New Build: Lindberg Jolly Roger *Finished 7-7*
    May 2003
Posted by jtilley on Tuesday, July 1, 2008 11:17 PM
Many thanks, warshipguy.
It's what might be called "semi-scratchbuilt."  The hull was built on the "bread and butter" system from laminations of basswood, with a plywood "keel plate."  The hull planking is styrene strip.  (That's a somewhat unusual method of hull construction that I used largely because I wanted to see if it would work.  I'm generally satisfied with it, but I'm not sure I'd recommend it to anybody else.) The decks are planked with 1/16" x 1/32" basswood.  (I got access to some nice holly while I was working on this model; if I'd had it earlier I would have used it for the decks.  I did use holly for the planking of the tops, and for the hulls of the boats.)  The masts and yards are turned from degama wood; the gun barrels are turned brass and sit on styrene carriages with brass wheels.
The manufactured parts are the Bluejacket britannia metal blocks and deadeyes (I have the means to make such things, but I figured six years on one model were enough) and the crew figures, which came from various plastic kits. (Some of them were subjected to rather brutal modification.  The Continental Marine on the forecastle started out as the guy with the helmet and breastplate in the old Revell Santa Maria, and the one on the spritsail yard footrope is the captain of the old Revell tugboat Long Beach, with a new hat.  Captains Cook, from the Airfix Endeavour, and Bligh, from the Revell Bounty, are standing on the quarterdeck, disguised in Continental Navy uniforms.)  The figurehead started life as a Preiser HO railroad figure.  (The real figurehead was larger than life-size; by pure coincidence putting the model on 3/32" scale made the HO figure right for the figurehead.  He got a new hat, jacket, and legs from styrene stock.)  All the other "carved" detail on the bow and stern was made from Milliput epoxy putty.  Most of the rigging is silk thread, made up on a crude "rope-making machine" that I put together from parts in a Lego set.  The exceptions are the ratlines, which are nickel-chromium wire.
In the unlikely event that anybody's interested, the British quarterly Model Shipwright published a series of four articles about this model, with some in-progress photos (the negatives of which have long since disappeared) back in 1983-84 (issues 45-48).  I think those articles may have been reprinted in one of the magazine's bound anthology volumes, but I'm not sure about that.
The photos on the website that I linked in the above post were taken a couple of years ago.  I'm pleased to say that the model has held up quite well during the 24 years since I finished it (and, for that matter, the 30 years since I started it).  It, along with several other models from our ship model club, is currently on display at the visitor center alongside the U.S.S. North Carolina, in Wilmington.
    September 2005
Posted by warshipguy on Wednesday, July 2, 2008 9:24 AM
jtilley,
And, the answer is . . . "d. All of the above".  Thank you for your detailed answer! I will look into that article.  Perhaps we could recommend some of the Revolutionary War ships to Revell of USA for future projects.  Ships of that period are exceptionally beautiful to me and are all too underrepresented as modeling subjects.  Thanks again!  You do beautiful work.
Bill Morrison
    August 2005
Posted by sumpter250 on Wednesday, July 2, 2008 11:19 AM
I've given some thought to using styrene strips for hull planks, on a keel and bulkhead/egg carton form. Would you be willing to post the benefits, and disadvantages to this method of hull construction? Where most of the sailing ship models here are styrene, it might be beneficial for all to hear about this process, especially where it might aid modifying a kit hull. Yes, it is a somewhat unusual method, but it just might be a technique that can be developed into something very useful. ( If you've already done this.....please post a link to the page. )
Lead me not into temptation ..................I can find it myself
    May 2003
Posted by jtilley on Wednesday, July 2, 2008 11:59 AM
Ok.  The big advantages to styrene as a planking material are that it's flexible and it doesn't have any grain, so it's easy to trim to any required shape.  The big disadvantage is that it doesn't have any grain, so it doesn't look like wood unless it's given some sort of treatment in the way of paint, texturing, etc.  That makes it appropriate for planks (e.g., exterior hull planking) that are going to be painted, but less so for unpainted decks.
I worked from a copy of the plans by Howard I. Chapelle, which I bought from the Smithsonian.  I checked them frequently against copies of the original Admiralty drawings; Chapelle was a great man, but he's somewhat infamous for his habit of making changes, some justifiable and some not, when he redrew old plans.  But he saved me the trouble of "fairing up" the lines in the Admiralty drawings. (They were made on linen, and stored in rolls for almost two hundred years; those old plans invariably have stretched and/or shrunk.)
I started out by carving the basic hull shape, up to the level of the maindeck, out of laminations of basswood - in two halves, to fit the plywood "keel plate."  (I cut the latter out of birch plywood with a scroll saw.  It runs up to the level of the underside of the maindeck at the centerline, with notches cut in the top for the deck beams.  Amidships the keel plate is cut down to the level of the berthdeck, which I wanted to be visible through the hatches in the waist.)  I hollowed out the two halves of the hull to a thickness of about 3/16", then secured them to the keel plate.  I built up the bulwarks above the maindeck with basswood strips - the first one being the height of the gunport sills.
I then laid in a stock of Evergreen strip styrene (which, if I remember correctly, had recently come on the market) in the appropriate dimensions.  (I'd have to measure to see just what those dimensions were; I think the thickness of the "common plank" was .010," but I'm not sure.  The wales, of course, are thicker.)  The adhesive was old-fashioned Revell "Type-S" styrene cement in a tube.  I wish that stuff was still on the market; I continue to think that tube glue has its uses.  In this case it worked quite satisfactorily, softening up the surface of the styrene and soaking into the basswood.  (Basswood is far from the best wood for many ship modeling purposes, but it's great for things that have to be glued.)  I worked alternately from the wale down and the keel up.  I was surprised at how little tapering was needed on the planks between them to get the planking lines to run fair on this particular ship.  I expected to need a couple of "stealers" at the stern, but they were in fact unnecessary.
The flexibility of the plastic, and the speed with which the glue dried, were such that no preparation of the planks was necessary and they didn't need to be clamped - even on the sharp curves around the bow.  Just holding them in place with finger pressure for a minute or so was enough.  I finished up with a little judicious sanding and scraping of the plank edges, but not too much; I wanted the edges of the planks to be faintly visible through the paint.  I covered the visible parts of the keel plate - the keel itself, the sterpost, the stem, and the knee of the head - with styrene sheet.
That styrene has now been held to the basswood hull by the Revell cement for just about thirty years, and, contrary to what some of my traditionalist friends predicted, shows no sign of coming loose.
There are several decorative moldings, with rather delicate T-shaped cross-sections, above the gunports.  I ground a female version of the cross-section in an old X-acto blade.  The height of the molding worked out to .040" (if I remember right), so I clamped a sheet of .040" styrene in a vise and scraped the profile on the edge of it.  Then I sliced off a strip of the right thickness and cemented it to the hull.
The last step in the planking process was to plank the insides of the bulwarks.  That was easy.
Styrene sheet really came into its own in the construction of the headrail assembly, the quarter galleries, and the transom.  That's another story, though, and this post has gone on more than long enough.
If I were building the model again (gawd forbid) I'm not sure whether I'd use this method of planking or not.  Since then I've acquired a good stock of nice holly veneer, which I really like; I suspect it would be just about as easy to work with as styrene in this context.  I do think, though, that if I were building another model with one of those complicated, basket-shaped headrail assemblies I'd use styrene for that part again.
Hope that helps a little.
    August 2005
Posted by sumpter250 on Friday, July 4, 2008 2:20 PM
 Thank You Professor!
I have come to appreciate the positives of styrene strip, and sheet, in the model railroading, and modern ship model construction, and had thought of using styrene strip for sailing ship planking. Your "Hancock" shows the validity of its use. Your use of the old revell "type S", reminded me of using the current "user safe" tube glue to attach a plastic building to a basswood foundation. Applying the glue to the wood, and "working it into" the wood grain, and letting it dry, then, a second coat on the dry, and a light coat on the plastic formed a reasonalby good bond. For this use, however I have found that silicone adhesives work better, although taking much longer to set up, and harder to control.
    February 2008
New Build: Lindberg Jolly Roger *finished 7-7*
Posted by enemeink on Monday, July 7, 2008 11:16 AM
Finished! Funny how not hand tying rat lines can cut build time down to almost half. Of course when I start the Royal louis I hope to have that one done by christmas.... There's nothing too fancy with the rigging. I just used the same gold chain that I used on the Wasa to do some of the rigging instead of using the thick plastic ones that came with the kit. I decided to leave the sailors off and use them on another build maybe the HMS bounty or the La Flore. I haven't decided yet. anyway if anybody has any questions please ask away......
thanks for looking.
"The race for quality has no finish line, so technically it's more like a death march."
    May 2007
Posted by RTimmer on Monday, July 7, 2008 11:21 AM
Hi "Enemienk",
Awesome!  I have really enjoyed your build progress and pictures - thanks very much for sharing. I can't remember if you mentioned earlier in the thread, but where did you pick this kit up from?
Keep 'em coming - looking forward to your Bounty or La Flore!
Cheers, Rick
    August 2005
Posted by sumpter250 on Monday, July 7, 2008 12:00 PM
Not to mention the time needed to mount the lower deadeyes, with chainplates, and rig shrouds. I'm still in that process.
  Very nice model indeed!, looking forward to your next project.
    February 2008
Posted by enemeink on Monday, July 7, 2008 12:17 PM
 RTimmer wrote:
Hi "Enemienk",
Cheers, Rick
Thanks Rick!
I bought two of these at my LHS in the discount bin for about $9.00 a piece. It seems like every month his dicount bin has a themed clearance sale. Right now it's old airliners.
    February 2008
Posted by enemeink on Monday, July 7, 2008 12:20 PM
thanks sumpter,
I'll be doing this on the Royal louis. I've just ordered some 2.5mm deadeyes and blocks for this so it's be awhile before that one is done. I might have to do some in between builds to keep my mind from going crazy....
    June 2006
Posted by Grem56 on Monday, July 7, 2008 1:03 PM
 A nice build. The ship looks like it has seen quite a bit of action Pirate [oX)]
Cheers, Julian
illegal immigrants have always been a problem in the United States. Ask any Indian.....................
Italeri S-100: http://cs.finescale.com/FSMCS/forums/t/112607.aspx?PageIndex=1
Isu-152: http://cs.finescale.com/FSMCS/forums/t/116521.aspx?PageIndex=1
    December 2009
Posted by kazubb on Friday, April 2, 2010 9:22 PM
Awesome!!! A recent idea came to me to try building a replica of Blackbeard's Queen Anne's Revenge out of Lindberg's Jolly Roger kit. It would look great with his flag flying from it and it would look a lot closer to the recent theories of what the ship might have looked like. Lindberg's Blackbeard ship is great, but they think it may have looked more like the depicted Jolly Roger.
    May 2003
Posted by jtilley on Friday, April 2, 2010 11:19 PM
Unfortunately the model companies have embraced the current (and long-lasting) public obsession with piracy as an excuse to recycle old kits that originally had nothing to do with the subject.
The kit that Lindberg is marketing under the name "Blackbeard" is a reissue of the old (and not very accurate) Pyro Sovereign of the Seas kit from, I believe, the 1960s.  Launched in 1637, the Sovereign of the Seas (later renamed Royal Sovereign) was the largest, most elaborately decorated ship in the navy of England's King Charles I.  She was, in fact, so expensive that Parliament balked at paying the bill; that was one of the factors that eventually cost Charles his head.  The notion of such a vessel operating as a pirate ship is absurd.  No pirate - nobody other than a government - could afford to buy such a thing - or pay the several hundred men required to operate it.  Besides, a great warship like that was notoriously slow, and pirate vessels had to be fast in order to do their dirty work.
The kit Lindberg is currently calling "Jolly Roger" is a reissue of a reasonably accurate (for the 1960s) scale model of a French frigate named La Flore, from the 1780s.  (We've had a number of interesting discussions about that ship here in the Forum.  The kit apparently is based on a model in the Musee de la Marine, in Paris; just what ship that model represents is a matter of some controversy.  Jean Boudriot, the current dean of the history of French naval architecture in the sailing ship era, is of the opinion that the model in the museum represents a ship that was never actually built.)  In any case, it also is far too big to represent a pirate ship.
Edward Teach ("Blackbeard") was born in about 1680 and was killed in 1718 - too late for the Sovereign of the Seas and too early for La Flore.  The unfortunate truth of the matter is that, unless I'm forgetting about one of them (always a possibility in the case of my poor old, Halfzeimer's-afflicted memory) not a single plastic sailing ship kit on the market can be said to be a reasonably representation of a pirate vessel.  (I guess we could, by stretching the point, count the various Golden Hind kits, since Francis Drake was, by many reasonable definitions, a pirate.  And the old Aurora American privateer Corsair might, just conceivably, represent a ship owned by an extremely wealthy pirate of the late eighteenth century.  Those are the only ones I can think of that might fit the bill.)
Several people in the Maritime Studies Program at East Carolina University, where I work, have been intimately involved in the Queen Anne's Revenge project.  (I need to be careful here.  The truth is that the shipwreck in question has not been positively identified; there's no firm reason to believe it actually is the QAR.  But there's no firm reason to believe that it isn't - and so far as I know nobody has suggested any other specific identity for it.)  Not enough of the wreck has been excavated yet to establish in any detail what the ship looked like.
The North Carolina Department of Cultural Resources has a nice website about the QAR project:   http://www.qaronline.org/ .  There's not enough here to give much of an idea about the ship's overall appearance, but the site is useful for stripping away the considerable load of nonsense that's been written about "Blackbeard's flagship" over the years.  The North Carolina Maritime Museum at Beaufort also offers some material on the subject.  Some years ago the museum bought a model of the QAR that's the most reasonable reconstruction of her I've seen - though I have some doubts about it (and I suspect the continuing study of the wreck will cause the gentleman who built the model to have some second thoughts).  There's a photo of it on the museum's website:  http://www.ncmaritime.org/Blackbeard/qar.htm .
I think that model probably was the basis for another reasonably serious modern reconstruction of the Queen Anne's Revenge:  a poster published by, of all places, the Raleigh News and Observerhttps://miva.nando.com/mm5/merchant.mvc?Screen=PROD&Store_Code=TNOS&Product_Code=PQRM&Category_Code=P .  I have the same reservations about this one, but it does strike me as one of the most reasonable versions I've seen.
 As you can see, the NCMM model and the N&O poster look absolutely nothing like the Lindberg "Blackbeard," and only slightly similar to the "Jolly Roger."
I have to admit that I personally am thoroughly jaded by the whole subject of pirates and piracy.  (Twenty-seven years at a university whose athletic teams are known as the ECU Pirates haven't helped.)  I guess I can understand at least some of the ongoing public fascination with the subject.  But I have to suggest that (a) every model kit sold under the label "Pirate Ship" is a marketing scam of greater or lesser proportions, and (b) there are lots of more interesting, and better researched, model subjects out there.
    December 2009
Posted by kazubb on Saturday, April 3, 2010 11:17 AM
Most of the kits marketed as a "Pirate Ship", while they are nice models, are not accurate as a pirate ship. But we can never really be 100% sure of what they looked like. None of us are standing in the 18th century. Even research doesn't help much sense older documents are not very detailed enough to show us exactly what they looked like. Hollywood hasn't helped over the last century either.
The QAR project is a very time consuming effort and it is estimated to take up to another 15 years. Since it's discovery, there hasn't been any concrete evidence saying that it was the Queen Anne's Revenge or formerly Le Concorde. It hasn't been as fortunate as the Whydah wreck.
The QAR museum I'm sure will no doubt have second thoughts in a few years of the model on display.  Most Pirate model kits seem to be huge warships. History records that most pirates actually sailed in small sloops. Blackbeard had three of these at one point I believe.
The Jolly Roger kit is a fun kit. trying to make a 100% accurate kit out of it can't be expected right now as there is little information of the QAR. But this is not the point. The point is it's a HOBBY. A fun way to unwind! No historian is probably gonna ever come into your house any tell you, your ship is all wrong so who cares! I'm still planing on building both of my Jolly Roger kits, having lots of fun with the build, and when it's done I'm proudly displaying it in my living room!
Posted by santa on Saturday, April 3, 2010 3:16 PM
Very nice build thred, I enjoyd the picture posts very much.  Hope to see more.
    May 2003
Posted by jtilley on Saturday, April 3, 2010 9:02 PM
kazubb
I've made this point before here in the Forum, but it seems relevant to this discussion as well so I'll make it again.  I firmly believe that, since model building (for most of us, at any rate) is a hobby, the individual modeler has every right in the world to build models for whatever purpose, and according to whatever standard, he or she thinks is appropriate.  I do, however, take exception to the marketing tactics of certain kit manufacturers, who use deceptive labels and descriptions in a blatant effort to squeeze more sales out of a set of molds.
The notion of the Sovereign of the Seas operating as a "pirate ship" under a captain who hadn't been born when the real ship was built is ridiculous; it makes about as much sense as selling a model of the U.S.S. Arizona as a twenty-first-century Somali pirate vessel.  In any other segment of the plastic kit world, such tactics would produce howls of protest.  Imagine a model of a Spad, or a Sopwith Camel, being sold as the aircraft of a Korean War ace.  Or a Sherman tank posing in Operation Desert Storm markings.  Or a Model T Ford dressed up as a participant in the 1965 Indianapolis 500.
It's not for me to tell hobbyists how to spend their time; heaven knows there are purists who wouldn't approve of some of the projects I do.  (At the moment I'm working on a thoroughly fictitious tugboat, from about 1900, that's named after my wife.)  But I do think potential purchasers are entitled to know the difference between a serious attempt at scale modeling and a marketing stunt.
