optivisor and a lot of patience.
This kit includes a lot of PE, which in aircraft I typically do not enjoy working with.  I think my dislike of PE has a lot to do with my aversion to using CA.  I've had too many fingers get stuck together, and even had CA "run away" from accelerator and onto the exterior of an EA-6 Prowler I did a few years ago.  To this end I found Gator Grip Thin Blend, which was said to work great with PE.  I'll verify that claim.  This glue looks a lot like white glue, or Elmer's glue.  Just a little dab on the tip of a toothpick, making glue placement relatively simple, followed by carefully aligning the parts from tweezer to kit, and then let it dry for a few minutes, which would usually be long enough to keep the parts in place.  I'd typically glue on a few pieces of railing  and leave it for the night, just to ensure a good bond.  The Gator's Grip also works great with EZ Line for rigging, as I later discovered.
I didn't like the look of the display stand (which is the same style Trumpeter used for the Lexington).  I opted to purchase a couple of rustic-looking drawer pulls to give the Texas a more polished look.
The kit was pretty good per my very limited experience building ships.  Not many fit issues (the only one I really recall was the lower hull pieces required some extra effort to close up properly, and I reinforced that join from inside with pieces of strip styrene.) I actually came up short on deflector plates for some of the deck guns - Trumpeter provided 44 to go with 45 guns, although you were only to use 42 of them.  Don't know if the carpet monster got some of the parts ...
Any way, this is my Texas.  I'm pleased with how she turned out.  And for now, I'm taking a break from the bench, but am eyeing a Fine Molds Star Wars kit as well as a lighted version of the C-57D Space Cruiser from the movie Forbidden Planet.
    April 2016
Posted by GlennH on Thursday, April 18, 2019 5:05 PM
Dang that thing is just bristling with firepower!
A number Army Viet Nam scans from hundreds yet to be done:
https://www.flickr.com/photos/southwestdreams/albums/72157621855914355
Have had the great fortune to be on every side of the howitzers.
    July 2013
Posted by steve5 on Thursday, April 18, 2019 6:06 PM
lovely , lovely work .
Posted by Tojo72 on Thursday, April 18, 2019 6:52 PM
A truly great job,lots of detail,very daunting.Ship builds can go on for quite a while,I would sometimes break it up with a quick change of pace build so I wouldn’t go stale.
    December 2015
Posted by templar1099 on Friday, April 19, 2019 7:12 AM
A really nice boat,you've done it justice.
"le plaisir delicieux et toujours nouveau d'une occupation inutile"
Posted by Don Stauffer on Friday, April 19, 2019 8:56 AM
Beautiful!  Really like the weathering and rigging.
    April 2019
Posted by skir4d on Friday, April 19, 2019 10:25 AM
Looks good, a nice job considering the scale, and it looks good in the Measure 22.
Did you get the light kit for the C-57D? That one is in my stash also, but I've got a CVN, DDG, and CA to do first.
Jack
    January 2015
Posted by Aggieman on Friday, April 19, 2019 1:33 PM
The C-57D kit that I have included the light kit.
Posted by CapnMac82 on Friday, April 19, 2019 1:59 PM
There's plenty for rivet counters to chew upon with this kit.(Bilge keels, over stated hull plating, finicky details of radar and platform fit.)  Skipping over that can help immeasurably.
There are details that would confuse "lay" viewers no end.
Like how the port shaft was a gunmetal sort of color, but the starboard shaft was in hull red.  Or that the screws were an olive sort of bronze (think 50/50 of XF-65 and gold).
And, about half the 20mm ought to have a dark gray wash on just the barrels.  The 'wet' location ones would be under a tarp 80% of the time, and would not be painted; the 'dry' ones were, but, when they were pulled out of the mounts for detail cleaning/maintenance, they'd go back in different locations than where they started.
The 3" and 5" gun barrels ought to have their top halves in Deck Blue.
For that matter, the Signalmen's platforms, a couple of the sky lookout locations, and the Flag bridge had russet linoleum on their decks for better skid resistance.
All of those things would be true to the original, but would confuse those who did not know any better (they just might think you daft, or under skilled.)  So, more power to you for the build.
One thing, the photos may have a skewed perspective, so that may be what I'm seeing.  Measure 22 had an perfectly horizontal top line, the height of which is struck from the top of the boot topping (the black stripe) to the lowest portion of the Main (100) Deck.  That height above the boot topping was held for the entire rest of the hull.  Which leaves a teeny sliver of upper works paint for most of the midships area.  Again, this is a point that might be lost on many viewers, and may be entirely accurate on your build.
Posted by Tojo72 on Friday, April 19, 2019 2:11 PM
Well,it looks like a well done battleship in spite of these "inaccuracies " Again,great looking project.
    March 2009
Posted by surfsup on Monday, April 22, 2019 2:13 AM
That is one beautiful build you have done. Very impressive work.....Cheers mark
If i was your wife, i'd poison your tea! If Iwas your husband, I would drink it! WINSTON CHURCHILL
    September 2005
Posted by freem on Wednesday, April 24, 2019 10:44 PM
Friggin impressive is what that is!!! Well done!
Chris Christenson
    July 2003
Posted by ridleusmc on Thursday, April 25, 2019 3:20 AM
Incredibly well done job on an increadibly beautiful ship.  I enjoyed my visit to the Texas.  That was about 13 years ago, but you've captured the spirit of that ship.
    May 2013
Posted by hogfanfs on Thursday, April 25, 2019 6:57 AM
Wow! Aggieman, she turned out great!
 Bruce
 On the bench:  1/48 Eduard MiG-21MF
                        1/35 Takom Merkava Mk.I
    December 2003
Posted by scottrc on Thursday, April 25, 2019 7:47 AM
Good work Aggie.
    September 2003
Posted by checkmateking02 on Thursday, April 25, 2019 2:40 PM
That looks really great!
    December 2018
Posted by Ted4321 on Thursday, April 25, 2019 5:41 PM
Nice job on your ship.
When you get your star wars model, join the star wars group build.
T e d
