Storing and Organizing Paint
    December 2009
Posted by jseese on Thursday, June 10, 2010 1:58 PM
I currently primairy use Tamiya (larger bottles) paint for almost everything. I have all my bottles in a drawer in my work room. I am looking for a good way to store them so I can easily find what I need. I have seen some destop organizers and some carosel type things but am wondering what everyone else does. Right now when I work on a project I have bottles scattered all over my workbench, lol.
I even emailed Tamiya to see if I could buy a retail rack like in my LHS, but they said they only sell them to retailers, bummer. Any tips to stay organized and keep inventory of my paint on hand.
Any pics or links would be super helpful!!
    January 2010
Posted by 101stAirborne on Thursday, June 10, 2010 2:20 PM
I have a rack I use to hold mine, it can be built easily. heres a picture.
Models on the bench:
Too many to count!
    May 2005
Posted by Bgrigg on Thursday, June 10, 2010 2:26 PM
I built a "stair" case to fit the small bottles of Tamiya (the only size I can find locally, the few big bottles I have date from the late 1980s (!). This setup allows me to read the color of each bottle, and they are organized gloss on the left, flat on the right:
So long folks!
    December 2009
Posted by jseese on Thursday, June 10, 2010 2:41 PM
Nice Bill!!
I really like the stepped approach. I might look into that. What di you build it out of? Did you use lumber and build it like a full set of stairs?
    May 2005
Posted by Bgrigg on Thursday, June 10, 2010 3:02 PM
It's made out of Komatex, a rigid "foamed" PVC product, but that's only because I happened to work for a sign shop, and I was using the offcuts. Plywood would be every bit as easy to build with.
The construction is pretty much the same as stairs, the side pieces are cut like stair stringers, and I used risers and treads. I used particle board screws to put it together, again only because I had them on hand.
There are four stringers, in all. One on each end, and two in the middle. Its probably overkill to have the fourth one, but I'm a firm believer in over building things! The risers are cut to support the treads, and the spacing was calculated so I could read the color (I'm repeating myself, aren't I?). The treads are calculated to be 1/8" wider than the bottles they hold. The very first tread doesn't have a stringer under it, its a doubled up piece of tread. You can adjust the sizes to fit your specific bottles, I wish I could buy the big ones locally!
Here is a cross section drawing showing the construction, you will note that I have 7 shelves and the drawing only has 5. That is because I'm lazy! You'll just have to extrapolate! Wink
So long folks!
    December 2009
Posted by jseese on Thursday, June 10, 2010 4:19 PM
Thanks for all the details and the drawing as well. I am at work and will be doing some measuring when I get home. Thanks for the info!!
    May 2005
Posted by Bgrigg on Thursday, June 10, 2010 4:22 PM
You're welcome, please let me know how it turns out for you!
So long folks!
    May 2010
Posted by estein9077 on Thursday, June 10, 2010 5:20 PM
Just remember, while you build it, that no matter how big you build it thinking that should be plenty of room; you will fill it within a month.  I am speaking from experience.
I did a set of steps for mine and had it filled in a week.  I am now considering something so massive that I would never fill.  I know I will though.
Eric
    May 2005
Posted by Bgrigg on Thursday, June 10, 2010 7:29 PM
Eric is speaking the truth, mine's not quite full, but it is nearing it's capacity! And I thought I had over built it...
So long folks!
Posted by Don Stauffer on Friday, June 11, 2010 8:55 AM
I use the drawer method. I do take the colors I need for a project out of the drawer, and just set them on the bench surface.
The problem with any rack is that I have pegboard on the back with hooks to hang my tools, and another along the left side of the bench for supplies like masking tape and such. I have added a piece of wood along the right side for my airbrush bottles, but those sideboards don't have a lot of area compared to the back board.  But, I still have tools in a drawer because the backboard isn't enough area for all of my tools.  What with X-acto knives, small saws, tweezers, pliers, etc. there sure isn't enough room for paint.
    May 2005
Posted by Bgrigg on Friday, June 11, 2010 9:52 AM
Don,
I would tend to agree with you, if that was my only work surface. I'm a bit spoiled, however and the pic above is just my hand painting, masking and decal station, my spray booth is one unit away to the right, and my assembly area is to the left. That's where I keep my tools.
Here is an earlier image of the assembly area, before I expanded my territory through a combination of hostile action and political annexing of neighboring countries. Originally the table top was designed to fold up and close off the bookshelf unit. You can see the paint stairs sitting on the shelf. I had already added the shelf at the back of the table to hold a magnifying lamp, and some tools, negating the folding top. The stash now takes up most of the foot well, and I have a three drawer storage unit under the left overhang for tools, as well as the small three drawer unit pictured. One day I'm planning on rebuilding everything so it's nicer, larger and better, but it suffices so well that it's hard to get motivated!
So long folks!
    February 2010
Posted by 68GT on Saturday, June 12, 2010 5:46 PM
I've seen spice racks like that in home stores.
On Ed's bench, ???
    November 2006
Posted by CuriousG on Sunday, June 13, 2010 4:05 PM
I'd love to line up all my paint like a stair-step spice rack, but that eats up space fast. My compromise is a plastic-drawer organizer typically used for nuts and bolts in your garage or shop. I group the paints by medium and colors to make it a little easier to find what I need. Each tray can hold about eight large Tamiya bottles. For a small footprint on my bench I am able to store 125 or so bottles of Tamiya or Testors.
George Ireland
"If you can't learn to do it well, learn to enjoy doing it badly."  - Ashleigh Brilliant
Posted by Wingman_kz on Tuesday, June 15, 2010 12:10 AM
I use the drawer method too. With the MM enamels and Acryll I use a silver marker and write the # on the lid, since they're all black, and put a little drop of paint on the lid. Then it's easy to spot, whether I'm looking for a # or a shade.
Tony
    December 2009
Posted by jseese on Tuesday, June 15, 2010 4:24 PM
Interesting idea George. I like how you grouped them together and you can pull each drawer out as you need to.
Jon
    December 2009
Posted by jseese on Tuesday, June 15, 2010 4:33 PM
Well I decided because I have enough bench space I would build the stair method. I wanted to use the same concept as posted above but wanted a small lip around the step so I could move it without worrying about the bottles sliding off. I spent $8 for 2 2' x 2' squares of 1/4" oak. It has 4 steps. I will post a picture later as I am at work now but it took me an hour or so to make the cuts and assemble. A few days to stain and clear. I just used wood glue and clamps. I used one coat of stain and 3 coats of clear.Probaly costed $20 all together. For anyone who uses google sketchup (its free!!) email me  and I will send you the plans I drew up. I even made cut sheets so you just have to transfer it to the wood, cut, and assemble.
Picture to come Smile
Jon
    May 2005
Posted by Bgrigg on Tuesday, June 15, 2010 8:10 PM
Cool! Looking forward to the pics.
So long folks!
    October 2006
Posted by JunJon on Wednesday, June 16, 2010 1:20 AM
I bought an Aluminum Angle Bar and cut into proper size then fixed to a wall...
http://3.bp.blogspot.com/_ITCONXvE2OY/TBhq_ObI0eI/AAAAAAAAABk/JJ5V5IpHwcA/s1600/My+Workbench.jpg
    June 2009
Posted by jimbot58 on Wednesday, June 16, 2010 2:55 AM
I made shelves out of 1 X 2 pine, painted and made labels for all. Empty spots are for future colors such as WWII colors I haven't needed yet.
On my workbench now:
It's all about classic cars now!
Why can't I find the "Any" key on my keyboard?
    December 2009
Posted by jseese on Wednesday, June 16, 2010 7:43 AM
For that aluminum shelf on the wall, that is cool, where did you get your material?
    December 2009
Posted by jseese on Wednesday, June 16, 2010 7:49 AM
Here is what I made for my paint. However it is 30 inches long and with 4 shelves I am wondering if I will have enough space, lol!
Jon
    October 2006
Posted by JunJon on Wednesday, June 16, 2010 10:27 AM
Jseese. I got the aluminum bars from a local hardware, selling only aluminum materials for Windows, Doors. It is the most space saver solution I can think of. And it doesnt gets in the way.
    December 2009
Posted by jseese on Wednesday, June 16, 2010 4:10 PM
Thanks, while I like my work.....lol!!!!   I really like your idea. The problem I have is my workshop has upper and lower cabinets so not sure how much vertical space I have. Here is my shop, on the right wall is my paintbooth and the left is a counter for my wife to do her crafts. similar to a kitchen setup but for hobbies.
Jon
    October 2006
Posted by JunJon on Wednesday, June 16, 2010 11:05 PM
Don't worry about the height. You can stretch it horizontally. The Aluminum Bar is rigid. It will take a lot of weight to make it sag. How did I determine the total length? I basically took all the Acrylic colors in the tamiya catalogue then multiply by the bottles dimension. that  But I suggest changing the light under the cabinet. To a more true color light. And looking at your space again. You can try to fix it between the right wall outlet and the wall. Or under the table? Anyway, how often will you reach for the paint. Just a suggestion.
    December 2009
Posted by jseese on Thursday, June 17, 2010 10:24 AM
Thanks for the tips, I will be checking out a few places this weekend.
Jon
    November 2008
Posted by iraqiwildman on Thursday, June 17, 2010 12:32 PM
JunJon, what kind of compressor is that? I need to buy one soon and am gather ideas.
Tim Wilding
    July 2003
Posted by zokissima on Wednesday, June 23, 2010 11:27 AM
I use the 'stairs' shelf as BGrigg. It seemed the most logical to have all of the paint clearly laid out in front. I just bought a cheapo Ikea shelf for $2 which came with wall mounting hardware, and just built stairs on top of it using lumber.
