warshipguy As for paper card modeling, it seems to be very similar to wooden plank-on-bulkhead building (at least in the photos you once sent to me!)
Bill, yes, it is.
And You will see, thats is very easy.
Marius
Somewhat similiar in the fact that you have to build a frame to attach the hull pieces to, be it a full hull or waterline model.Most or the paper ships I built were waterline. The important thing to remember is to be very careful and trial fit the pieces before you do any glueing, cuz once the parts are set, its difficult to remove them. Also, you`ll need some felt tip markers to color the white edges on th parts once you cut them out. If you are careful to build the hull and deck, the rest of the model isn`t tool hard to finish, It takes timepand patienc, patience, and more patience.Good luck!
If someone interested, here is the link of building Shipyard's paper-card model of HMS Alert on Lithuanian forum:
http://www.kvaksiuk.com/forum-lt/viewtopic.php?f=6&t=467
